The TeraFlex JK 3" Suspension Lift Kit gives you everything that you need to tackle some serious trails. Drivability and performance are the most important factors that are engineered and built into every TeraFlex lift kit. Properly developed suspension geometry, roll center, and load tuning ensure that all factory stability controls remain functional and within the parameters that Jeep originally engineered into the vehicle. TeraFlex kits drive straight and will crawl anything, getting you there and back! This system includes 3" lift coil springs, front swaybar disconnects, rear swaybar links, rear trackbar bracket, bumpstops and all necessary hardware.
Click image for larger version
Team this 3" lift up with the Teraflex Sport flex arms! TeraFlex sport fixed-length flexarms are designed to offer maintenance free performance for 2.5" - 3" lift. Pre-adjusted length arm corrects caster and pinion angle for 2.5" - 3" lift kits. 1-5/8" x 0.156 wall DOM tube stands up to trail abuse and demands. High quality, factory style bushings provide excellent vibration damping ride quality characteristics with zero maintenance. Full range of movement will not restrict articulation or flex off-road. Premium black e-dipped coating provides superior durability and corrosion resistance.
You can customize this package deal to your liking! Run all 8 flex arms, or if that doesn't fit your budget, 2 front lower and 2 rear upper to properly align caster and pinion angle. You can purchase this set up with Teraflex 9550 shocks OR you can step up into the VERY MUCH recommended FOX IFP 2.0 shocks for better performance and ride quality!
This is a package deal you DON'T want to miss out on!! Let's make it happen!! Contact me direct for quickest response and BEST pricing! Joel@rockridge4wd.com
