-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   Synergy Suspension Lifts @ Rockridge 4WD! (http://www.jeepforum.com/forum/f43/synergy-suspension-lifts-rockridge-4wd-1333575/)
Rockridge4WD 02-24-2012 11:09 AM
4 Attachment(s)
CLICK HERE --> JK LIFT KITS
CLICK HERE --> JK CONTROL ARMS & COMPONENTS
CLICK HERE --> UNIVERSAL SUSPENSION BUILD COMPONENTS
Let me make your Jeep function and ride amazing. We provide Special Forum Discounts to many product lines. All you need to do is email or call!
:cheers2:
Rockridge4WD 02-29-2012 11:03 PM
3 Attachment(s)
Since we seem to have no interest just yet in Synergy let ROCKRIDGE 4WD show you why these are such awesome products!!
#1 These adjustable ARMS are freaking awesome! They use a pinch bolt instead of a Jam nut which is super premium in my opinion, and the secondary adjuster tightens with the pinch bolt as well. This means you can adjust your arms without even unbolting anything. GENIUS! Also, they use only the best, the Currie Johnny joint!
Attachment 355413
#2 These ball joints are bullet proof, the proof is in the picture!
Attachment 355414
#3 They make killer long arm upgrades and full suspension kits. I'm pretty sure they have it dialed in for JK like nobodies business....
Attachment 355415
Why you ask?
*The JK Synergy Suspension System™ was designed and engineered from the ground up using a synergistic approach to maximize the JKs on & off road performance
*Stage 4 key features are a front track bar relocation bracket, drag link flip kit, rear track bar relocation bracket, and all adjustable upper & lower long arm control arms
*Suspension components feature a 2 stage powder coat finish for maximum durability
*Lower control arms are manufactured from high quality crush resistant 2″ X .25″ Wall 1026 DOM tubing
*Control arms incorporate the tried and true Currie Enterprises Johnny Joints® for paramount performance & durability
*OEM style rubber bushings are also used in the control arm assemblies for extended permanence & minimized road vibration
*Sway-bar disconnect system for ultimate trail articulation mounts sway bar up and out of the way when disconnected from the axle
*Synergy Suspension double adjuster sleeve & pinch bolt assembly allows for easy adjustment of control arms & drag link without removal
*Progressive wound coil spring manufactured using the latest in CNC hot winding technology keeps spring from coming unbound at full suspension droop
*Front & rear track bar relocation brackets move track bar mounting position increasing suspension roll center height which improves handling on and off road
*Suspension components feature an abrasive-resistant powder coat finish for maximum durability and corrosion resistance
*100% bolt on components assures an easy, trouble free installation with the use of basic hand tools
THAT'S WHY......
Contact me by Emailing or Call and I will make sure that the suspension you buy for your JK is the ultimate upgrade that you will ever do. Period.
:2thumbsup:
Rockridge4WD 02-10-2015 03:57 PM
2 Attachment(s)
ATTENTION JK GUYS!!!! Are you lifted, locked and ready for the trails?! BUT WAIT!! You notice you're getting some serious death wobble at 50mph (or so)?! Death wobble can be a serious pain in the A**.. Not only dangerous and annoying, but can also lead to more damage that you DON'T want to pay for later.. trust me!
Rockridge4wd has the fix for you death wobble. It's a system of TOP of the line Synergy components that team up to tighten your steering, stabilize your axle, bring everything back to it's normal, solid, parallel self!!
This COMPLETE death wobble fix contains-
SYNERGY Chromoly tie rod with double adjuster sleeve and pinch bolt system
SYNERGY High steer drag link
SYNERGY Track bar relocation bracket
SYNERGY Tie rod end flip adapter
SYNERGY Front track bar
SYNERGY Steering stabilizer tie rod clamp
SYNERGY Track bar brace
Don't put this off!! DEATH WOBBLE IS SERIOUS!!
Contact me direct for some pricing on all this beefed up AWESOMENESS!!
Joel@rockridge4wd.com
The time now is 11:17 AM.
