SYE Slip Yoke Eliminator Kit SALE at JeepHut.com - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > SYE Slip Yoke Eliminator Kit SALE at JeepHut.com
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 01-20-2012, 03:44 PM   #1
JeepHut
Vendor
JeepHut's Avatar
NP231 Transfer Case Slip Yoke Eliminator Kit, 87-06 Wrangler
This kit is a MUST if you installed a 2in or taller suspension Jeep in your 1987-2006 Wrangler (not needed for body lifted Jeeps). The kit fits all newer production NP 231 transfer cases (1988up). A Slip Yoke Eliminator Kit will eliminate the need to drop your transfer case in order to avoid drive train vibrations that are caused by taller suspension lift kit. The purpose of this kit is to replace the slip yoke portion of the NP 231 with a fixed-yoke, CV style drive shaft assembly. This is the most complete and strongest kit available. Check out the size and thickness of the output shaft housing. NOTE: A CV equipped drive shaft will be required for this conversion kit.
Give us a call. 706-692-5488
http://thejeephut.com/np231-transfer-case-slip-yoke-eliminator-kit-8799-wrangler-p-28331.html
www.thejeephut.com
JeepHut is offline   Reply With Quote
Unread 01-20-2012, 03:52 PM   #2
alex101
1987 YJ Wrangler
hey how much for one of those for my 87 yj 4 banger with a cv driveshaft. Whats the driveshaft made by too.
alex101 is offline   Reply With Quote
Unread 01-20-2012, 04:00 PM   #3
JeepHut
Vendor
JeepHut's Avatar
pm sent. Thanks for your business.
www.thejeephut.com
Unread 01-20-2012, 04:02 PM   #4
tractor1
old dog
tractor1's Avatar
1979 CJ5
cost with shiping to 60560
1979 CJ5 304 T150 Dana 20 under construction
1993 Wrangler 4.0 HO AX15 231 4” lift 33 12.5 15 DD
1994 Wrangler 2.5 AX5 231 Stock Sold
1973 Cj5 304 T15 Dana20 Sold
tractor1 is offline   Reply With Quote
Unread 01-20-2012, 04:42 PM   #5
JeepHut
Vendor
JeepHut's Avatar
pm sent
www.thejeephut.com
Unread 01-22-2012, 05:01 PM   #6
Asco
Price delivered to 20639 just the SYE
Asco is offline   Reply With Quote
Unread 01-23-2012, 07:44 AM   #7
LukerSuperman
How much for the SYE and driveshaft shipped to 72802? Also, a quote on just the SYE to the same zip.
LukerSuperman is offline   Reply With Quote
Unread 01-23-2012, 12:28 PM   #8
JeepHut
Vendor
JeepHut's Avatar
pm sent
www.thejeephut.com
Unread 01-23-2012, 02:27 PM   #9
RedneckJacob
1987 YJ Wrangler
how much for SYE and driveshaft shipped to 64870? and a quote on just the SYE to 64870? thanks.
RedneckJacob is offline   Reply With Quote
Unread 01-23-2012, 04:30 PM   #10
Jeepguy91
How much for just the sye shipped to 46582?
2000 XJ limited-3" rough country, winch, winch bumper, 31" BFG at's
89 XJ- stock for now
Jeepguy91 is offline   Reply With Quote
Unread 01-23-2012, 04:32 PM   #11
bniedert
bniedert's Avatar
SYE to 60543
Oswego, IL
2000 TJ 4.0 5 Speed - currently
Formerly: 2000 TJ 4.0 Auto REBB
2001 XJ 4.0 Auto
bniedert is offline   Reply With Quote
Unread 01-23-2012, 06:31 PM   #12
01BigSmitty
SYE only to 28348
01BigSmitty is offline   Reply With Quote
Unread 01-24-2012, 08:37 AM   #13
JeepHut
Vendor
JeepHut's Avatar
quotes sent
www.thejeephut.com
Unread 01-24-2012, 11:32 PM   #14
kylo
Cost of just the SYE with shipping to 84094?
kylo is offline   Reply With Quote
Unread 01-25-2012, 07:07 AM   #15
jkiech
SYE and drive shaft to 20148? Thanks in advance!
jkiech is offline   Reply With Quote
