Swag Off Road new vendor on Jeep Forum - Page 4 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Swag Off Road new vendor on Jeep Forum
Memorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-04-2010, 12:41 PM   #46
Swagoffroad
Vendor
Swagoffroad's Avatar
Thanks again for the orders.
Let me know if you have any questions about the products I sell.
Thanks Troy
Swagoffroad.com
Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's.
Visit us on Facebook
Swagoffroad is offline   Reply With Quote
Unread 10-04-2010, 04:34 PM   #47
FamillyCJ7
1983 CJ7
any plans on making stuff for CJ7's? I could use a set of front tube fenders, I like the metal cloak look.
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline   Reply With Quote
Unread 10-04-2010, 09:47 PM   #48
Swagoffroad
Vendor
At this time I don't have plans to make tube fenders for any Jeep model that is a pretty crowded market with a dozen different companies to choose from.
Troy
Swagoffroad.com
Unread 10-13-2010, 03:55 PM   #49
Swagoffroad
Vendor
Duck Tongue....
Ideal for those with tight clearances or those who lack room to mount lights on the bumper.
Keep your lights out of harms way and clear of trail obstacles like branches, rocks, and trees.
No drill installation, bolts up to existing holes on top of the grill.
Constructed out of 3/16" steel to reduce vibration and dimple died for added stiffness.
Swagoffroad.com
Unread 10-15-2010, 10:44 AM   #50
76flh
troy, i have the diamond plate panel on my tailgate with the diamond plate lower panel below the tailgate. will the drop down kit work with this setup or will it need to be removed.
76flh is offline   Reply With Quote
Unread 10-15-2010, 11:49 AM   #51
Swagoffroad
Vendor
The drop down tailgate will work with your diamond plate panels. No modifications or additional work is necessary to in stall this kit.
I have everything in stock ready to ship out.
Thanks Troy
Swagoffroad.com
Unread 10-20-2010, 01:27 PM   #52
Full_Rut95
How much is the tailgate conversion for a TJ?
Full_Rut95 is offline   Reply With Quote
Unread 10-20-2010, 01:34 PM   #53
Swagoffroad
Vendor
$160 or $180 depending on which hinges you purchase with the kit.
Take look at the following link. Swagoffroad.com YJ, TJ & JK Fold Down Tailgate Conversion Kits
Let me know if you have any questions. I have plenty in stock ready to ship out.
Troy
Swagoffroad.com
Unread 10-25-2010, 01:08 PM   #54
Swagoffroad
Vendor
Some times I win, sometimes I loose. I am currently sitting on 60 sets of expensive paper weights AKA Harbor Freight pipe roller dies. I am going to machine these into tube dies and or square dies because they are not moving off of my shelf.
So, if you have a use for pipe dies you have until this Wednesday the 27th before I turn them into tube dies and pull them off the website.
0.50" Round Pipe
0.75" Round Pipe
1.00" Round Pipe
1.50" Round Pipe
A couple days until they are gone for good. I will sell the pipe dies at $15 off retail for a total of $135 ea.
Harbor Freight Tubing Roller Die Sets
Troy
Swagoffroad.com
Unread 10-25-2010, 01:10 PM   #55
MountainMan864
And what are those used for exactly?
MountainMan864 is offline   Reply With Quote
Unread 10-25-2010, 01:19 PM   #56
Swagoffroad
Vendor
YouTube - Harbor Freight Tubing Roller 1.75" Dies @ swagoffroad.com
It make large gradual bends in tubing.
Swagoffroad.com
Unread 10-25-2010, 05:04 PM   #57
olebluetj
you got some great products there, i do like the grill lights idea, when funds come in i'll be calling, by the
way your 01 tj is a sharp rig, looks identical to mine
98 xj
a few dodads
olebluetj is offline   Reply With Quote
Unread 10-28-2010, 12:27 PM   #58
Swagoffroad
Vendor
Sounds good.
Have everything listed on the website in stock boxed up and ready to ship out.
Let me know when you are ready.
Troy
Swagoffroad.com
Unread 11-15-2010, 03:42 PM   #59
Swagoffroad
Vendor
I will now offer to put in a key way in every drive roller purchased through Swag's website for the Harbor Freight tubing roller. I will include 6mmx6mm key way with every purchase. You can purchase fully keyed 20mm drive axles Part Number: 1439K611 through Mc master Carr for ~$32.
It works so much better than set screws when your rolling thick walled tubing. You will be required to adapt the captians wheel to the drive roller, however it is easy done with a grinder to drop the shaft dia from 20mm down to 3/4"
If you want to have me key your current drive rollers as shown below, send them my way and for $42 I will key the drive rollers and send them back to you.
Troy
Swagoffroad.com
Unread 11-26-2010, 09:52 AM   #60
Swagoffroad
Vendor
With this DIY 20 ton press brake kit you can bend steel and have a professional look about it.
If your still using a torch and a bench vise to bend steal check out this video.
YouTube - 20 TON Press Brake DIY Builder Kit @ Swagoffroad.com
Thanks again for the orders. Troy
Swagoffroad.com
