SWAG 50 Cal Ammo Can Mount With M2A1 Can - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > SWAG 50 Cal Ammo Can Mount With M2A1 Can
Rampage Bowless Soft Top Oconee offroadAlloy USA Still AvailableAdvance Adapters SYE Kits
Unread 07-16-2014, 10:55 AM   #1
Swagoffroad
Vendor
Have you been looking for a tough, reliable, safe, water proof, airtight, lockable storage at a very competitive price? The SWAG 50 cal ammo can mounts are just that. M2A1 Military ammo cans are used extensively in the field to transport a variety of calibers of ammunition to the troops. These cans feature a removable lid with a rubber gasket seal, flat folding handle for carrying, lever-lock lid that is lockable, and they are constructed of heavy gauge steel. These are ideal for storing ammo, tools, or anything you want to keep locked up and secured.
The SWAG ammo can mount is constructed out of 12 gauge 5052 Aluminum which keep the weight down and does not require painting. Well suited for the off-road, overland expedition, vehicle racing, and or anywhere you need a tough lockable storage box.
Note: The footman loop mounted on the rear of the ammo can is attached using two stainless steel fasteners and nyloc nuts. If you wish to keep the box completely water proof you will need to remove the fasteners and install silicone and or rubber washers to make a water tight seal.
You can purchase the The SWAG ammo can mount with our with out the ammo can as noted in the drop down menu above. 100% proudly made it the USA. The overall can dimensions are 11" X 5.5" X 7".
https://www.youtube.com/watch?v=KZmy...sGAw4kaEuLMsmg
Swagoffroad.com
Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's.
Visit us on Facebook
Swagoffroad is offline   Reply With Quote Quick reply to this message
Unread 07-23-2014, 09:15 AM   #2
Swagoffroad
Vendor
Thanks again for the orders.
Just a heads up the 50 Cal Fat 50 can is in production and will be added to the website as soon as we have sufficient quantities available.
Please let us know if you have any questions along the way.
Thanks SWAG
Swagoffroad.com
