Steering and more from Ruffstuff! - Page 9 - JeepForum.com
post #121 of 376 Old 09-12-2012, 10:52 AM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
Steer on in to strength and savings at Ruffstuff
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #122 of 376 Old 09-17-2012, 02:59 PM Thread Starter
Dan Fredrickson
Vendor
Time to go big
Dan Fredrickson
post #123 of 376 Old 09-23-2012, 02:09 PM Thread Starter
Dan Fredrickson
Vendor
Before you hit the road make sure your steering is up to it...
Dan Fredrickson
post #124 of 376 Old 10-02-2012, 07:42 AM Thread Starter
Dan Fredrickson
Vendor
Great savings on steering still going
Dan Fredrickson
post #125 of 376 Old 10-02-2012, 12:18 PM
NEastUnlmtd
I am wondering, do you know of anyone that used your coil-over mounts to outboard TJ rear shocks?
These: http://www.ruffstuffspecialties.com/.../STOWER12.html
Any offering on a shock tower specific to the geometry needed to relocate a TJ rear shock?
NEastUnlmtd is offline
post #126 of 376 Old 10-02-2012, 03:45 PM Thread Starter
Dan Fredrickson
Vendor
Quite a few do, they are made to able to use them in any application... They will need to be cut but they do work. We are working on a bunch of TJ type kits right now too, watch for them!
Dan Fredrickson
post #127 of 376 Old 10-03-2012, 11:27 AM
NEastUnlmtd
Sounds good, thanks.
post #128 of 376 Old 10-09-2012, 09:57 AM Thread Starter
Dan Fredrickson
Vendor
Steer yourself in the right direction with one of our kits!
Dan Fredrickson
post #129 of 376 Old 10-10-2012, 09:38 AM Thread Starter
Dan Fredrickson
Vendor
Breaking TRE's? Time to swap it out!
Dan Fredrickson
post #130 of 376 Old 10-11-2012, 05:55 PM Thread Starter
Dan Fredrickson
Vendor
Strength you need!
Dan Fredrickson
post #131 of 376 Old 10-12-2012, 10:46 PM
djlarroc
1997 XJ Cherokee
hi Dan, just making sure, but the y kit is not bolt in correct? must be cut to length, and welded? also can it be used UTK? and how many inserts must be purchased to install (if not using a reamer)? 3?
thanks
'97 XJ Country, 3" hybrid, 245/75 MTR, TJ Moabs, Front Truetrac/Rear Aussie, 4:10 gears, skids, recovery.
djlarroc is offline
post #132 of 376 Old 10-12-2012, 11:08 PM Thread Starter
Dan Fredrickson
Vendor
Yes, it is a cut and weld to fit kit. For UTK you do not need the inserts, for OTK you would need them with TRE's but not with Heims.
Dan Fredrickson
post #133 of 376 Old 10-13-2012, 09:11 AM
djlarroc
1997 XJ Cherokee
Thanks!!!!!!!
djlarroc is offline
post #134 of 376 Old 10-15-2012, 09:41 AM Thread Starter
Dan Fredrickson
Vendor
Hope everyone had a great weekend!
Dan Fredrickson
post #135 of 376 Old 10-19-2012, 09:17 AM Thread Starter
Dan Fredrickson
Vendor
Don't let your stock steering hold you back!
Dan Fredrickson
DOM Tube now available at Ruffstuff! Dan Fredrickson Vendor Display 51 07-07-2014 09:18 AM
You may not post new threads
