Steering and more from Ruffstuff! - Page 4 - JeepForum.com
post #46 of 372 Old 11-29-2011, 10:51 PM
DoctorTim
hey, ive been lookin around for a steering setup that doesnt change my alignment if the lift height changes like a crossover steering set provides, but without the 300 dollar price tag that a crossover setup comes with. I have a 96 XJ. What are your options for me? any DIY kits?
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #47 of 372 Old 11-29-2011, 10:54 PM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
Your alignment may be changing because of the shift caused from a too short panhard due to lift? Is yours a linked front end?
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #48 of 372 Old 11-29-2011, 11:02 PM
DoctorTim
not sure what you mean, its the stock steering for most jeeps. it looks like this (not my picture). when the jeeps weight or lift height changes, it also changes the toe on the front wheels.
post #49 of 372 Old 11-30-2011, 07:32 AM
sexysun555
sexysun555 is offline
post #50 of 372 Old 11-30-2011, 12:00 PM Thread Starter
Dan Fredrickson
Vendor
There are so many factors that come into play when you lift, somethings are simply never considered by the companies making lift kits. Several kits will even change the knuckle position from stock which will cause all kinds of problems. Long arm kits that do not change the position of the upper link mount are notorious for causing steering issues.
And then we have tire size changes. If you go up in tire size without changes to your panhard your axle is moving to the right. Think about it and you will see my point. Your Panhard/Trak bar is very is affected even when you do small changes.
Dan Fredrickson
post #51 of 372 Old 11-30-2011, 01:13 PM
DoctorTim
i know that, i have an adjustable trac bar. but say you go on a road trip and the jeep is loaded up so the suspension is compressed about an inch in the front, this will mess up the alignment and wear out the inner edge of the tires. what i am looking for is a steering setup with a tierod that links both knuckles, and the draglink is connected to the tierod itself. do you understand?
post #52 of 372 Old 11-30-2011, 04:57 PM Thread Starter
Dan Fredrickson
Vendor
We can do that with either TRE's or Heims...
http://www.ruffstuffspecialties.com/catalog/YLINK.html
Dan Fredrickson
post #53 of 372 Old 12-03-2011, 01:32 PM Thread Starter
Dan Fredrickson
Vendor
Time to make your move up!
Dan Fredrickson
post #54 of 372 Old 12-05-2011, 02:16 PM Thread Starter
Dan Fredrickson
Vendor
One of the best moves for longevity!
Dan Fredrickson
post #55 of 372 Old 12-12-2011, 09:52 AM Thread Starter
Dan Fredrickson
Vendor
Factory steering needs to be gone when you move up, it simply cannot hang with trail abuse...
Dan Fredrickson
post #56 of 372 Old 12-13-2011, 11:56 AM Thread Starter
Dan Fredrickson
Vendor
Step up your game with the best!
Dan Fredrickson
post #57 of 372 Old 12-16-2011, 07:53 PM Thread Starter
Dan Fredrickson
Vendor
Most people put off the steering for last and that only makes sense but it isn't something you should ever let slide because the old steering works OK... OK isn't near good enough for steering!
Dan Fredrickson
post #58 of 372 Old 01-02-2012, 10:28 PM Thread Starter
Dan Fredrickson
Vendor
The way the factory SHOULD have built your steering...
Dan Fredrickson
post #59 of 372 Old 01-09-2012, 10:52 AM Thread Starter
Dan Fredrickson
Vendor
Time to do it right!
Dan Fredrickson
post #60 of 372 Old 01-10-2012, 08:36 PM Thread Starter
Dan Fredrickson
Vendor
Always a great choice!
Dan Fredrickson
DOM Tube now available at Ruffstuff! Dan Fredrickson Vendor Display 51 07-07-2014 09:18 AM
You may not post new threads
