Stainless Steel Door Hinge Pins - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Stainless Steel Door Hinge Pins
Awesome Open box items at OPENBOXOFFROAD.COMIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.com
Unread 08-24-2014, 08:33 AM   #1
mecheng10
Vendor
Magnitude Engineering's premium line of stainless steel replacement pins for Jeep Wrangler door hinges will allow you to replace your corroded, deteriorated, broken, or worn out pins with ease. Whether you are trying eliminate unsightly rust, compensate for years of wear, fix that door that won't latch properly, or prevent potentially damaging leaks due to door misalignment; replacing your pins is a simple and cost effective way to improve the appearance and operation of your door.
Simply remove the old pins and insert new ones in their place without the extra time, expense, and risk of replacing your hinges. As opposed to replacing your hinges, replacing only your pins minimizes the risk stripping a screw, exposing unpainted steel, or damaging paint on your door that could cause it to rust.
Magnitude Engineering's premium replacement pins are precision machined from solid stainless steel bar. Unlike OEM or other replacement pins that are cold formed from rust susceptible mild steel and coated with a thin layer of plating that can be scratched or wear away over time, these solid stainless steel pins will not flake or rust.
Visit the Magnitude Engineering website for more information or to purchase at:
http://www.magnitude-engineering.com/shop/
mecheng10 is offline   Reply With Quote Quick reply to this message
door , hinge , jeep , pin , wrangler
