Stainless Steel Door Hinge Pins - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Stainless Steel Door Hinge Pins
The Cure for your Tie Rod Roll!Offset Tie Rod Kit From RuffStuff!SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 04-19-2014, 08:27 AM   #1
mecheng10
Vendor
Magnitude Engineering's premium line of stainless steel replacement pins for Jeep Wrangler door hinges will allow you to replace your corroded, deteriorated, broken, or worn out pins with ease. Whether you are trying eliminate unsightly rust, compensate for years of wear, fix that door that won't latch properly, or prevent potentially damaging leaks due to door misalignment; replacing your pins is a simple and cost effective way to improve the appearance and operation of your door.
Simply remove the old pins and insert new ones in their place without the extra time, expense, and risk of replacing your hinges. As opposed to replacing your hinges, replacing only your pins minimizes the risk stripping a screw, exposing unpainted steel, or damaging paint on your door that could cause it to rust.
Magnitude Engineering's premium replacement pins are precision machined from solid stainless steel bar. Unlike OEM or other replacement pins that are cold formed from rust succeptable mild steel and coated with a thin layer of plating that can be scratched or wear away over time, these solid stainless steel pins will not flake or rust.
Visit the Magnitude Engineering website for more information or to purchase at:
http://www.magnitude-engineering.com/shop/
mecheng10 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2014, 10:15 AM   #2
Timeless
1987 MJ Comanche
Do you guys know you can bump threads instead of making new duplicates every few days?
Timeless is offline   Reply With Quote Quick reply to this message
Unread 04-21-2014, 12:18 PM   #3
Nitr0EngiEx
what are the factory pins made of ?
Nitr0EngiEx is offline   Reply With Quote Quick reply to this message
Unread 04-26-2014, 09:01 AM   #4
mecheng10
Vendor
Factory Pin Material
The factor pins are made of plain carbon steel. Magnitude Engineering pins are made of stainless steel primarily for corrosion resistance reasons.
