SPARTAN LOCKER by USA Standard Gear 15% Off
The Spartan Locker by USA Standard Gear is a mechanical locker that replaces the spiders in a standard open case differential.
The Spartan Locker's design, eliminates the use of the thrust washers and has a revolutionary spring and pin design that makes installation a snap!
The couplers and drivers are made from 9310 MATERIAL, for added strength.
Each Spartan Locker carries a ONE YEAR WARRANTYagainst manufacturing defects.
Spartan lockers are available for the following open case differentials:
Dana 30 27 Spline
Dana 44 30 Spline
Dana 44 Heavy Duty 30 Spline, 96-98 Jeep ZJ Grand Cherokee, 99-04 Jeep WJ Grand Cherokee
Dana 35 27 Spline, 1994-2006 Jeeps and 1993 Models with 1.5 Side Bore
Dana 35 27 Spline, 1987-1992 Jeeps and 93 Models with 1.6 Side Bore
AMC 20 29 Spline, 76-86 Jeep CJ5 CJ7 and CJ8 with AMC 20 Rear Axle
Dana 60 35 Spline
Sukuzi Samurai, 85-95 Front or Rear
Nissan Titan rear differential with 32 spline axles 2004-2010
Toyota 7.5" with 27 spline axles
Toyota 8" differential with 30 spline axles
Toyota V6 with 30 spline axles
Toyota 9.5" Landcruiser with 30 spline axles
GM 12 bolt car & truck with 30 spline axles
Chrysler 8.25 29 Spline
Chrysler 8.25 27 Spline
Ford 8.8 31 Spline
Ford 9" 28 or 31 Spline
Installation Video of Spartan Lockers
Spartan Lockers In Action.
Dana 30 27 Spline
Dana 44 30 Spline
Dana 60 35 Spline
Ford 8.8 31 Spline
