Smittybilt Products at Oconee Off-Road! - JeepForum.com
post #1 of 28 Old 05-16-2014, 02:17 PM Thread Starter
oconee offroad
Consulting Jeep Needs
oconee offroad's Avatar
1981 CJ7
Jeep SRC and XRC for JK, TJ, CJ, XJ and more available here at Oconee Off-Road! We carry ALL Smittybilt products! Bumpers, winches, tops and more!
TJ and CJ front XRC Bumper
The Smittybilt XRC Bumper line was engineered to provide maximum clearance for rock crawling. Each bumper has high degree approach angles and raised corners to maximize ground clearance, with 3/16" cold rolled steel bars robotically welded for exact specifications. A two stage powder coat is then applied for the ultimate look.
JK XRC MOD Front Bumper
The all new JK XRC M.O.D. (Multi Optional Design) Bumper System allows you to design your bumper for any terrain. The base unit was developed around our XRC platform and comes standard with a winch cradle with capacity to support up to a 15,000lb. winch. Its also equipped with D-Ring mounts that are welded on the inside and out that provides a towable anchor when pulling your rig behind a truck or motor home. Choose between our Mid or Full Width End Plate knowing that bumper clearance won't be sacrificed when wheeling in the harshest conditions. Then decide which over rider you prefer, you can choose between our low profile bull bar or our high point stinger.
JK XRC Front Bumper
Like all Smittybilt Jeep parts, the Smittybilt XRC Bumper line was engineered to provide maximum clearance for rock crawling. Each bumper has high degree approach angles and raised corners to maximize ground clearance, with 3/16" cold rolled steel bars robotically welded to the exact specifications. A two stage textured matte black powder coat is then applied for the ultimate look. The front stinger is manufactured from 1.75" tubing and has 2 light tabs that could accommodate up to two 9" lights. Its unique design is capable of mounting up to 10,000 lb winch with the option of running an aluminum or roller fairlead. Each bumper was developed to be a complete bolt on and requires no modifications to your vehicle.
Cherokee XJ XRC Front Bumper
The all new line of Smittybilt XRC bumpers for the 84-01 Jeep Cherokee was engineered to provide maximum ground clearance. Manufactured out of 3/16" cold rolled steel that is robotically welded to exact specifications. The front bull bar is manufactured from 1.75" tubing and has two light tabs that can accommodate up to a 9" light. Its unique design is capable of mounting up to a 12,000 lb. winch.
CJ and TJ XRC Rear Bumper
The New XRC Rear Bumper is Manufactured out of 3/16" cold rolled steel, and comes standard with a Class III receiver hitch and two solid D-ring mounts that are welded on the inside and out for maximum strength. The optional swing away portion features a billet handle with a camlock system, adjustable tire mount and safety catch that will hold the Swing Away open while parked or positioned at an angle. The optional Swing Away Tire Carrier can be added to the bumper at anytime!.
JK XRC Rear Bumper
Smittybilt XRC Rear Bumpers implement the same technology and advanced engineering as XRC front bumpers, but also add a tow hitch mount and optional spare tire carrier. For rugged, heavy duty equipment designed to prepare you for off-road terrain, Smittybilt XRC Rear Bumpers are the answer you're looking for.
Cherokee XJ XRC Rear Bumper
TJ SRC Front Bumper
For the toughest and most durable bumper system ever created, Smittybilt Rock Crawler Series delivers heavy duty equipment designed to withstand the off-road use and abuse. Powdercoat painted 2" x 0.120" wall tube protects your front end, and sloping ends allow for greater tire travel with enhanced entry and exit. Available in textured Black finish to match the SRC bumper mount tire carrier.
JK SRC Front Bumper
THE NEW LINE OF SMITTYBILT ROCK CRAWLER (SRC) PRODUCTS for the NEW Jeep Wrangler we've designed and tested to the EXTREME! The SRC bumpers are engineered to provide the maximum protection without sacrificing the ability to go anywhere off road. Each SRC Front Bumper features a 3/16" solid plate center section that wraps and protects the frame horns and lower cross member; which provides the ultimate protection when off roading. Each front bumper has an integrated winch mount and is capable of holding a winch with up to a 10,000 LB rated line pull. Both the front and the rear bumpers feature a two point shackle mount system that is welded on the outside and inside of the bumper. The 1.75" over rider and wings are manufactured from 1010.120 wall tubing and are custom formed to compliment the front of your new Jeep. All of the SRC products come in the signature series matte black textured two stage powder coat.
TJ SRC Front Stinger Bumper
Smittybilt is proud to introduce a complete line of front and rear stingers developed and thoroughly tested in the most extreme conditions. The Smittybilt Stingers are hand crafted to exacting specifications using DOM 1020 2" Tubing which is one of the strongest materials available. Each Stinger base is manufactured out of 3/16" cold rolled steel with reinforced gussets and solid D-Ring mounts that are welded on the inside and out for maximum strength. All of the Stinger products come in the signature series textured matte black finish and come with a 5 year Limited Warranty. When you're looking for the most ground clearance and want a Stinger that can withstand the most hostile environments look to Smittybilt to provide you the very best in stinger technology!
JK SRC Front Stinger Bumper
TJ SRC Rear Bumper
Designed with the off-road enthusiast in mind, Smittybilt SRC Rear Bumpers are the perfect addition to any Jeep running oversized tires. The finest materials combined with a dual stage powdercoat help make this one heavy duty piece of equipment that is built to last. The optional tire carrier allows you to accommodate a spare oversize tire with ease.
*Class III Hitch Rated.
JK XRC Fender Armor
Smittybilt XRC JK Armor - The new line of XRC JK Front Fenders were specifically engineered to provide the maximum protection and clearance needed when you're pushing your rig through the toughest conditions.
Each piece of XRC JK Armor is manufactured out of 3/16" cold rolled steel and then powder coated in Smittybilt's signature series two-stage finish. Each section of XRC JK Armor is designed to be a complete bolt-on with stainless steel fasteners. All of the XRC JK Armor comes with an inner fender liner to keep mud, snow or any other debris out of the engine compartment and wheel wells.
Many more options available! Give us a call today or visit our website!
Located in Bogart / Athens GA.
The best off road shop in the Classic City!
Oconee Off-Road
Visit our retail store & 8 Bay Install Shop!
ATHENS, GEORGIA 30606
THE BEST OFF ROAD SHOP IN THE CLASSIC CITY
We carry the Largest assortment of Jeep Restoration Parts and After Market Accessories from 1941-2015 at low prices!
WE PRICE MATCH COMPETITORS!!!!!
Call to Order 706-534-9955
9-6 M-F 10-1 Sat
We take all major credit cards and Paypal
Call or Visit our web site to order. Use JEEP10 Promo Code to save 10%
FREE SHIPPING ON WEBSITE ORDERS OVER $50
oconee offroad is offline
post #2 of 28 Old 05-21-2014, 03:11 PM Thread Starter
oconee offroad
1981 CJ7
Thanks for all the orders! Give us a call or stop by to order your new Smittybilt parts today!
Oconee Off-Road
9-6 M-F 10-1 Sat
post #3 of 28 Old 05-23-2014, 09:58 AM Thread Starter
oconee offroad
1981 CJ7
Thanks for all the orders! Give us a call today to order your new parts for your Jeep!
Oconee Off-Road
9-6 M-F 10-1 Sat
post #4 of 28 Old 05-27-2014, 07:04 AM Thread Starter
oconee offroad
1981 CJ7
Have an interest in Smittybilt products?
Give us a call ~
Oconee Off Road
706 534 9955
Oconee Off-Road
9-6 M-F 10-1 Sat
post #5 of 28 Old 05-30-2014, 07:14 AM Thread Starter
oconee offroad
1981 CJ7
Thanks for all the orders guys! Keep them coming!
Oconee Off-Road
9-6 M-F 10-1 Sat
post #6 of 28 Old 06-03-2014, 04:26 PM Thread Starter
oconee offroad
1981 CJ7
Lots of items to choose from!
Oconee Off Road carries 100% smittybilt ~
just sayin'......
Oconee Off-Road
9-6 M-F 10-1 Sat
post #7 of 28 Old 06-04-2014, 12:14 PM Thread Starter
oconee offroad
1981 CJ7
we carry 100% All Smittybilt products...
Just sayin'...
Oconee Off Road
706 534 9955
Oconee Off-Road
9-6 M-F 10-1 Sat
post #8 of 28 Old 06-05-2014, 08:16 AM Thread Starter
oconee offroad
1981 CJ7
Just sayin'...
Oconee Off Road
706 534 9955
Oconee Off-Road
9-6 M-F 10-1 Sat
post #9 of 28 Old 06-10-2014, 09:44 AM Thread Starter
oconee offroad
1981 CJ7
Smittybilt special on seats till the end of the month of June!
Purchase a pair of front SmittyBilt XRC Seats and receive a matching rear seat cover free. ($129.99 Value)
Give a call!
Oconee Off Road
706 534 9955
Oconee Off-Road
9-6 M-F 10-1 Sat
post #10 of 28 Old 06-13-2014, 07:28 AM Thread Starter
oconee offroad
1981 CJ7
Thanks for all the orders! Keep them coming!
Oconee Off-Road
9-6 M-F 10-1 Sat
post #11 of 28 Old 06-17-2014, 02:45 PM Thread Starter
oconee offroad
1981 CJ7
Thanks for all the orders! Give us a call to order your Smittybilt products today!
Oconee Off-Road
9-6 M-F 10-1 Sat
post #12 of 28 Old 06-27-2014, 08:25 AM Thread Starter
oconee offroad
1981 CJ7
Thanks for all the orders! Keep them comin!
Oconee Off-Road
9-6 M-F 10-1 Sat
post #13 of 28 Old 07-01-2014, 07:44 AM Thread Starter
oconee offroad
1981 CJ7
PM's sent out!
Thanks everybody!
Oconee Off-Road
9-6 M-F 10-1 Sat
post #14 of 28 Old 07-07-2014, 02:26 PM Thread Starter
oconee offroad
1981 CJ7
Oconee Off-Road
9-6 M-F 10-1 Sat
post #15 of 28 Old 07-19-2014, 12:48 PM Thread Starter
oconee offroad
1981 CJ7
great product!
Oconee Off-Road
9-6 M-F 10-1 Sat
You may not post new threads
