Savvy/Currie Aluminum Control Arms - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Savvy/Currie Aluminum Control Arms
Awesome Open box items at OPENBOXOFFROAD.COMIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.com
Unread 12-07-2013, 11:34 AM   #1
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Our control arms started a revolution. The aluminum double adjustable the first commercially available double adjustable with Currie Johnny Joints have become the defacto standard for this format. Other try to emulate them but they do not compare.
1. Currie Johnny Joint is the gold standard of link joint in the USA.
2. Double Aluminum Adjustable Arms in a round bar configuration have less area to get hung up on and hex in the rocks is easy to spin loose.
3. Wrench flats and hex configurations lead to thread problem due to over tightening with them so we do not include them.
4. The best selling Aluminum Control arm in the Jeep TJ/LJ market.
5. Best warranty available
6. New Low price.
Get yours now!
http://shop.savvyoffroad.com/category.sc?categoryId=24
SAVVY OFF ROAD - Overall Winner of the King of the Hammers Everyman Challenge FOUR years in a row!
Email me for the fastest response: gman@savvyoffroad.com
Like us on Facebook FACEBOOK.COM/SAVVYOFFROAD
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee Lifetime Guarantee - See Here
http://www.savvyoffroad.com
Unlimited Black Hole - The Ultimate LJ
Savvy Spartan 2004 LJ
2014 JKU Test Mule
Three years in a row! KOH Mod Killer Build
2003 TJ Project Unrolled
2003 TJ Project Click Here
Savvy is offline   Reply With Quote Quick reply to this message
Unread 12-12-2013, 07:44 AM   #2
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Thank you for the orders.
I was looking at a JK with less than 4,000 miles on it and it had another vendors arms on it. The joints were already clunking and the welds on the just plain sucked. You'll never get that with these arms and should by some miracle do. We will gladly send a replacement.
2014 JKU Test Mule
Unread 01-01-2014, 11:30 AM   #3
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
The best out there with the best warranty.
2014 JKU Test Mule
Unread 08-18-2014, 09:36 PM   #4
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Get yours now. Lifetime warranty!
2014 JKU Test Mule
Unread 08-29-2014, 09:59 AM   #5
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Thank you for your orders!
In stock and shipping! Get the original aluminum TJ double adjustable arms with Johnny Joints. No other compares!
2014 JKU Test Mule
Unread 09-23-2014, 06:22 AM   #6
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
2014 JKU Test Mule
Unread 09-28-2014, 01:40 PM   #7
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Lifetime Warranty!
2014 JKU Test Mule
Unread 10-01-2014, 08:41 AM   #8
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
In stock and ready to ship!
2014 JKU Test Mule
Unread 10-08-2014, 11:18 PM   #9
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Thanks for your orders!
2014 JKU Test Mule
Unread 10-09-2014, 09:30 PM   #10
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Ready to ship!
2014 JKU Test Mule
Unread 10-12-2014, 04:50 PM   #11
SpeedJeep
SpeedJeep's Avatar
I'm interested in these. Can I ask why the wrench flats are no longer present?
With sufficient thrust, pigs fly just fine.
SpeedJeep is online now   Reply With Quote Quick reply to this message
Unread 10-14-2014, 07:28 AM   #12
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Couple of reasons. Since we have a lot of first time installers we had a couple of issues with them. First when tighten the jam nuts and JJ's it is not recommended as the JJ's can be out of synch (not aligned correct) causing them to loosen up when the suspension articulates. This will cause link to fail prematurely.
Second, the flats were used to adjust the suspension (never recommended.) What happens is by adjust the link with the flat you can put the suspension into a bind and really mess the threads up. A little at a time on both sides by hand is recommended.
The correct way to tighten the jam nuts on a double adjustable is to tighten each jam nut snug until the JJ binds in the control brackets (both should be facing the same direction.) Once the JJ's are facing the same direction go ape (tighten as tight as you can) on the jam nuts not need for a wrench flat as the joints are now perfectly aligned and will not loosen up when articulated.
2014 JKU Test Mule
Unread 11-08-2014, 11:03 PM   #13
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
2014 JKU Test Mule
Unread 12-03-2014, 08:33 PM   #14
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Still the best! Prices are going up January 1st so get yours now!
2014 JKU Test Mule
Unread 12-08-2014, 07:50 PM   #15
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Thank you! Get yours for Xmas now.
2014 JKU Test Mule
