SALE PRICING, Specials, Huge Savings Alloy USA and Posi-Lok Cable Axle Disconnect Kit - JeepForum.com
post #1 of 21 Old 02-01-2012, 04:20 PM Thread Starter
Baseline 4x4
Baseline 4x4's Avatar
1979 CJ5
The Alloy USA® Differential Cable Lock Kit is a permanent replacement for the failure prone OE vacuum disconnect system. The kit allows you to engage and lock the front axle from inside the cab. A 1” pull of the cable ensures you will have four wheel drive when you need it for as long as the transfer case is engaged. The Differential Cable Lock Kit is more cost effective and easier to install than a locker or posi-trac system. Backed by a three year warranty.
450920 - Alloy USA Differential Cable Lock Kit, For 3-In To 6-In Lift, with Front D30 Axle, Jeep Wrangler YJ 1987-1995, Cherokee XJ 1984-1991
450900 - Alloy USA Differential Cable Lock Kit, with Front D30 Axle, Jeep Wrangler YJ 1987-1995, Cherokee XJ 1984-1991
450100 - Alloy USA Shift Fork, Cast Iron, For Use W/ Alloy USA or Posi Lok Differential Cable Lock Kit, Jeep W/ Front Dana 30 Wrangler YJ 87-95, Cherokee XJ 84-91
The 4x4 Posi-Lok System™ will fit the following applications:
1987 to 1995 Jeep® YJ Wrangler the Dana 30 vacuum actuated front axle
1987 to 1995 Jeep® XJ Cherokee the Dana 30 vacuum actuated front axle
The 4x4 Posi-Lok System™ is a permanent replacement for both the original equipment vacuum and electric axle engagement systems
The installation of this kit gives you direct control, of your 4 wheel drive system, from inside the cab
A one inch pull of the cable ensures you will have four wheel drive when you need it
Simple and easy installation
Note: This system is not a posi track or locker system
PSL920 - 4x4 Posi-Lok Vacuum Actuator Eliminator Kit, 3" To 6" Of Lift
PSL900 - 4x4 Posi-Lok Vacuum Actuator Eliminator Kit
PSL100 - 4x4 Posi-Lok Dana 30 Front Axle With Disconnect, Cast Iron Shift Fork
Baseline 4x4 Outfitters
Baseline 4x4 is offline
post #2 of 21 Old 02-09-2012, 05:05 PM Thread Starter
Baseline 4x4
1979 CJ5
Cable lock kits are great to be sure your disconnect axle is engaged.
post #3 of 21 Old 02-11-2012, 11:16 AM Thread Starter
Baseline 4x4
1979 CJ5
Congratulations to Erik Miller, winner of the 2012 Griffin King of the Hammers
post #4 of 21 Old 02-28-2012, 08:06 PM Thread Starter
Baseline 4x4
1979 CJ5
Great pricing on these kits. Instock and ready to ship.
post #5 of 21 Old 05-05-2012, 08:22 AM Thread Starter
Baseline 4x4
1979 CJ5
post #6 of 21 Old 07-05-2012, 07:03 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your kit at www.baseline4x4.com
post #7 of 21 Old 10-12-2012, 07:11 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Jeep Wrangler a Cable Lock kit to eliminate the faulty factory vacuum system from Baseline 4x4 Outfitters.
post #8 of 21 Old 01-22-2013, 10:57 AM Thread Starter
Baseline 4x4
1979 CJ5
Instock and ready to ship from Baseline 4x4 Outfitters
post #9 of 21 Old 01-31-2013, 10:37 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your axle disconnect kit for your Jeep Wrangler at www.baseline4x4.com
post #10 of 21 Old 02-06-2013, 08:57 AM Thread Starter
Baseline 4x4
1979 CJ5
Order yours today at Baseline 4x4 Outfitters!
post #11 of 21 Old 03-13-2013, 01:41 PM Thread Starter
Baseline 4x4
1979 CJ5
Get your Posi Lok Cable Kit at www.baseline4x4.com. Great prices.
post #12 of 21 Old 04-08-2013, 02:22 PM Thread Starter
Baseline 4x4
1979 CJ5
Get your Posi Lok Cable engagement system at www.baseline4x4.com. Great prices and they are instock!
post #13 of 21 Old 10-16-2013, 09:57 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Posi-Lok Cable Kit at www.baseline4x4.com
post #14 of 21 Old 10-29-2013, 07:52 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Jeep Posi-Lok Cable Kit today at www.baseline4x4.com
post #15 of 21 Old 09-05-2014, 09:22 PM Thread Starter
Baseline 4x4
1979 CJ5
Get your Posi Lock Cable Kit today at www.baseline4x4.com
Alloy USA and Posi-Lok Cable Axle Disconnect Kits Dana 30 Front Axles Baseline 4x4 Vendor Display 55 08-07-2016 07:31 AM
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com SALE PRICING Baseline 4x4 Vendor Display 173 05-11-2015 06:48 AM
You may not post new threads
