Safety Thimble Fairleads - JeepForum.com
post #1 of 1 Old 11-26-2014, 06:18 PM Thread Starter
LVLJ05
Safety Thimble Fairlead designed specifically for use with the “Original” Safety Thimble 2
TRE (Tactical Recovery Equipment) has designed fairleads to go along with their products, specifically the Safety Thimble 2 and the Safety Thimble 3. TRE currently offers several different designs of Aluminum Hawse fairleads so that you can choose the one that fits your needs depending on the equipment that you currently have installed.
The Safety Thimble Fairlead is designed for use with the Safety Thimble 2. It allows the Safety Thimble 2 to be placed in an upright position on the fairlead. By having the Safety Thimble in an upright position, this keeps the Safety Thimble from being the front-most part of your jeep or off road vehicle. This is especially good for rock crawlers. Now you do not have to worry about hitting your Safety Thimble on a rock or ledge that you are about to climb.
TRE Hawse Fairlead Features:
Precision machined from 6061 Aluminum.
Anodized using a 2 step Electrolytic process during anodizing to help resist fading. Currently they are only anodized in Black, since black is the only color found to resist fading the most.
The curvature of the fairlead openings are designed to cause the least resistance to abrasion to your synthetic winch rope, even while under load.
Includes all Stainless Steel hardware needed for installation
Made in the USA
The TRE Aluminum Hawse Fairleads are designed to help protect your Safety Thimble as well as your synthetic winch rope.
* For use with synthetic winch rope only (Steel cable will damage fairleads)
Read more about the New Safety Thimble Fairleads Here
or
Purchase a Safety Thimble Fairlead Here
LVLJ05 is offline
4lowparts.com , fairlead , safety thimble , winch accessories , winch rope
You may not post new threads
