Rugged Ridge WINCH SALE 8500 & 10500 Cable and Synthetic with Warranty - JeepForum.com
post #1 of 9 Old 08-01-2011, 08:40 PM Thread Starter
Baseline 4x4
Baseline 4x4's Avatar
1979 CJ5
Durable. Tough. Affordable. The Heavy Duty 8500 LB Winch from Rugged Ridge is everything you could want in a winch. It is driven by a durable 5.5 HP Series Wound motor for long life and extra pulling power. A tough 3 Stage Planetary Gear box with a 172.8:1 gear ratio delivers power and reliability on each and every pull. The Heavy Duty 8500 LB Winch has more power and exclusive features than any other winch in its price range: Stainless Steel Hardware- All the exterior winch body screws and bolts are Stainless steel to prevent rust and provide a long life. All Rugged Ridge steel cable style Winches include off road light mount roller fairleads allowing for the easy mount of two off road lights! Special Solenoid mounting brackets allow for multiple solenoid mounting points and the ability to “tilt” the Solenoid for ease of use. This “tilt” feature ensures that each Rugged Ridge winch can be used with almost all off road bumpers and over riders! Limited 2 year warranty against manufacturing defects (1 Year on electrical). Each winch has been independently tested to ensure they meet or exceed all specifications.
Heavy Duty 8,500 LB Winch Features & Specifications
• Durable 5.5 HP Series Wound motor for long life and extra pulling power
• Tough 3 Stage Planetary Gear box with a 172.8:1 gear ratio
• Includes 94’ of 5/16” diameter wre rope and latched hook
• Automatic load holding brake system (in the drum brake system)
• Exclusive light mount roller fairlead included- allows for easy no-drill mounting of up to 2 off road lights!
• Tough stainless hardware on the body of the winch to eliminate rust
• Each winch includes a durable 12’ all weather cable remote.
Fits:
10" x 4.5" Standard Winch Plates
15100.01 - Rugged Ridge Heavy Duty 8.5 XHD 8,500 LB Off Road Winch
Lightweight. Durable. Tough. Affordable. The Performance 8500 LB Winch from Rugged Ridge is everything you could want in a competition winch. It is driven by a durable 5.5 HP Series Wound motor for long life and extra pulling power. A tough 3 Stage Planetary Gear box with a 172.8:1 gear ratio delivers power and reliability on each and every pull. The Performance 8500 LB Winch has more power and exclusive features than any other winch in its price range: Stainless Steel Hardware- All the exterior winch body screws and bolts are Stainless steel to prevent rust and provide a long life. All Rugged Ridge synthetic rope style Winches include hawse fairleads. Special Solenoid mounting brackets allow for multiple solenoid mounting points and the ability to “tilt” the Solenoid for ease of use. This “tilt” feature ensures that each Rugged Ridge winch can be used with almost all off road bumpers and over riders! Limited 2 year warranty against manufacturing defects (1 Year on electrical). Each winch has been independently tested to ensure they meet or exceed all specifications.
Rugged Ridge Heavy Duty 8,500 LB Winch Features & Specifications
• Includes 100’ of 11/32” diameter synthetic rope and latched hook
• Constructed with Dyneema SK-75 from the Netherlands.
• 12-strand braid rope with a breaking force of 16,550lbs is lighter and stronger than steel
• Includes hawse fairlead.
Fits:
15100.02 - Rugged Ridge Heavy Duty 8.5 XHD 8,500 LB Off Road Winch, Prewound with Synthetic Rope
Durable. Tough. Affordable. The Heavy Duty 10500 LB Winch from Rugged Ridge is everything you could want in a winch. It is driven by a durable 6.6 HP Series Wound motor for long life and extra pulling power. A tough 3 Stage Planetary Gear box with a 218:1 gear ratio delivers power and reliability on each and every pull. The Heavy Duty 10500 LB Winch has more power and exclusive features than any other winch in its price range: Stainless Steel Hardware- All the exterior winch body screws and bolts are Stainless steel to prevent rust and provide a long life. All Rugged Ridge steel cable style Winches include off road light mount roller fairleads allowing for the easy mount of two off road lights! Special Solenoid mounting brackets allow for multiple solenoid mounting points and the ability to “tilt” the Solenoid for ease of use. This “tilt” feature ensures that each Rugged Ridge winch can be used with almost all off road bumpers and over riders! Limited 2 year warranty against manufacturing defects (1 Year on electrical). Each winch has been independently tested to ensure they meet or exceed all specifications.
Heavy Duty 10,500 LB Winch Features & Specifications
• Durable 6.6 HP Series Wound motor for long life and extra pulling power
• Tough 3 Stage Planetary Gear box with a 218:1 gear ratio
• Includes 94’ of 23/64” diameter wire rope and latched hook
• mounting of up to 2 off road lights!
Fits:
15100.10 - Rugged Ridge Heavy Duty 10.5 XHD 10,500 LB Off Road Winch
Lightweight. Durable. Tough. Affordable. The Performance 10500 LB Winch from Rugged Ridge is everything you could want in a competition winch. It is driven by a durable 6.6 HP Series Wound motor for long life and extra pulling power. A tough 3 Stage Planetary Gear box with a 218:1 gear ratio delivers power and reliability on each and every pull. The Performance 10500 LB Winch has more power and exclusive features than any other winch in its price range: Stainless Steel Hardware- All the exterior winch body screws and bolts are Stainless steel to prevent rust and provide a long life. All Rugged Ridge synthetic rope style Winches include hawse fairleads. Special Solenoid mounting brackets allow for multiple solenoid mounting points and the ability to “tilt” the Solenoid for ease of use. This “tilt” feature ensures that each Rugged Ridge winch can be used with almost all off road bumpers and over riders! Limited 2 year warranty against manufacturing defects (1 Year on electrical). Each winch has been independently tested to ensure they meet or exceed all specifications.
Rugged Ridge Heavy Duty 10,500 LB Winch Features & Specifications
• Includes 94’ of 3/8” diameter synthetic rope and latched hook
• 12-strand braid rope with a breaking force of 19,310lbs is lighter and stronger than steel
Fits:
15100.11 - Rugged Ridge Heavy Duty 10.5 XHD 10,500 LB Off Road Winch, Prewound with Synthetic Rope
These also fit great with the Rugged Ridge XHD Front Bumpers.
Baseline 4x4 Outfitters
Baseline 4x4 is offline
post #2 of 9 Old 09-01-2011, 07:23 PM Thread Starter
Baseline 4x4
1979 CJ5
Up to $50.00 rebate on Rugged Ridge Winches. Contact us for a great quote
post #3 of 9 Old 09-28-2011, 11:51 AM Thread Starter
Baseline 4x4
1979 CJ5
post #4 of 9 Old 10-21-2011, 01:04 PM Thread Starter
Baseline 4x4
1979 CJ5
Rugged Ridge provides a three year warranty on all of their winches. Cash rebates are available on all purchases over $200 of Rugged Ridge or Alloy USA products.
post #5 of 9 Old 10-29-2011, 09:27 AM Thread Starter
Baseline 4x4
1979 CJ5
post #6 of 9 Old 11-17-2011, 02:01 PM Thread Starter
Baseline 4x4
1979 CJ5
This is an excellent winch that comes with a three year warranty. Cash back rebates up to $50 are available on these winches through the end of the year.
post #7 of 9 Old 11-28-2011, 02:00 PM Thread Starter
Baseline 4x4
1979 CJ5
Offroad Recovery Winches from Rugged Ridge come with a 3 year warranty and are eligible for cash back rebates.
post #8 of 9 Old 11-30-2011, 11:44 AM Thread Starter
Baseline 4x4
1979 CJ5
Contact Baseline 4x4 Outfitters for a quote on your winch.
post #9 of 9 Old 12-02-2011, 07:06 AM Thread Starter
Baseline 4x4
1979 CJ5
These Rugged Ridge winches are in stock and can be processed for immediate shipment. Contact Baseline 4x4 Outfitters to order yours today.
Rugged Ridge Floor Liners - On Sale! Morris4x4Center Vendor Display 3 03-05-2009 08:05 AM
You may not post new threads
