Rugged Ridge JK HALF DOORS $630 SHIPPED!!! THROUGH APRIL ONLY @ ROCKRIDGE 4WD! - JeepForum.com
post #1 of 1 Old 04-24-2012, 04:11 PM Thread Starter
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
RUGGED RIDGE JK HALF DOORS
$630 PER PAIR!!!!
Savings of $289.92 PER PAIR!!!
JK Half Door
Looking for an economical way to replace your factory full steel doors with a set of half doors? Rugged Ridge Half Doors help keep the elements out while maintaining that open-air experience. The Half Doors are constructed from paintable, impact resistant, thermoplastic outer door skins mounted to rigid powder coated internal steel doorframes. The Half Doors interchange easily with the factory steel doors and require no body modification for installation. They feature lockable door handles, an internal storage pouch, waterproof seals, OE style hinges, and mirror mounts. The Half Doors are also available with optional upper soft doors.
Features and Benefits
•Get the open-air fun and factory look for a lot less money. Finally the half door solution Jeep owners have been waiting for!
•Impact resistant thermoplastic black ABS material with enhanced UV protection.
• Matte finish is easily paintable for custom match factory look.
•Specially reinforced internal steel frame provides strength and is powder coated to resist corrosion.
•The interior of our new half doors were not forgotten about in development. The textured inner ABS panels provide a finished look and feature a grab handle and molded storage pocket.
•Lightweight half doors provide added convenience and utility with improved visibility on the trails.
•Each door has a weather tight seal to keep out moisture and reduce wind noise.
•OE Style Hinges provide a factor y look and are designed to last.
•Durable and lockable paddle handle.
•Matching soft upper doors available for all season protection from the weather.
•Designed to work with your original mirror or for added convenience permanently install a pair of Rugged Ridge replacement mirrors.
•Adjustable nylon door strap allows you to control and adjust how far the door opens.
•Attaches to factory hinge and door latch locations–easy no-drill install.
•Front pairs fit 2-door and 4-door Fronts, Rear pairs fit 4-door Rears.
---->CLICK HERE FOR FRONT DOORS
---->CLICK HERE FOR REAR DOORS
THESE PRICES ARE ONLY AVAILABLE ONLINE AND INCLUDE FREE SHIPPING!!! THIS IS A Savings of $289.92 PER PAIR!!!
ON TOP OF THAT.... IF YOU BUY 2 PAIR, YOU WILL GET AN ADDITIONAL $100 MAIL IN REBATE!
I HAVE SET ALL PRICING UP ONLINE, THERE IS NOTHING ELSE TO DO EXCEPT ORDER AT YOUR LEISURE! THIS SALE WILL ONLY BE GOOD THROUGH APRIL 30TH!
JEFF
SALES@ROCKRIDGE4WD.COM
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
door , half doors , wrangler jk wrangler
Rugged Ridge Half Door Kits at Baseline 4x4 - As Low as $624.95 Limited Qtys Baseline 4x4 Vendor Display 4 02-22-2013 09:16 PM
Rugged Ridge WINCH 8500 & 10500 Cable and Synthetic with Warranty $279.95 shipped Baseline 4x4 Vendor Display 20 06-24-2012 11:48 AM
You may not post new threads
