Ruffstuff XJ Unirail Channel Reinforcement.... - JeepForum.com
post #1 of 89 Old 08-08-2012, 11:20 AM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
These have been a long time coming but were well worth the wait! Perfect for a Crawler or Jeepspeed, our version of the Cherokee Unirail Reinforcement plates.
They are certainly as well made as any of the rest but have some very definate improvements over them also. First off they are 3/16" thick, I tried them in 10 gauge but they just felt lite. Then, where the others stop the Cap at the floor creating a very long stress riser on the very weak floorboards, ours continue 1" onto the floor itself spreading out the load further and increasing the lifespan of the body. Another of the unique ways these are made is the front and rear risers following the Unirail into the wheelwells, the rear dosen't need too much but the front goes up 9" into the front fender at the angle of the rail after it turns into the well towards the motor.
When you install these is the perfect time to create your own longarm kit and we have the brackets for it! If you are sticking with stock either cutoff the leading 9" or remove and replace your link bracket after you install the rails. The last thing these do that others have chosen to ignore is to make adding a skidplate easy.
These come built in with 4 additional threaded holes for skid attachment! The holes are there and the weldable nuts come with it but if you don't want them use it as a plug weld hole, to use the nuts you will use a 3/4" hole saw to fit the nut into the existing channel.
These are shipped to you flat and very easy to install, first you weld the flat area around the crossmember and then use a jack to custom fit the bends, it is extremely easy to do!
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #2 of 89 Old 11-30-2012, 10:01 AM Thread Starter
Dan Fredrickson
Vendor
Ready to take your XJ to a new level?
Dan Fredrickson
post #3 of 89 Old 12-20-2012, 11:15 AM Thread Starter
Dan Fredrickson
Vendor
Add the strength your XJ needs!
Dan Fredrickson
post #4 of 89 Old 01-28-2013, 10:49 AM Thread Starter
Dan Fredrickson
Vendor
Give it the strength it needs!
Dan Fredrickson
post #5 of 89 Old 05-13-2013, 02:25 PM Thread Starter
Dan Fredrickson
Vendor
I am posting this here because Jeepforum cannot get it together enough to fix my account and I don't want you guys to miss this sale entirely. I first posted this Friday morning on 66 other sites but this one just doesn't care to fix something I paid for!
This is for those of you that were left home this weekend. That’s right, all you Mother’s need a push to get it in gear and this should be enough to do the trick! For the Mothers day weekend only, starting NOW until Monday at 6PM (PST) everything is 20% off. Plug in MOTHER as the discount code to get these prices
We haven’t had stock levels this high in 6 years so we are ready for you and with 700 parts we are only out of stock on 4 of them thanks to todays Heim delivery! Get on it, times’ flying by…
And while you're at it sign up for our mailing list so you don't miss these offers in the future!
Off-Road Fabrication Parts - RuffStuff Specialties
Dan Fredrickson
post #6 of 89 Old 05-22-2013, 08:33 AM Thread Starter
Dan Fredrickson
Vendor
Beef up your unibody!
Dan Fredrickson
post #7 of 89 Old 06-03-2013, 02:06 PM Thread Starter
Dan Fredrickson
Vendor
Take your XJ to the next level!
Dan Fredrickson
post #8 of 89 Old 06-11-2013, 04:13 PM Thread Starter
Dan Fredrickson
Vendor
Give your XJ the strength it needs!
Dan Fredrickson
post #9 of 89 Old 07-01-2013, 10:46 AM Thread Starter
Dan Fredrickson
Vendor
Reinforce your frame to keep your mind at ease!
Dan Fredrickson
post #10 of 89 Old 07-16-2013, 07:16 AM Thread Starter
Dan Fredrickson
Vendor
The extra beef really does help!
Dan Fredrickson
post #11 of 89 Old 07-24-2013, 07:53 AM Thread Starter
Dan Fredrickson
Vendor
Midweek bump!
Dan Fredrickson
post #12 of 89 Old 08-13-2013, 11:20 AM Thread Starter
Dan Fredrickson
Vendor
A XJ can be strong, but only by adding these!
Dan Fredrickson
post #13 of 89 Old 08-22-2013, 08:22 AM Thread Starter
Dan Fredrickson
Vendor
Ready to step your game up?
Dan Fredrickson
post #14 of 89 Old 09-04-2013, 07:51 AM Thread Starter
Dan Fredrickson
Vendor
This is what you need!
Dan Fredrickson
post #15 of 89 Old 09-09-2013, 08:58 AM Thread Starter
Dan Fredrickson
Vendor
Reinforcing your XJ is a smart choice!
Dan Fredrickson
Steering and more from Ruffstuff! Dan Fredrickson Vendor Display 375 09-07-2017 09:00 AM
Ruffstuff 3 Link Kit! Dan Fredrickson Vendor Display 59 11-05-2014 11:21 AM
DOM Tube now available at Ruffstuff! Dan Fredrickson Vendor Display 51 07-07-2014 09:18 AM
HID's from Ruffstuff! Dan Fredrickson Vendor Display 21 10-02-2013 09:28 AM
You may not post new threads
