The Ruffstuff Heim Joint Revolution Continues! - Page 5 - JeepForum.com
post #61 of 137 Old 11-25-2011, 02:38 PM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
Originally Posted by MountainMan864 View Post
not sure on the width. I am very newbie on this knowledge. The shop said I needed to replace the frameside joint. When I dry steering test it. It moves around in the ball thing.
Measure the width of the socket it needs to fit into...
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #62 of 137 Old 11-25-2011, 02:44 PM
MountainMan864
Yeah.
MountainMan864 is offline
post #63 of 137 Old 11-25-2011, 02:58 PM
MountainMan864
Like the size of the socket the hex head it will fit into?
post #64 of 137 Old 11-25-2011, 03:05 PM Thread Starter
Dan Fredrickson
Vendor
No, the end of the heim where the bolt goes through, how wide is the ID of that?
Dan Fredrickson
post #65 of 137 Old 11-25-2011, 03:45 PM
MountainMan864
Oh ok sorry. Ill take it apart soon and holla back atcha.
post #66 of 137 Old 11-26-2011, 08:33 AM Thread Starter
Dan Fredrickson
Vendor
Its time to make the doughnuts! We are open today but I am going to breakfast first! Its only 6:30 here...
Dan Fredrickson
post #67 of 137 Old 12-04-2011, 01:25 PM Thread Starter
Dan Fredrickson
Vendor
Sunday morning! I slept in but its time to get to work getting the weekends orders packed!
Dan Fredrickson
post #68 of 137 Old 12-04-2011, 06:29 PM
TURBevO8
I like the idea of this (link below), it is cleaner than using 2 separate parts. I may need some for my drag link. I am just curious what you mean by "unresolved joint" causing stress. When used in a single shear situation, which is what these are for I assume, the joint you speak of would have no load or stress associated with it. It would be like stacking a few flat washers on top of each other. Same type of joint. Once the bolt/nut is torqued the proof load should be what it is for the rated bolt of that size and the only shear the bolt would see would be the shear plane at the steering knuckle. Is this correct? Not busting balls, just trying to understand as I was searching for "heim steering parts" and came across this thread and trying to figure out what I need. Thanks!
http://www.ruffstuffspecialties.com/catalog/merchant.mvc?Screen=PROD&Store_Code=ruffstuff&Product_Code=34TO58SAFE&Category_Code=
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline
post #69 of 137 Old 12-04-2011, 07:19 PM Thread Starter
Dan Fredrickson
Vendor
No problem, the gap between a standard safety washer and the High misalignment can allow flex on the bolt retaining them. Eliminating that gap eliminates any possible issue and eliminates the requirement of having to buy the seperate piece.
Sometimes it is better to simply think it ends up costing less this way.
Dan Fredrickson
post #70 of 137 Old 12-04-2011, 07:44 PM
TURBevO8
I still don't see how the bolt can flex if you have 2 flat surfaces in contact and the bolt/nut combo is torqued properly. There should be enough tension in the bolt to hold that joint together such that flex is not possible. But yeah I like the idea of a safety washer and misalign in combo. Cheaper and cleaner. Good idea. So here is my question, if I need a pair of these where the drag link bolts to the steering knuckle and do not need a misalign for the tie rod, do you offer a sleeve for the tie rod heim to knock it down from 3/4" ID to 5/8" ID so a single 5/8" bolt can be used through the heims of the tie rod and the drag link? I guess if I need a pair of these I will run 3/4" bolt on the DS and 5/8" on the PS as the tie rod surely wont need anything other than safety washers. I guess I could by a new 5/8" heim with 7/8" threads too. Thanks!
TURBevO8 is offline
post #71 of 137 Old 12-04-2011, 08:07 PM Thread Starter
Dan Fredrickson
Vendor
In the steering kit we use a 3/4" x 5/8" heim for the Tie Rod so you do not need the misalignment. They are not on the website but we keep about 300 around for steering only. On it you would use a safety washer.
Dan Fredrickson
post #72 of 137 Old 12-05-2011, 06:20 AM
TURBevO8
I'm an idiot. I actually have 2x 3/4" heims and 2x 5/8" heims. So I will run the 5/8"s on the tie rod and the 3/4" on the drag link so that when I run 4x of your little widgets here on the drag link I can run 1x 5/8" bolt through the PS drag link and tie rod heims, 1x 5/8" bolt at the pitman, and 1x 5/8" bolt on the DS tie rod/knuckle connection. 4x total safety washers on the tie rod. Do you sell just safety washers? Would be nice to order all this from one place. Gonna order at lunch. Any JF discount or any codes I should be aware of before my online order? Thanks!
TURBevO8 is offline
post #73 of 137 Old 12-05-2011, 03:14 PM Thread Starter
Dan Fredrickson
Vendor
We have offered a discount for members for 6 years, use JPFORM as the code to get 10% off, thanks!
Dan Fredrickson
post #74 of 137 Old 12-06-2011, 06:14 AM
TURBevO8
Order placed last night. Now crossing fingers it gets from CA to PA by Sat.
TURBevO8 is offline
post #75 of 137 Old 12-06-2011, 11:25 AM Thread Starter
Dan Fredrickson
Vendor
Should be Friday if it fits in a usps box...
Dan Fredrickson
The Ruffstuff NOT Universal 4 Link Kit! Dan Fredrickson Vendor Display 271 12-13-2016 03:56 PM
You may not post new threads
