The Ruffstuff 9" Disc Brake brackets! - JeepForum.com
post #1 of 35 Old 08-07-2012, 02:17 PM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
These are made for the 11.75" Bronco 5 on 5.5" rotors and an inexpensive Chevy 1/2 or 3/4 ton caliper. You can use any of the 20 or so high performance calipers that share the 7" caliper pin spacing also but the Chevy seems more than good enough for nearly everyone.
These are 3/8" thick and wrap completely around the axle. If the were only partially around the axle they would be strong enough but welding the entire diameter helps control warp of the tube itself. They are available with for a 3.25" or 3.5" diameter tube.
These are ideal for all the aftermarket housings made nowadays but they can be equally usefull when trying to fit up that old Dodge or Jeep 5 on 5.5" axle, the bronco rotor will go on about any of them and if its the bolt pattern it will pretty much work...
Thanks for waiting.
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #2 of 35 Old 06-19-2014, 10:15 AM Thread Starter
Dan Fredrickson
Vendor
Its been awhile since I've bumped this!
Dan Fredrickson
post #3 of 35 Old 06-30-2014, 08:01 AM Thread Starter
Dan Fredrickson
Vendor
Setup your brakes the right way with RUFFSTUFF!
Dan Fredrickson
post #4 of 35 Old 08-04-2014, 08:49 AM Thread Starter
Dan Fredrickson
Vendor
Disc brakes beat drums any day!
Dan Fredrickson
post #5 of 35 Old 08-25-2014, 09:34 AM Thread Starter
Dan Fredrickson
Vendor
Extremely busy weekend, thanks for keeping us that way!
Dan Fredrickson
post #6 of 35 Old 09-03-2014, 10:56 AM Thread Starter
Dan Fredrickson
Vendor
Adding on these will only improve your offroad machine!
Dan Fredrickson
post #7 of 35 Old 09-09-2014, 09:29 AM Thread Starter
Dan Fredrickson
Vendor
Increase your stopping power!
Dan Fredrickson
post #8 of 35 Old 09-30-2014, 11:23 AM Thread Starter
Dan Fredrickson
Vendor
This will give your 9" the upper hand!
Dan Fredrickson
post #9 of 35 Old 10-27-2014, 10:36 AM Thread Starter
Dan Fredrickson
Vendor
We hope everyone had a excellent weekend!
Dan Fredrickson
post #10 of 35 Old 11-10-2014, 10:33 AM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson
post #11 of 35 Old 11-18-2014, 10:43 AM Thread Starter
Dan Fredrickson
Vendor
Ditch the drums!
Dan Fredrickson
post #12 of 35 Old 12-03-2014, 11:42 AM Thread Starter
Dan Fredrickson
Vendor
Give your 9" the advantage!
Dan Fredrickson
post #13 of 35 Old 01-12-2015, 01:39 PM Thread Starter
Dan Fredrickson
Vendor
King of the Hammers is only 2 weeks away!
Dan Fredrickson
post #14 of 35 Old 02-09-2015, 08:28 AM Thread Starter
Dan Fredrickson
Vendor
This is the first step to upgrading your braking system!
Dan Fredrickson
post #15 of 35 Old 02-21-2015, 09:39 AM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson
Ruffstuff's Monster Shock Brackets! Dan Fredrickson Vendor Display 69 09-15-2017 10:28 AM
Ruffstuff 9" & 14 bolt Pinion Guards! Dan Fredrickson Vendor Display 27 07-12-2013 11:23 AM
New Ruffstuff 9" Truss! Dan Fredrickson Vendor Display 9 08-29-2012 02:17 PM
Barnes 4WD Disc Brake Brackets Barnes4wd Vendor Display 0 11-17-2011 09:07 AM
You may not post new threads
