Ruffstuff 3 Link Kit! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Ruffstuff 3 Link Kit!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender Flares
Unread 07-12-2012, 12:27 PM   #1
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
We have here everything to create a 3 link suspension, front or rear, and not low end stuff just to be cheap either! The kit is wrapped around 6 of our 1.25" Heat & Cryo Treated Chromoly Heims with Stainless High Misalignment, Zink Plated Jam nuts, and 1.5" Tube ID Weld Bungs and another set of the same in 7/8" for the Panhard. We add our Chassis Link Brackets, a 10 degree Adjustable Axle Link Tower, a 10 degree Adjustable Frame bracket for the 3rd link, the Axle Lower Link brackets. We finish the Kit off with the Panhard setup, an Axle Offset panhard Bracket & the Frame panhard (Inside or Outside).
We do not include the tubing because you will save alot of money buying your tube locally when you add the shipping cost of the tube, 2" x .25" wall DOM weighs over 4.5lbs a foot! If you need to change anything give us a call and we can mix & match til its right for you! We do have DOM as an option but always price it locally first...
These are $573 and $23 to ship, sound fair to you?
Dan Fredrickson
www.ruffstuffspecialties.com
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline   Reply With Quote
Unread 07-23-2012, 10:56 AM   #2
Dan Fredrickson
Vendor
Remember this is not some weak bolt on kit.. This is the real deal !!
Dan Fredrickson
Unread 08-02-2012, 11:07 AM   #3
Dan Fredrickson
Vendor
Time to do it right !!
Dan Fredrickson
Unread 08-05-2012, 10:58 AM   #4
Dan Fredrickson
Vendor
Link it and never look back!
Dan Fredrickson
Unread 08-15-2012, 02:48 PM   #5
Dan Fredrickson
Vendor
When leaf springs can't get the job done. This kit will !!!
Dan Fredrickson
Unread 08-15-2012, 05:32 PM   #6
seattle_yj
seattle_yj's Avatar
does this come with install instructions. do you have any before after pics to could point me to.
seattle_yj is offline   Reply With Quote
Unread 08-20-2012, 12:17 PM   #7
Dan Fredrickson
Vendor
I'm sorry I missed this...
We have some pics but there are no instructions. Instructions would have to be regimented and this is not that kind of kit. There are many different ways this could be used.
Dan Fredrickson
Unread 08-20-2012, 05:20 PM   #8
seattle_yj
seattle_yj's Avatar
no prob. thanks for the response.
Unread 09-13-2012, 09:56 AM   #9
Dan Fredrickson
Vendor
A great way to upgrade your front suspension
Dan Fredrickson
Unread 09-19-2012, 11:23 AM   #10
Dan Fredrickson
Vendor
When its time for you to go all out we are ready!
Dan Fredrickson
Unread 10-23-2012, 08:56 AM   #11
Dan Fredrickson
Vendor
Get Ready to do away with the leaf springs!
Dan Fredrickson
Unread 10-26-2012, 09:34 AM   #12
Dan Fredrickson
Vendor
More articulation is what you want!
Dan Fredrickson
Unread 11-07-2012, 11:29 AM   #13
Dan Fredrickson
Vendor
A 3 link is the right way to go!
Dan Fredrickson
Unread 11-14-2012, 10:38 AM   #14
Dan Fredrickson
Vendor
This is not some weak bolt on kit, this is the real deal!
Dan Fredrickson
Unread 11-28-2012, 09:57 AM   #15
Dan Fredrickson
Vendor
Take your rig to the next level!
Dan Fredrickson
