Rough country shocks and dual stabilizers at rockridge4wd - JeepForum.com
post #1 of 1 Old 08-20-2013, 12:09 PM Thread Starter
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Name:  RGB 72dpi-stacked.jpg
Who says your daily driver and your weekend warrior can't be the same vehicle? Introducing The N2.0 Shock absorber: Engineered by Rough Country's Research and Development Team specifically for both on and off-road use. N2.0 shocks are nitrogen charged at 200 PSI to prevent foaming and offer a longer lifespan. Incorporating "Velocity Sensitive Valving" technology, these shocks utilize a 10-stage variable valving process that helps facilitate resistance valving incorporated in the shock according to piston rod speed. This allows for a super smooth highway ride and outstanding control in rugged off road situations from the same shock, without turning any knobs or shock removal for re-adjustment. Each shock is tested and custom tuned for its specific vehicle application. It's Chromed Hardened 9/16" Piston Rod and massive 1 3/8" Bore allow for fluid movement while providing the type of heavy duty durability needed in off-road situations.
Like Us On FACEBOOK --> www.Facebook.com/rockridge4wd
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
You may not post new threads
