Rough Country Long arm up-grade at Rockridge 4wd - JeepForum.com
post #1 of 8 Old 02-14-2013, 10:37 AM Thread Starter
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Rough Country 1993-1998 Jeep ZJ Grand Cherokee Long Arm Upgrade Kit
Description
Boasting some impressive features, the ZJ Longarm Kit is a comprehensive package including everything needed for a great suspension lift while maintaining the vehicle's crucial center of gravity. The kit includes adjustable high-clearance X-Flex upper and lower control arms with Clevite bushings, featuring rebuildable X-Flex joints with Adjustable Retainer Rings allowing you to preload bushings by compressing them prior to install. This lift kit features high-clearance components with a front y-link and rear 4-link control arm design. This promotes extreme axle flex while keeping pinion angles optimized.
System Contents
Front: Adjustable high-clearance lower control arms, adjustable upper control arms, 0.25" thick crossmember, transfer case skid plate, sway-bar quick disconnects, 3" bumpstops & hardware.
Rear: Adjustable high-clearance lower control arms, adjustable upper control arms, long arm frame brackets, track bar bracket, e-brake relocation bracket, bumpstop brackets & hardware.
Shocks: -
Manufacturers Notes
Transfer case skid plate will not fit models equipped with 249 transfer case.
Upgrade for 4" suspension kits Only.
Models equipped with CV style front driveshaft may result in driveshaft vibration. If this occurs, replacing the driveshaft, axle yoke and / or transfer case yoke will need to be performed to rid the vehicle of driveline vibration.
Exhaust will have to be cut and rerouted to make sure it is away from the moving components.
Blake
Blake@Rockridge4wd.com
www.Rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
post #2 of 8 Old 02-15-2013, 04:41 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Rough Country Long Arm Upgrade For 4" - 6" Lifts - 2007-2011 Jeep JK Wrangler - ALL Unlimited Sport Rubicon & Sahara Models
Gain the absolute best in off-road articulation and a host of impressive features with this all-inclusive package. There are no obstacles you can't tackle with our front and rear Y-link Suspension setup featuring HUGE adjustable 2" lower control arms and X-Flex Joints. This Dual Y-link Suspension setup with longer travel arms doesn't just prevent binding and rear-steer, it gives you unparalelled axle flex while keeping pinion angles optimized - letting you negotiate trails on your terms.
The JK Long Arm Kit is built to withstand the harshes of off-road mayhem. A beefy crossmember with frame strengthening brackets gives your JK new, stronger mounting points while a 1/4" thick steel skid plate keeps everything protected from off-road hazards. This kit also includes front sway-bar disconnects and stainless steel brake lines.
2007-2011 Jeep JK Wrangler (2 door)
2007-2011 Jeep JK Wrangler Unlimited (4 door)
Upgrades short arm kit to long arm.
Dual Y-link suspension setup with longer travel arms.
Prevents binding and rear-steer.
Gain unparalelled axle flex while keeping pinion angles optimized.
HD 1/4" thick skid plate protects transmission & transfer case.
Lower X-Flex control arms feature:
Massive flex joints with 2.5" diameter body and huge 1.25" threads
OEM style Clevite rubber bushings
All joints are fully rebuildable
Fully greasable
Adjustable retainer ring
Lower joints pivot up to 35 degrees
Made of 2" diameter heavy duty tubing
Front: Sway-bar disconnects, stainless steel brake lines, HD lower skid plate, X-Flex lower control arms and upper radius arms, crossmember w/frame strengthening brackets & hardware.
Rear: Stainless steel brake lines, X-Flex lower control arms and upper radius arms & hardware.
Blake
post #3 of 8 Old 02-18-2013, 12:40 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Rough Country 1984-01 Jeep XJ Cherokee Long Arm Upgrade kit for Transfer Case NP231
Rough Country 1984-01 Jeep XJ Cherokee Long Arm Upgrade kit with Transfer Case NP242
Upgrade your existing 4" or 6" Jeep XJ Cherokee suspension kit to a Long Arm kit!
Features high clearance lower control arm design.
Extreme travel long arms keep optimum alignment
and give optimum articulation.
Unbeatable value and best prices in the market!
Upgradeable with our Jeep X-tras. - Click Here -
Features our NEW X-Flex control arms:
Fully greasable
Upper joints pivot up to 20 degrees
Front: Lower high clearance arms with X-Flex Joints, upper control arms with X-Flex Joints, long arm mounting crossmember, transfer case skid plate, and hardware.
Upgrade for 4" and 6" kits Only.
Kit will Not fit models with 2.8L V-6 or diesel motors.
Kit will Not fit 87-89 models with Peugeot manual transmissions
Blake
Blake@rockridge4wd.com
post #4 of 8 Old 02-28-2013, 10:39 AM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Rough Country 1997-06 Jeep TJ Long Arm Upgrade kit
Upgrade your existing 4" or 6" Jeep TJ suspension kit to a Long Arm kit!
Fully greasable
Clevite brand OEM style rubber bushings.
Front: Lower high clearance arms with X-Flex Joints, upper control arms with X-Flex Joints, control arm mounting brackets, rubicon compressor bracket, Clevite bushings, and hardware.
Rear: Lower high clearance arms with X-Flex Jointss, upper control arms with X-Flex Joints, track bar bracket, Clevite bushings and hardware.
Does NOT fit Unlimited models
Upgrade for 2.5", 4" and 6" kits Only.
Slip Yoke Eliminator with CV Driveshaft is
recommended to avoid driveline vibration.
Rubicon models do not need SYE kit.
CV Driveshaft is still recommended.
Blake
post #5 of 8 Old 04-08-2013, 12:01 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
NO better time than now to get your Rough Country Long Arm Upgrade kits now!
Contact me to today for your quote!
Derran@rockridge4wd.com
post #6 of 8 Old 05-01-2013, 05:27 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
NEED THAT LONG ARM UPGRADE KIT FOR YOUR JEEP! NO BETTER PLACE THAN TO ORDER FROM ROCKRIDGE4WD!
post #7 of 8 Old 05-02-2013, 02:44 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Need that long arm kit! No better time than now to contact me for your quote!
post #8 of 8 Old 05-03-2013, 02:24 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
get your long arm upgrade today! Contact me for your quote!
You may not post new threads
