Rough Country Lift Kits and Parts! - Page 15 - JeepForum.com
post #211 of 747 Old 04-13-2013, 08:46 AM Thread Starter
CCOR
Vendor
Thanks,
CCOR
706-559-9609
Classic City Off Road (CCOR)
Email:
Shop: (706-559-9609)
CCOR is offline
post #212 of 747 Old 04-13-2013, 10:13 AM
VTJ
4.5 xj add a leaf to 22815
Virginia Tech '15, 04 TJ
Build: http://www.jeepforum.com/forum/f22/vtj-college-build-1501804/
VTJ is offline
post #213 of 747 Old 04-15-2013, 07:33 AM Thread Starter
CCOR
Vendor
Thanks,
CCOR
706-559-9609
Email:
CCOR is offline
post #214 of 747 Old 04-16-2013, 09:16 AM Thread Starter
CCOR
Vendor
2007-2011 Jeep JK Wrangler 4" Long Arm Suspension
Kit Contents:
Front: Lifted coil springs, adjustable track bar, sway-bar disconnects, stainless steel brake lines, HD lower skid plate, X-Flex lower control arms and upper radius arms, crossmember w/frame strengthening brackets & hardware.
Rear: Lifted coil springs, coil correction plates, track bar bracket, sway-bar links, stainless steel brake lines, X-Flex lower control arms and upper radius arms & hardware.
Shocks: (4) High Performance 2.2 series
Applicable Models:
2007-2011 Jeep JK Wrangler (2 door)
2007-2011 Jeep JK Wrangler Unlimited (4 door)
Notes:
Front and rear driveshafts are recommended to
replace the factory limited travel shafts.
Benefits:
Increased ground clearance.
Dual Y-link suspension setup with longer travel arms.
Prevents binding and rear-steer.
Gain unparalelled axle flex while keeping pinion angles optimized.
HD 1/4" thick skid plate protects transmission & transfer case.
Coil correction plates corrects the rear coil angle 10 degrees.
Coil correction plates allows the rear coil springs to function more effeciently.
Application valved Premium Performance 2.2 shocks
Lower X-Flex control arms feature:
Massive flex joints with 2.5" diameter body and huge 1.25" threads
OEM style Clevite rubber bushings
All joints are fully rebuildable
Fully greasable
Adjustable retainer ring
Lower joints pivot up to 35 degrees
Made of 2" diameter heavy duty tubing
Specs:
Part #: 786.22 - 2 door
Part #: 787.22 - 4 door
Install Time: 8 - 10 hours
Email:
CCOR is offline
post #215 of 747 Old 04-17-2013, 07:57 AM Thread Starter
CCOR
Vendor
Jeep TJ Rubicon 6" RC Long Arm kit install with a set of Fox IPF aluminum body shocks. 35"x12.50x17 Nitto Trail Grapplers, 17x9 Moto 951 wheels, Poison Spyder Full roll cage powdercoated semi gloss black.
Call 706-559-9609 to get your TJ build scheduled in! 1350 Custom CV high angle drive shaft not pictured.
TJlongarm1.jpg   TJlongarm2.jpg   TJlonarm3.jpg   TJlongarm4.jpg   TJlongarm5nocage.jpg
Email:
CCOR is offline
post #216 of 747 Old 04-18-2013, 11:32 AM Thread Starter
CCOR
Vendor
Thanks,
CCOR
706-559-9609
Email:
CCOR is offline
post #217 of 747 Old 04-18-2013, 12:52 PM
TheJareDr
1.25" body lift and 1" MML for a 98 TJ shipped to 70808? Thanks
'98 TJ, 4" BDS Suspension Lift, Bilstein 5100s, Fully Locked on 35's
TheJareDr is offline
post #218 of 747 Old 04-18-2013, 02:53 PM
sc00bz
Same shipped to 38305.
Sent from my GSIII using HeepForum
97 TJ with some stuff.
sc00bz is offline
post #219 of 747 Old 04-18-2013, 06:53 PM Thread Starter
CCOR
Vendor
Almost done! 6" long arm on 35's! Just needs the custom 1350 HD cv drive shaft installed!
Thanks,
CCOR
706-559-9609
Email:
CCOR is offline
post #220 of 747 Old 04-19-2013, 10:13 AM
tjjeep98
Originally Posted by CCOR
Thanks for the Long ARM order Fred!
Bobby
Sales Manager
CCOR
706-207-4140
You're welcome Bobby! I will be sure to post pics when's it's done!
tj 1998 4.0 Ax15 HP30 and D44 4.88s ARB
1995 XJ
/l ,[____]
l__L OlllllllOL
l----l l---l
()_) ()_)--)_)
tjjeep98 is offline
post #221 of 747 Old 04-19-2013, 07:27 PM Thread Starter
CCOR
Vendor
Sending you tracking numbers now via pm!
Bobby
Email:
CCOR is offline
post #222 of 747 Old 04-19-2013, 09:30 PM
lonnie147
92-95 YJ rollbar forsale
I was wondering if anyone has a 92-95 YJ roll Bar for sale? I am wanting one for my 88 YJ. Thanks Lonnie
lonnie147 is offline
post #223 of 747 Old 04-24-2013, 01:46 PM Thread Starter
CCOR
Vendor
I don't think you posted in the correct section seeing as we are in Ga and all used parts would be here in GA too.
Thanks,
CCOR
706-559-9609
Email:
CCOR is offline
post #224 of 747 Old 04-25-2013, 09:00 PM
029s
Received and installed my RC 4 inch long arm kit about 2 weeks ago. CCOR git it out to me fast. Just got my Treadwright 285/70R17's put on today. Here are few pics. Also sporting RC 1.5 inch wheel spacers.
029s is offline
post #225 of 747 Old 04-26-2013, 06:15 AM Thread Starter
CCOR
Vendor
Dang that looks good! I like the wheels on it too. What are you doing about the front bumper? Thanks for posting the pics as it really can help people decide what they want to do by looking at yours.
Thanks,
CCOR
706-559-9609
Email:
CCOR is offline
You may not post new threads
