Rough Country Deals at JeepHut.com - Page 40 - JeepForum.com
post #586 of 993 Old 12-25-2012, 09:07 AM
RedNeckRanger
Originally Posted by JeepHut View Post
Great Deals on all Rough Country lift kits. Installation available if your local as well.
706-692-5488
www.thejeephut.com
It's been 4 weeks now since I have notified your office of my 2 rear shocks leaking .I bought the lift kit about six months ago .I have talked to yr shop twice and still nothing done .he keeps saying he will call the factory and call me back .my wife is *****ing me out everyday about the 2012 jeep driving like crap ,that I just had to order that kit from jeephut .how about a little help guys ? Is the jeephut gonna make this right or once u sell something ,are u done ? Sorry ,but I think a month of phone calls And several pm s should of been plenty !
RedNeckRanger is offline
post #587 of 993 Old 12-25-2012, 10:18 AM Thread Starter
JeepHut
I will resend your tracking number when we reopen tomorrow and make sure it had no issues. Figured it was already there by now.
706-692-5488
JeepHut is offline
post #588 of 993 Old 12-25-2012, 04:07 PM Thread Starter
JeepHut
Originally Posted by SophomoreJeeper
Quote for
97-02 Jeep TJ 3.25" Suspension Kit (4 Cyl) [PERF641]
Jeep TJ Big Bore Steering Stabilizer [87317]
Jeep TJ Adjustable Track Bar (0-3.5") [1083]
Orange Shock Boots!!
shipped to 12603
PLEAASSEEEEE
I will get you one this evening or first thing in the morning. Thanks for the inquiry. Merry Christmas.
706-692-5488
JeepHut is offline
post #589 of 993 Old 12-25-2012, 08:17 PM Thread Starter
JeepHut
Quote for
shipped to 12603
PLEAASSEEEEE
Quote sent to you
Thank you.
706-692-5488
JeepHut is offline
post #590 of 993 Old 12-28-2012, 10:33 AM Thread Starter
JeepHut
1997 - 2006 Jeep TJ 3.25" Suspension by Rough Country
Kit Contents:
Front: 2.5" progressive rate coil springs, 0.75" poly isolater spacers, sway-bar links, and transfer case drop kit.
Rear: 2.5" progressive rate coil springs, 0.75" poly isolater spacers, sway-bar links, and track bar drop bracket.
Shocks: Includes (4) RCX Performance 2.2 series shocks.
Description:
This suspension lift is designed to give your Jeep TJ optimal on and off-road performance with up to a 33 tire. It offers a perfect balance for a daily driver that also desires great off-road performance. These ride quality and performance gains are delivered by our new progressive rate coil springs combined with our Performance 2.2 shocks.
Notes:
Must know vehicle engine size when ordering.
Benefits:
Clears up to 33" tires.
100% bolt-on installation.
Increased ground clearance.
Kit contains 4 Performance 2.2 shocks.
Levels the front with the rear of the Jeep.
Springs are progressive rate for enhanced ride
quality.
Specs:
Part #: PERF641 - PERF644
Install Time: 3 - 5 hours
Recommended Tire Size: 33x12.50
Download Instructions: View
Rough Country Recommends:
Performance steering stabilizer, OEM steering stabilizer
JeepHut is offline
post #591 of 993 Old 12-28-2012, 10:48 AM
classictruck
Quote for 1" shackles and 1.75 spacers for a 1993 jeep cherokee. Shipped to 72704.
"Knowledge speaks, but wisdom listens." Jimi Hendrix
classictruck is offline
post #592 of 993 Old 12-28-2012, 06:49 PM Thread Starter
JeepHut
quote sent
thanks for your business.
Mike
jeephut.com
706-692-5488
706-692-5488
JeepHut is offline
post #593 of 993 Old 12-30-2012, 02:50 AM
RedNeckRanger
got the shocks friday ....thanks for making this happen so quick !!!!
post #594 of 993 Old 12-30-2012, 11:12 AM Thread Starter
JeepHut
Thank you for the orders. Let us know if we can help further.
706-692-5488
JeepHut is offline
post #595 of 993 Old 12-30-2012, 04:52 PM Thread Starter
JeepHut
No problem and thank you for your business.
Give me a call on your next part or accessory and I will hook you up.
Mike
706-692-5488
JeepHut is offline
post #596 of 993 Old 12-31-2012, 05:01 PM Thread Starter
JeepHut
Benefits:
Coil correction plates corrects the rear coil angle 10 degrees.
Coil correction plates allows the rear coil springs to function more effeciently.
Application valved Performance 2.2 series shocks.
Unique coil springs for 4-door & 2-door models.
Features our NEW X-Flex control arms:
Massive flex joints with 2.5" diameter body and huge 1.25" threads
Adjustable from stock to 6" of lift
All joints are fully rebuildable
Fully greasable
Adjustable retainer ring
Upper joints pivot up to 20 degrees
Lower joints pivot up to 35 degrees
Lower control arms are made of Heavy Duty tubing
Specs:
Part #: 673X (2door)
Part #: 674X (4door)
Install Time: 4 - 5 hours
Wheel Backspacing: 4.5" - 4.75"
Recommended Tire Size: 35x12.50
Kit Notes
On Automatic equipped vehicles; due to use of an oversize driveshaft from the factory and inadequate factory clearance it may be possible for the front driveshaft to come in contact with the automatic transmission pan tearing the factory boot and rubbing on the shaft. Generally this occurs during heavy articulation when front sway bar links are disconnected and longer shocks are installed. If this is found to occur, the proper procedure would be to replace the oversize factory shaft with an aftermarket smaller diameter shaft to increase clearance between the transmission and front driveshaft. Rough Country does offer this driveshaft if needed.
706-692-5488
JeepHut is offline
post #597 of 993 Old 01-02-2013, 07:37 PM Thread Starter
JeepHut
Thanks for the orders.
706-692-5488
JeepHut is offline
post #598 of 993 Old 01-03-2013, 02:07 PM Thread Starter
JeepHut
Quote sent. Thanks for your order.
706-692-5488
JeepHut is offline
post #599 of 993 Old 01-04-2013, 01:07 PM Thread Starter
JeepHut
Pm sent. Thanks for the orders
706-692-5488
JeepHut is offline
post #600 of 993 Old 01-05-2013, 12:09 PM Thread Starter
JeepHut
Thank you for your business. All quotes sent to you.
706-692-5488
JeepHut is offline
You may not post new threads
