Rough country 3" XJ SERIES II LIFT KIT!! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Rough country 3" XJ SERIES II LIFT KIT!!
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiUSA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Ford Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip Elim
Unread 03-25-2015, 03:13 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Here's a NICE 3" lift for all you XJ guys out there! This is the Rough country XJ 3" series II kit. This is a perfect set up for the XJ looking to gain ground clearance and tire clearance to clear those oversize tires! This kit features;
LIFTED COIL SPRINGS
FIXED LOWER CONTROL ARMS
SWAY BAR BRACKETS
LIFTED FULL LEAF SPRINGS
U-BOLTS
N2.0 SHOCKS (with option to upgrade to 2.2)
HARDWARE
This all inclusive lift kit features everything you need to hit the ground running, with an exciting upgrade to our previous design. This kit now features our new Nitrogen charged N2.0 shocks with custom 10 stage variable valving. With this redesigned lift, you'll be paired up with the most versatile shocks on the market - balanced for performance on and off-road and custom tuned for this application. This lift also ships with a set of lifted front coil springs and new lifted rear leaf springs, which help level the vehicle while providing enough clearance to run up to 31-inch tires.
Contact me direct and i'll get you set up!! Joel@rockridge4wd.com
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 09:22 PM   #2
PhantomWJ
2003 WJ
How much for XJ front long arm kit shipped to 92376. SKU:*689U
I would be buying in the next 48 hours.
PhantomWJ is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 09:48 PM   #3
Rockridge4WD
Vendor
2010 JK Wrangler
Pm sent your way!
Thanks
Erin
Rockridge 4wd
Unread 04-05-2015, 10:07 PM   #4
PhantomWJ
2003 WJ
Originally Posted by Rockridge4WD View Post
Pm sent your way!
Thanks
Erin
Rockridge 4wd
Also looking for lunch box locker for C8.25, stock gears.
Unread 04-05-2015, 10:08 PM   #5
PhantomWJ
2003 WJ
Pm sent your way!
Thanks
Erin
Rockridge 4wd
ETD for LA Kit?
Unread 04-06-2015, 11:11 AM   #6
Rockridge4WD
Vendor
2010 JK Wrangler
ETD for LA Kit?
PM sent your way!
Thanks so much
Erin
ROCKRIDGE 4WD
Unread 04-11-2015, 08:31 PM   #7
PhantomWJ
2003 WJ
Price for Rough Country 4-6" lift for a 98' Z-71 (K1500) shipped?
Unread 04-12-2015, 05:03 PM   #8
Rockridge4WD
Vendor
2010 JK Wrangler
PM SENT! Thank you!
Joel
Rockridge4wd
