Roll Cage Frame Tie In's & Seat Belt Mounting Kit - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Roll Cage Frame Tie In's & Seat Belt Mounting Kit
Rough Country Lift Kits and Parts!RIGID LED Light Blowout Sale - All Sizes, All Series, all Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerrai
Unread 08-16-2010, 03:32 PM   #1
Swagoffroad
Vendor
The roll cage frame tie in's and seat belt mounting kits are sold individualy or in kit form.
Universal "A" Pillar Roll Cage Frame Tie In's
Universal design that allows you to attach your roll cage to the frame of your vehicle
Laser cut from 3/16" high strength A-572-GR 50 steel.
This is sold as a DIY cage builder kit, welding and additional fabrication skills are required for installation.
Kit contains the following items:
(2) Polyurethane bushings with .120 wall DOM tubing and internal crush sleeves for vibration dampening.
(2) 6" long pieces of 1.75" x 120 DOM notched tubing.
(2) High clearance weld on frame mounting brackets
(2) 9/16" bolts, washers & nuts.
(4) 4" x 3.5" Square base plates.
Roll Cage Frame Tie Ins & Seat Belt Mounting Kit
Jeep TJ "B" Pillar Roll Cage Plates
Fits 97-06 Jeep TJ B pillar foot plate.
(1) Driver side "B" pillar foot plate.
(1) Passenger side "B" pillar foot plate.
Universal "C" Pillar Roll Cage Frame Tie In's
Universal design that allows you to attach the rear of your roll cage to the frame of your vehicle.
(2) Weld on frame mounting brackets
(4) C pillar base plates.
Universal Jeep Seat Belt Mounting Kit
Universal design fits Jeep CJ, YJ, TJ, & LJ factory set belt assemblies.
(2) Front seat belt brackets.
(2) Rear seat belt brackets.
(4) Weld in upper seat belt mounts.
Complete Kit Jeep TJ Roll Cage Frame Tie In's & Seat Belt Mounting kit
Complete kit contains the following items:
Universal "A" Pillar Roll Cage Frame Tie In's.
Jeep TJ "B" Pillar Roll Cage Plates.
Universal "C" Pillar Roll Cage Frame Tie In's.
Universal Jeep Seat Belt Mounting Kit.
Swagoffroad.com
Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's.
Visit us on Facebook
Swagoffroad is offline   Reply With Quote Quick reply to this message
Unread 09-08-2010, 11:56 AM   #2
Swagoffroad
Vendor
All of these items are in stock and ready to ship out.
Thanks again.
Troy
Swagoffroad.com
Unread 02-25-2011, 11:35 AM   #3
Swagoffroad
Vendor
All parts are in stock ready to ship out.
Thanks Troy
Swagoffroad.com
Unread 03-22-2011, 12:07 PM   #4
Swagoffroad
Vendor
Everything listed on the website is in stock ready to ship out.
Thanks again.
Troy
Swagoffroad.com
Unread 04-18-2011, 12:38 PM   #5
little_Jeep
Anyone do a write up on this install? I have a couple questions about placement of the plates for the "A" pillar and the fact that the frame side of the TJ tub is not a flat surface. Detailed pics of an installed system are always nice..... BTW, I purchased kit for all 3 pillars..... talk about Tonka built.
Everything looks like it will fit as it should, I am just a little confused on a couple issues.
little_Jeep is offline   Reply With Quote Quick reply to this message
Unread 04-25-2011, 12:26 PM   #6
Swagoffroad
Vendor
Thanks again for the orders, and before you go out flogging your Jeep this summer be sure to tie the roll cage into the frame rails..........if you actually get a chance to use them it will be the best $80 you spent on your jeep.
In stock ready to rock.
Thanks Troy
Swagoffroad.com
Unread 04-25-2011, 12:51 PM   #7
little_Jeep
Thanks Troy
Troy.... Any response to post #5?
**EDIT**
Thank for the private e-mail Troy.... I would love to see some pics of an installed system, but I guess I'll have to take some when I'm done (GRIN). If I am real lucky, I'll find a Jeep in my Club that I can look at to make sure that I am doing the install the best that it can be. I appreciate your help and really thank you for the personal response.... [thumbsup]
Unread 05-13-2011, 11:52 AM   #8
Swagoffroad
Vendor
If your looking to tie your roll cage into your frame let us know. We have everything listed on the website in stock.
Thanks Troy
Swagoffroad.com
Unread 09-06-2011, 04:44 PM   #9
Swagoffroad
Vendor
Knocking the dust off this older forum post.
Everything listed on the website is in stock.
Thanks Troy
Swagoffroad.com
Unread 09-06-2011, 05:44 PM   #10
little_Jeep
Originally Posted by little_Jeep View Post
--snip--
Troy, I still haven't completed the frame tie in install...... kind of got side tracked on some other projects. Whenever, I do get the frame tie in's installed, I'll be sure to post up some pics.
Unread 03-26-2012, 01:36 PM   #11
Swagoffroad
Vendor
Thought I would bump this up to the top and let you all know that everything listed on our website is in stock ready to ship out today.
Thanks Troy
Swagoffroad.com
Unread 07-30-2012, 09:44 AM   #12
Swagoffroad
Vendor
If your looking for a one stop shop for your DIY roll cage accessories we have what you need.
Thanks Troy
Swagoffroad.com
Unread 07-23-2013, 08:42 PM   #13
joey48442
Seatbelt mount kit
Got a question about your universal seat belt mount... My yj seatbelt mounts are look a little thin due to rust. Down where the retractor and lap belt all tie in together. Will your kit help this? Does it tie the retractor into the frame? I'd love to some action photos...
Thanks!
Joey
joey48442 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 04:22 PM   #14
Swagoffroad
Vendor
Joey,
It sounds like you need the B pillar plates for the YJ and that is something we don't produce. If your just needed the seat belt brackets then yes our kit will work for your application.
Thanks Troy
Swagoffroad.com
