ROGUE FAB Tubing Bender with choice of 180 degree die set - only $595! - JeepForum.com
post #1 of 50 Old 09-19-2012, 01:49 PM Thread Starter
RogueFab
^CLICK on this picture, it is a link to our web page.
The Rogue Fab Tube Bender kit w/dies is only $595! (3.5/4.5 CLR only, 6.0 is an upgrade)
This bender includes the BASE, it includes a built in accurate DEGREE INDICATOR, and it includes (1) 180 degree die!
180 degree Die sets in 3.5-"4.5" CLR are $199 shipped, no sales tax, no handling fees, no sale required... this is every day!
Size range for 3.5 CLR is .5" to 1.125" (1/2" to 1 1/8")
Size range for 4.5 CLR is 1.00" to 1.75" (1" to 1 3/4")
We even have dies that bend 2 sizes at this price! Like our 3/4 and 7/8 round combo die.
Larger 180 degree Die sets in 6.00" CLR are $349-399 shipped:
Size range for 6.0 CLR is 1.00" to 2.00"
Finally there is an affordable solution to bending tube without mounting the bender the ground, buying adapter kits for hydraulic cylinders, or requiring you to rip on a 4 foot bar while you try to read a degree wheel you can’t even reach. Our kit comes with EVERYTHING you need except the air/hydraulic cylinder, which is available nearly everywhere at Harbor Freight for about $80 (without paying shipping). Our Rogue Fab Bender bends vertically to save space in your shop. It can bend the first 90 degrees without pulling any pins or using any ratchet mechanism (then you re-pin to bend more). It is portable! This tool is Made in the U.S.A. out of US made metal/materials and packaged in US made boxes. We back our rock-solid engineering with the fastest shipping and best customer service and tech support in the industry. We will ship your order in 1 business day 99% of the time. Don't take our word on the customer service, call us and see for yourself: 503-389-5413.
Our benders can keep up with your business. We offer our tube benders fully assembled and powder coated (additional cost), and with complete tooling packages and professional 1200+ lb capacity bender carts for large fabrication shops. We also have a 2HP double acting fully engineering electric/hydraulic power system that has 2 adjustable auto stops for precision manufacturing of repeat parts. We get absolutely amazing rates on LTL freight. We would be happy to get your tools palletized and delivered to your loading dock.
VIDEOS OF OUR TOOLS<--- LINK
Here is our bender on one of our Elite carts with the optional 2HP Electric Hydraulic upgrade and optional 195 degree adjustable Auto Stops (We also have a mount that attaches our VersaNotcher to our carts):
We have 30+ dies that fit this bender. There are many options to allow you to bend 4130 Chromoly, Pre-Polished stainless (including low carbon 316) without a scratch, aluminum, and of course pipe, square tube, DOM, HREW, and solid bar stock. Did you notice the chunk of 1.75 SOLID ROUND BAR bent to 90 degrees?:
Here is our tradesman set, $1649 as a weld together kit without the $80 ram, with a range of dies from 1 inch to 2 inch (1/4" sizes). That is a bender AND (5) 180 degree dies for $1649! (2.00x6.00, 1.75x6.0, 1.50x4.5, 1.25x4.5, 1.0x3.5)
Here is the $595 weld together kit (shown assembled and painted):
Rogue Fabrication - Portland OR -
Air/Hydraulic tube benders- $595 w/180 degree die sets
Universal Drill Press Reduction Kits- $119 shipped
RogueFab is offline
post #2 of 50 Old 09-24-2012, 09:26 AM Thread Starter
RogueFab
Pic below showing bent 1.75x.188 1020 DOM. If you want to build rocker guards with rock sliders, tube fenders, bumpers, or a custom cage... this machine can handle it all!
And here is a few ads that run on our web page about our bender and tools, the links work :
RogueFab is offline
post #3 of 50 Old 10-02-2012, 09:18 AM Thread Starter
RogueFab
We just finished testing of our 1.00" Square die set, and it is added to our web page. This was a customer request (several) and we responded and made it.
RogueFab is offline
post #4 of 50 Old 10-09-2012, 05:29 PM Thread Starter
RogueFab
Big change to the website this week (behind the scenes). We now have a dynamic shipping calculator. No more relying on Paypal to try to get close on shipping. Accurate UPS shipping quotes will take you 2 clicks and 5 keystrokes! We don't need you to make an account and tell us your full address, credit card number, interests and blood type to get a quote!
It's that easy:
-Add to cart
-Type in zip code
-Click continue
And the shipping is displayed.
Of course if you would rather post up your city or zip and what you want, we will be more than happy to shoot you a quote via PM too
RogueFab is offline
post #5 of 50 Old 10-10-2012, 05:21 PM
fratis
fratis's Avatar
how is this design better then a protools horizontal unit?
-insert meaningless out-of-place political diatribe-
fratis is offline
post #6 of 50 Old 10-15-2012, 04:22 PM Thread Starter
RogueFab
Sorry for the delayed response, we need to change something in our subscription settings.
If you are asking, I am guessing you have already compared the prices for a bender, a couple of die sets, a degree wheel, and a base, and a handle or hydraulic conversion kit all shipped to your zip code (compared to our bender, which comes with everything you need except the ram). This is where you will see the biggest difference; our design can be made for much less without giving up features or functions.
The common Hossfeld style horizontal bender design that nearly every manual bender uses (JD, Pro Tools, etc) is a good proven design. It is an old design, and it was intended for manual operation. Here is a quick comparison.
Hossfeld Style
Drawbacks:
  • They have to be bolted to the ground
  • They are manual (and conversions don’t typically put the ram in line with the pivots)
  • When converted to hydraulic they still need to have a custom base made or be floor mounted
  • They use dies that have a weldment at the highest stress area
  • Horizontal bending long material without a way to rotate the bender requires a MASSIVE amount of open space
  • Dies cost much more
Advantages:
  • Flexibility of die options (CLR, spacing, etc)
  • Proven over the years (why else would everyone use this design?)
Rogue Design:
Advantages:
  • They DON’t have to be bolted to the ground
  • They are manual hydraulic or air/hydraulic, or convertible to electric hydraulic!
  • No additional parts or money to convert to hydraulic, we make them that way
  • Our dies are cut from 100% billet material. No welds to weaken the material or fail.
  • Vertical bending being better is an opinion, but most people prefer it.
  • You can remove material from the machine with the clamp attached to test fit, and resume a bend without a mark on the tube!
  • Our fully machined, profile matched clamps don't leave bolt gouges in your tube
  • Our bender has a built in degree wheel, it isn't a separate accessory
  • Dies are much less expensive
Disadvantages:
  • Lack of flexibility of die options (CLR, spacing, etc)
RogueFab is offline
post #7 of 50 Old 10-19-2012, 05:17 PM Thread Starter
RogueFab
Square tube bent on our 1.0 x 4.5 square die. Wall thickness is .095 and .120.
RogueFab is offline
post #8 of 50 Old 10-19-2012, 05:27 PM
lutzke21
Video links are not working.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #9 of 50 Old 10-23-2012, 09:29 AM Thread Starter
RogueFab
Thank you. Fixed them.
RogueFab is offline
post #10 of 50 Old 11-02-2012, 10:25 AM Thread Starter
RogueFab
Chris ("Titus") built this awesome rear stinger hinged/removable tire carrier for a TJ using our bender.
This is 1.75 tube bent on our 4.5" CLR die set.
RogueFab is offline
post #11 of 50 Old 11-18-2012, 06:36 PM Thread Starter
RogueFab
Thanks for the photos and comments everyone. We added a few more photos and quotes to our 'customers' part of the we page, which has now been changed to 'reviews'.
RogueFab is offline
post #12 of 50 Old 11-25-2012, 11:40 PM Thread Starter
RogueFab
It is Cyber Monday! We are offering free shipping on all orders over $1000 and $25 off shipping on all other orders over $100. Discount is given as a refund after purchase. Kick off the online shopping season with new tools from Rogue Fabrication! Continental 48 US states only.
RogueFab is offline
post #13 of 50 Old 11-29-2012, 09:05 AM Thread Starter
RogueFab
We have new revision to the Rogue Alpha, which is shipping right now:
• 90 degree bends on 4.5” CLR dies in ONE ram cycle, no more re-pinning for 90 degree bends, including 4 degrees of over travel for springback!
• Support for dies up to 6.00” CLR
• ~5 Pounds lighter than previous versions
• Same great low price at $595 with any 4.5 CLR die set
We have these in stock and we are shipping most orders within 48 hours! Post here for a quote.
RogueFab is offline
post #14 of 50 Old 11-29-2012, 09:34 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
One of these to 65109 ?
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #15 of 50 Old 12-04-2012, 05:30 PM Thread Starter
RogueFab
Thanks for the order Scott!
RogueFab is offline
Tubing Bender Air/Hydraulic Ram Mount @ Swag Off Road Swagoffroad Vendor Display 20 06-18-2015 01:12 PM
Harbor Freight Tubing Roller Dies (14) Sizes Available @ Swag Off Road Swagoffroad Vendor Display 10 11-19-2014 08:07 AM
HF Tubing Roller Electric Drive / Bottle Jack Kit @ Swag Off Road Swagoffroad Vendor Display 2 08-24-2012 11:45 AM
You may not post new threads
