-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail light conversion kit (http://www.jeepforum.com/forum/f43/rockridge4wd-introduces-new-jeep-wrangler-jk-led-tail-light-conversion-kit-1548195/)
Rockridge4WD 07-12-2013 05:46 PM
5 Attachment(s)
JEEP WRANGLER JK *LED* TAIL LIGHT CONVERSION KIT
ROCKRIDGE 4WD Has finally developed a solution to get rid of the bulky OEM tail lights that come on all Jeep Wrangler JK's. The goal is not only about changing to a rugged new appearance but giving you a light that won't get ripped off while you are out playing on the trail! Our new COMPLETE LED Tail Light Conversion KIT allows you to remove your OEM tail light assemblies , cut the oem mounts off, drill 6 holes & bolt on the new adapter plates with stainless steel button head hardware. All this is accomplished for a fraction of the cost of other full systems that are currently on the market. The kit features (2) 16 gauge cold rolled steel adapter plates that are precision cut & formed, (12) stainless steel button head bolts with nylock nuts, (2) DOT approved 4" round flush mount LED Lights, (2) rubber grommets, (2) pig tails & (2) ULTRA bright white 7/8" diameter backup lights that feature over 140 Lumens each! This kit fits all Jeep Wrangler JK's 2007-2013 2 & 4 Door.
WE ARE THE FIRST TO MANUFACTOR THESE KITS!
bondosgto 07-12-2013 09:49 PM
To bad these don't fit the t/lj
Rockridge4WD 07-12-2013 10:12 PM
Actually we are working on that now!! So keep posted cause they are coming!!
Rockridge4WD 07-15-2013 04:49 PM
1 Attachment(s)
Go wheeling with your JK and rip the back tail lights off? Rockridge4wd has come up with a solution! Contact us now for your jk tail light conversion kit today!
Rockridge4WD 07-16-2013 04:14 PM
4 Attachment(s)
Rockridge4WD 07-17-2013 04:04 PM
3 Attachment(s)
Rockridge4WD 07-17-2013 07:22 PM
Check it all out right here --> http://www.rockridge4wd.com/ROCKRIDG...-p/rr-5002.htm
Simply use COUPON CODE "ROCK10OFF" @ checkout for 10% off your entire order over $99.99 !
Jeff
sales@rockridge4wd.com
Rockridge4WD 07-18-2013 12:01 PM
4 Attachment(s)
afbond03 07-18-2013 02:17 PM
So code basically covers your shipping..not bad not bad.
Rockridge4WD 07-18-2013 02:27 PM
That depends on the cost of the item. Its all based on percentage. If its expensive then the discount outweighs the shipping by a lot since most items are very low fixed priced shipping.
Rockridge4WD 07-19-2013 02:36 PM
3 Attachment(s)
Rockridge4WD 07-22-2013 04:10 PM
3 Attachment(s)
Rockridge4WD 07-23-2013 04:26 PM
Check out our NEW SOLUTION to the JK tail lights!! Coming soon for TJ's and YJ's.
If you guys have researched ANY LED Conversion's you will find that either you will be spending over $1000 for body armor with the cut out hole, or a bracket that sticks out just as far as the regular tail light.
Our kit includes everything that you will need to get the job done in one simple kit.
Kit includes 2 plates, Led Tail lights (either in Clear lense w/ Red Diodes or Red lense w/ Red diodes) Small but mighty reverse LED Back up lights (each back up light has a 200 lumen punch, so don't let the size fool you) and hardware. Along with step by step instructions on how to do it right.
Are you ready to purchase now? Click here or contact Derran@Rockridge4wd.com or Erin@Rockridge4wd.com
Rockridge4WD 07-25-2013 05:52 PM
4 Attachment(s)
:2thumbsup:
Rockridge4WD 07-31-2013 05:11 PM
4 Attachment(s)
:2thumbsup:
The time now is 12:43 PM.
