#1 | ||
ROCKER POD cargo steps (pictures added)
#2 |
JF Administrator, eh?
Gonna check it out ..
![]() ... and just sent you a message through your "Contact-Us" page for more info!
Hello, my name is Vance and I am a Jeepaholic. Its better to be naked with your friends, than to be clothed with your enemies #1 From street to trail, '88 YJ on 38" tires does it all well #2 Silver 2006 TJ Unlimited w/ RubiconExpress 2" lift, 32" BFG, AussieLocker, SpeedGlass windshield, custom front / rear bumpers, Warn 8,000lb winch and Airaid throttle-body spacer #3 .. and my little lady's Jeep - WildMist #4 - 1989 YJ w/ 3" body, 2" shackle and new springs - the low-rider #5 - 1998 ZJ 5.9L with every factory goodie - the LuxMobile Evironmentalists of the world, UNITE! * * White-Jeep club member #69 * * T-Max recovery - 9,000lbs of winch power! My story |
#3 |
Thanks! for checking us out
NaeKid, I recieved your inquiry and I will get back to you soon. Again thanks for looking.
#4 |
Some pictures to explain how the ROCKER PODS are mounted
These pictures show how the ROCKER PODS are attached to the vehicle and the ground clearance on a stock TJ
#5 |
Do you offer a version for people that actually use their Jeeps to 4 wheel with?
#6 |
X2, i'll take sliders that are higher than 3 inches off the ground
1999 XJ - 3" Rustys full pack HD, 31" MTR's, 4.0l, Aussie Locked Rear, Skids - Rolled :( 1997 TJ - XJ coils, 31" BFG AT, Skyjacker 7000, 2.5l 2000 WJ - Limited, V8, K&N intake, Kolak exhaust Firefighters Jeep Club |
#7 |
NeverEndingWorkInProgress
I'm sorry, but I can't see using those on a jeep with less than a 6" lift and then they should be curved and reinforced on the sides and bottom. That's just my 2.5 cnts worth.
White Jeep Club #44 98 TJ Sport see profile for mods. |
#8 |
ROCKER PODS - keep 'em coming!!
I can appreciate that people use their Jeeps in many environments. The current ROCKER POD is designed for the average trail and for the daily driver, NOT for extreme off roading or rock crawling. We are currently working on a design that would be used on more challenging trails. That product will be available by the end of the year. I do appreciate all inputs and suggestions. Keep them coming.
#9 |
I think if you had a thick bottom on them and tapered the ends they would fend off other rocks better.
#10 |
Good suggestion, I know what you mean.
If we had designed the cargo step for rock crawling or extreme off roading, I would certainly agree with you. Our new off road product will incorporate exactly what you suggested.
This Rocker Pod cargo step design is not meant for extreme trails. That said it is significantly stronger than tube steps that are typically made from less than 1/16 thick steel tube. As I have stated Rocker Pod cargo steps are not intended for rock crawling. The reason being they take away approximately 5 ½”-6 ½” of clearance between the wheels. That may sound like a lot, but compared to standard 3” tube steps that take away about 4”-5” and offer NO storage, we feel the trade off in clearance is more than worth it for the majority of Jeep and truck owners that do not use their vehicles for rock crawling or off roading. For those that enjoy hunting, fishing or camping, you will be able to carry your gear safely and securely. The Rocker Pod cargo step can be configured with a single long door that can accommodate a shotgun or rifle as well as a number of fishing rods. A small compressor or power inverter can be packed as well as supplies for camping and towing, the list is endless For those that ride on extreme trails and need every inch of trail clearance, we will have a product similar to the current Rocker Pod that will be specifically designed to take trail abuse. As mentioned it will be available at the end of the year. I am mostly a pavement and dirt runner and I don’t want to pretend to know everything about crawling or mudding fortunately our team has members that don’t believe in roads and have the attitude that the more extreme the trail, the more extreme the fun. I appreciate your comments and hope to here more. |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Cargo Nets | SafariStraps | Vendor Display | 1 | 01-07-2010 05:27 PM |
| Rocker Guards for TJ, YJ, CJ!!! | SunPerformance | Vendor Display | 52 | 12-10-2009 07:19 AM |
| New Jk 2dr Warrior Cargo Net | SafariStraps | Vendor Display | 0 | 09-26-2009 09:11 AM |
| Wild Boar Weekend Special - 25% off Bumpers & Cargo Rack package | Wild_Boar | Vendor Display | 0 | 08-22-2009 05:43 PM |
| Wild Boar Cargo Rack & Bumper 6 Day Sale | Wild_Boar | Vendor Display | 2 | 05-23-2009 05:03 AM |
The time now is 09:48 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
