RIPP Superchargers now at JeepHut - JeepForum.com
post #1 of 2 Old 11-10-2013, 05:33 PM Thread Starter
JeepHut
JeepHut's Avatar
Check them out. Until end of year use the code below to save on your supercharger.
Ripp
http://www.thejeephut.com/ripp-superchargers/
706-692-5488
JeepHut is offline
post #2 of 2 Old 11-11-2013, 07:26 PM Thread Starter
JeepHut
JeepHut's Avatar
ITS ARE NOW IN STOCK
This kit now features a state of the art and innovative Water To Air Intercooler, with built in water tank, By Pass Valve flange and air intake temp grommet. This unit will easily cool the 8psi peak in any environment. The GEN2 now features 6 larger primary injectors, plug and play map sensor and Pre-Programmed Diablo Sport Intune for re-flashing of the ECU.
Power, Drivability, and, Reliability: these three words sum up the RIPP SDS Supercharger Drive System (SDS). The RIPP SDS will deliver a smooth and linear boost curve that does not shock your engine or drive-system the way a turbocharger or roots system would. RIPP’s unique approach to product development brings together a system with the level of refinement that your Jeep has been waiting for. Pumping new life into the veins of your vehicle with every revolution! The power added will bring out the performance you lost when you added wheels and tires and then deliver more.
RIPP Superchargers are not CARB approved, please check your local laws for reference.
Features
Design features include of 6061 spun aluminum construction, with CNC design and fabrication units are then hand assembled by our in house techs to insure quality control second to none. Our shaft is mated to a custom configured mirror polished Vortech Engineering V3 Si-Trim self contained Supercharger with the Quiet option (VSQ), bringing boost in smoothly and safely and covered by a comprehensive 1 year limited warranty.
265WHP Auto TJ with a Full Stock Exhaust and Drive train
For fuel management RIPP feature plug and play Diablo Sport Predator which turns your ECU into a fully programmable fuel and timing system. The system comes with base maps designed to safety, calibrated to an engine running boost, or you can choose to bring it to a tuning facility and get the most out of your system.
All RIPP Supercharger kits come pre-programmed to give you safe and reliable HP (unless otherwise advertised) with out the hassle of going to a tuner or the worriers associated with detonation in conjunction with boost.
Tech Specs
RIPP Supercharger Drive System (SDS) 6061 Aluminum
SDS shafts use a 80k rpm heavy duty SKF bearing
SDS drive shafts are balanced to over 60k rpm and use a dual key way system.
RIPP Water to air Intercooler
Washable Air Filter
Vortech V3 Si-Trim Self Contained Supercharger (VSQ Option)
Vortech Blow Off Valve
Diablo Sport Predator *Fuel and timing controller*
RIPP *MAP Sensor* for exact ECU boost communication
Plug and Play Injectors with clips
2.75” 6061 Aluminum Piping
Four Ply silicon hose (Gloss Black)
All hardware and clamps included
Illustrated Instructions and tech tips
Extended Information
RIPP has a history of developing high-quality, street driven packages. Our SDS system continues this tradition, this product uses some of the most sought after components on the market today. To date our customers have produced impressive horse power figures, and reported over 100k miles of driving on stock internals with little to no change in gas mileage.
JeepHut is offline
You may not post new threads
