PREORDER: Truck-Lite LEDs Generation 2 Complete Systems - JeepForum.com
post #1 of 6 Old 02-07-2012, 11:42 AM Thread Starter
REBELOFFROAD
Vendor
REBELOFFROAD's Avatar
Rebels,
We've got our stocking order set for the Truck-Lite Generation 2 LEDs set - and want to give you the opportunity to jump in line before they sell out. ESTIMATED SHIP DATE: FEB 17, 2012.
These are highly anticipated and solve many issues presented by the older model Truck-Lite LED lamps.
Our system includes:
Pair of LED Truck-Lite Gen 2 headlamps
Pair of Jeep JK Harnesses
PREORDER LINK:
http://www.rebeloffroad.com/product_p/27270complete.htm
Specs:
  • When properly mounted, exceeds FMVSS-108 and CMVSS-108 requirements for low beam and high beam performance
  • Excellent option for light, medium and heavy-duty trucks, off-road vehicles, classic cars, motorcycles and more.
  • Metalized reflector optics provide a lighting experience that smooth and clean across the driving surface
  • Provides a brighter, crisper and whiter light output, closer to the color temperature of daylight, dramatically improving light projection distance and overall visibility
  • Durability and dependability of LED lighting provides a solid-state, bulb-free headlamp design that impervious to damage from shock and vibration
  • Military grade, die-cast aluminum housing and non-yellowing, polycarbonate lens offer optimum protection against damage from impact, roadside debris and other hazards
  • Electronics are sealed in epoxy to resist from damage caused by corrosion or moisture
  • Advanced circuitry protects against voltage spikes up to 600v
  • Drop-in replacement for #6014, 6015, 6016, H6024 and Par 56 headlamp designs
  • Uses standard, H4, 3-blade wiring connector
  • Equipped with Truck-Lite 3-Year Limited Warranty.
Material:
Hard-coated polycarbonate lens
eCoat aluminum housing and internal structures
Metalized Reflector
16 Gauge Wire
Light Source:
2 LED Arrays
9v-33v Multi-volt design works with both
12v and 24v systems
Designed At:
12.8v, 1.80a (low beam), 3.60 amps (high beam)
25.6v, 1.00a (low beam), 1.80 amps (high beam)
1,300 Lumens
Additional Specifications:
Operating temperature range: -40C to 50C
Overvoltage protection to 600v, w/constant output
Mechanical aim
Bond Gilmer - President / Rebel Leader
- 866 900 8841
Visit us on:
REBELOFFROAD is offline
post #2 of 6 Old 02-07-2012, 11:43 AM
97Heep
any night shots with picture exposed to the lights? These look interesting.
'97 Jeep Wrangler Sport TJ 4.25" lift 33x10.5x15 KM2's (Sold)
'04 Jeep Wrangler Rubicon TJ - She's Savvy
97Heep is offline
post #3 of 6 Old 02-07-2012, 11:55 AM
tskeen
What exactly are the pair of harnesses that come with the lights? Are these adapters? Would there be a price break for those that already have a dedicated H4 harness?
2012 Sport..auto 3.73 limited slip.Poison Spider Rocker Knockers, Daniel Stern lighting..AEV Pintlers GoodYear Duratracs 285-70-17 springs from Unlimited Rubicon. Weathertech Mats..AEV hood, kicker speakers, remote start added.
tskeen is offline
post #4 of 6 Old 02-07-2012, 12:00 PM Thread Starter
REBELOFFROAD
Vendor
The harnesses will be adapters. Yes - $26 less if you already have the harness.
- 866 900 8841
Visit us on:
post #5 of 6 Old 02-26-2012, 01:17 AM
JackTEOD
With the 2012 JK's and the computer regulated voltage to the headlights, is it recommended to go with a complete harness to eliminate the so called pulsing to flickering i keep hearing about for LEDs? I already ordered the set with the H4 to 13 adapters. I can't wait to get my hands on these!
JackTEOD is offline
post #6 of 6 Old 02-26-2012, 06:38 AM
fsSnowboard
There are some pics on the Manufacturer's thread. http://www.jeepforum.com/forum/f43/t.../#post13043236
My Build -> http://www.jeepforum.com/forum/f22/fssnowboards-2005-tj-x-1133763/
fsSnowboard is offline
You may not post new threads
