Poison Spyder JK Tramp Stamp II & License Plate Mount - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder JK Tramp Stamp II & License Plate Mount
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 06-15-2012, 02:25 PM   #1
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
Poison Spyder is proud to introduce our new JK Tramp Stamp II and JK License Plate Mount Mount, which incorporate several features often requested by our customers!
The JK Tramp Stamp II is installed using the stock tire carrier bolts (no drilling or pop-rivets like our OG Tramp Stamp). And it includes a center cut-out to allow retention and full functionality of the stock tailgate vent piece. The JK Tramp Stamp II is CNC laser cut from 1/8" aluminum plate, and is powder coated with a textured black finish. The JK Tramp Stamp II sells for $49.
NOTE: This item fits JK's with the WIDE VENT on the tailgate (vent is wider than it is tall). These are generally found on 2010 and newer JK's, however they have also been found on some 2009's. This item is not a direct fit for JK's with the TALL tailgate vent (taller than it is wide), which were typically found on 2007-2009 JK's. On Jeeps with vertical tall vent, this item may be used if the vent assembly is either removed or trimmed to fit. Regardless of your year model, we strongly advise that you visually verify which vent your JK is equipped with before ordering (will require removal of the stock spare tire mount).
The new JK License Plate Mount allows relocation of the Jeep's license plate to the center of the tailgate. It can be used with or without the JK Tramp Stamp II. The JK License Plate Mount is CNC laser cut from .063 aluminum sheet. The piece is brake-formed to provide an offset to allow full functionality of the tailgate vents, and it is powder coated with a textured black finish. It is installed using 4 of the stock tire carrier bolts. The JK License Plate Mount sells for $29.
For a complete package, we offer the JK Tramp Stamp II with License Plate Mount together, with a savings of $19 versus purchasing them separately. This JK Tramp Stamp II with License Plate Mount bundle sells for $59.
Each of these items may be purchased directly from Poison Spyder or through any of our Authorized Poison Spyder dealers!
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote Quick reply to this message
Unread 04-04-2013, 10:25 AM   #2
DTS
Vendor
DTS's Avatar
It looks like we never announced it in this thread, but FYI a while back we changed the design of the standard JK Tramp Stamp, it now uses the stock tire carrier bolts like our JKTramp Stamp II. No more drilling and riveting!
Unread 12-29-2014, 06:49 PM   #3
DTS
Vendor
DTS's Avatar
There are now versions of the Poison Spyder Tramp Stamp II and License Plate Mount designed specifically for JK's with the TALL tailgate vent. These are typically '07 to '09 models, but we have seen some discrepancies so physically check yours to confirm tall or wide vent before ordering.
JK Tramp Stamp™ II with License Plate Mount (Tall Vent)
JK Tramp Stamp™ II (Tall Vent)
JK License Plate Mount (Tall Vent)
Contact Poison Spyder at the links above or 951-849-5911, or purchase through your favorite Authorized Poison Spyder Dealer.
