Poison Spyder JK Body Mounted Tire Carrier - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder JK Body Mounted Tire Carrier
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 12-16-2014, 12:09 PM   #1
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
Poison Spyder's JK Body Mounted Tire Carrier works with the stock rear bumper or just about any aftermarket rear bumper, and can accomodate up to a 40" spare tire and accessories. The main tire carrier assembly is made of 1-1/2" DOM tubing for strength and great looks. All of the plate steel components are CNC laser cut and brake-formed from 1/8" or 3/16" steel plate. The hinge and latch assemblies are designed to address common issues inherent in similar tire carriers from other manufacturers. The tire carrier comes with mounting points to add several Roto-Pax™ fluid packs as well as a Hi-Lift™ jack.
Here's a video showing features and benefits of the tire carrier:
Here's a video of the installation process:
Or you can Download the Installation Instructions (link to PDF file)
With a 40" tire:
Threaded mount, alignment cone and wing nut tire mount:
Detail of the internal bracing that helps strengthen the tire carrier mounting, rather than just bolting it to the exterior sheet metal:
Close-up of the adjustment cam on the hinge side:
See our website (link) for all of the info about the Poison Spyder JK Body Mounted Tire Carrier, or inquire through any of our Authorized Poison Spyder Dealers!
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote Quick reply to this message
Unread 12-16-2014, 12:46 PM   #2
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
Slick. Anything similar in the works for a TJ? I'd be happy to test one for yall
EugeneTheTJ is online now   Reply With Quote Quick reply to this message
Unread 12-16-2014, 04:01 PM   #3
DTS
Vendor
DTS's Avatar
No plans for a TJ variant yet. Thanks,
Unread 01-15-2015, 12:04 PM   #4
DTS
Vendor
DTS's Avatar
Unread 01-19-2015, 06:33 PM   #5
DTS
Vendor
DTS's Avatar
We're starting to see some customer-installed photos of these JK Body Mounted Tire Carriers now...
This one's from Jeff Yurk.
And a couple more from Jeff Yurk.
Here's a shot courtesy of Allan Tilley.
Here are a couple shots of Frank Castle's Jeep, shot and sent in by Vic Perz:
Vic gives us our first shot of this tire carrier installed with Poison Spyder Crusher Corners. Here's the tuning he had to do around the hinge cutouts on the passenger side corner to get it to fit. I know a couple folks have asked to see this and I said I'd post a pic as soon as we got one. Thanks again Vic.
Ryan Coleman installed his with what appear to be AEV corners, which are similar to our Crusher Corners in the hinge area so they required the same trimming:
Unread Today, 09:13 AM   #6
Jeepforthewin
2010 JK Wrangler
I found this on the PS website today, any pictures of the carrier with a 35" tire? Seems it might look pretty small in that carrier.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline   Reply With Quote Quick reply to this message
