Poison Spyder Hood Louvers - Page 26 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder Hood Louvers
Tactical Recovery Equipment Soft Shackles!!!50% Off Sale at KrawlOff-Road.com50" LED CREE Light Bar Pair With Wiring Kit
Unread 02-21-2013, 03:47 AM   #376
JeepAddOnsChris
Vendor
I plan on putting a 20" in the exact same place on my hood... Can I see where you drilled the holes to mount?
Right beside the hood tie downs. They're around 1/2" beside them on each side.
We are currently away from the forums and unavailable for quotes. Please contact our sales team at 800-388-8637.
Visit our site
http://jeepaddons.com
Like us on Facebook
http://facebook.com/jeepaddons
JeepAddOnsChris is offline   Reply With Quote Quick reply to this message
Unread 02-21-2013, 08:21 AM   #377
Carlos14
Awesome! That looks like it works perfectly. Thanks!
[B][URL="http://www.jeepforum.com/forum/f22/teenager-dream-1378217/"]Teenager With A Dream Build[/URL][/B]
[QUOTE=Anticanman;15143112]I think you're skewing the facts. Clarity is relative. Our job is to lead people to the kingdom of heaven, not make them think they're looking at it. :D[/QUOTE]
[URL="http://www.jeepforum.com/forum/f27/poison-spyder-hood-louver-install-1463085/"][B]Poison Spyder Hood Louver Install[/B][/URL]
Carlos14 is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 10:27 AM   #378
RobSheaTJ
I'm finally pulling the trigger on this. Could you PM me a JF price for the 03-06 TJ model in bare? Thank you.
"Wha's a Jeep?" Popeye asks Professor Brainstine.
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
RobSheaTJ is offline   Reply With Quote Quick reply to this message
Unread 02-28-2013, 10:59 AM   #379
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
$129 for bare Hood Louvers. (JF price is the same as our Spyder Direct price )
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote Quick reply to this message
Unread 04-03-2013, 12:18 PM   #380
DTS
Vendor
DTS's Avatar
Unread 04-16-2013, 06:38 PM   #381
TheOtherMe
Placed my order today. I'm going to try and cut my hood like B2CARPEN did on page 18 and not cut into the support beams. It seems to me there is plenty of room on the hood for louvers without cutting into the support beams so I'm not sure why the design doesn't avoid them. But what do I know, I'm just some guy who's about to cut up my perfectly good hood.
TheOtherMe is offline   Reply With Quote Quick reply to this message
Unread 04-16-2013, 10:41 PM   #382
Carlos14
Check out the link in my signature. It should help with the install.
Unread 04-17-2013, 09:05 AM   #383
DTS
Vendor
DTS's Avatar
If you're referring to the TJ Hood Louver, the cut lines on the template we provide are designed to miss the underhood braces. I don't know if you read through the entire thread but this was a change we made early on due to customer requests.
Unread 04-19-2013, 10:56 PM   #384
TheOtherMe
Yes, I am referring to the TJ louvers. I read through this thread and noticed that the template changed for the larger cutouts, but I didn't notice if it was altered for the smaller cutouts for the forward facing louvers. One of the louver installs linked on this thread has the following picture which shows him using the template, but you can see part of the center bracing has been cut through. That is the bracing cut I was referring to. Has this been changed as well?
Unread 04-22-2013, 08:22 AM   #385
DTS
Vendor
DTS's Avatar
It looks like he used the current template. It looks like he got into the brace just slightly. If that bothers you, you can just take some careful measurements to make sure it doesn't happen when you install yours.
Unread 04-26-2013, 05:17 PM   #386
DTS
Vendor
DTS's Avatar
Poison Spyder Hood Louvers are now available for the 2013+ JK with dual windshield squirters! Click Here.
Unread 04-28-2013, 08:00 AM   #387
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
whats with the tj's and jk's changing their squirter numbers lol. you think jeep could just stick with one design
LifeProof is online now   Reply With Quote Quick reply to this message
Unread 04-28-2013, 08:24 AM   #388
SKINUM
Do these help with heat soak issues? I would think yes but curious to hear what others think.
SKINUM is offline   Reply With Quote Quick reply to this message
Unread 04-28-2013, 08:43 AM   #389
LifeProof
SEMPER FIDELIS
LifeProof's Avatar
whats heat soak and i'll let you know lol
Unread 04-28-2013, 09:01 AM   #390
SKINUM
Simple terms - a hunk of metal (or other thing) starts out at ambient temperature. It's exposed to other another temperature that warms (or cools) the surface. As time goes on, the head (or cold) evens out throughout the metal and the thing is "heat soaked". If you take away the source of the heat (or cold), the part will remain hot (or cold) for quite some time as it gives off the heat (or cold) that has "soaked" in the metal.
Sitting idle (with no air passing over the cooler) can also raise the "heat soak" causing loss of performance (or detonation), but it will reduce the "heat soak" as the car is moving with fresh (relatively) cool air passing over the system again.
The same thing happens with cooling systems. The combustion chamber temperatures can get quite high, and the coolant passing through the cylinder head carries away the heat. But when you turn off the engine, there is still a high amount of residual heat in the chamber material that has not been removed. That heat "soaks" the head (and the coolant) and makes localized hot spots - the normal coolant temperature may be 195 degrees, but that local hot spot can easily get to be 20 - 50 degrees hotter. That's why many cars have a fan that will kick on after the car is parked if it detects that the engine is too hot.
*****Took the above info from another site. The information explains heat soak in greater detail than I would*****
