Poison Spyder Hood Louvers - Page 20 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder Hood Louvers
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 05-18-2012, 11:10 AM   #286
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
Originally Posted by JCJeep97 View Post
AHHHHHHHHHHHAAAAHHHHHAHAHAAAAAAAHHHHHHHHAAAAAAAAAA A I don't believe it!!!!!
EDIT: I'll believe it when I see it
Originally Posted by B2CARPEN View Post
Dusty, is that a custom paint job on Matt's jeep? I haven't seen that color on a JK before but I like it a lot.
Yes he did the paint in flat black. Then got really meticulous on the copper/bronze accents
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote Quick reply to this message
Unread 05-18-2012, 12:19 PM   #287
RDaniel2405
RDaniel2405's Avatar
Just a quick question, Has anyone thought of, or tried using black aluminum pop rivets instead of the scrwes???
MY DAILY DRIVER BUILD http://www.jeepforum.com/forum/f22/r...-tj-x-1170452/
RDaniel2405 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2012, 03:04 PM   #288
scot68
Originally Posted by RDaniel2405 View Post
Just a quick question, Has anyone thought of, or tried using black aluminum pop rivets instead of the screws???
Thats a good question. I just ordered mine today after I confirmed it would only have the small logo. I'm going to try and have the bolt heads powder coated.
scot68 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2012, 03:23 PM   #289
RDaniel2405
I just thought that black pop rivets might give it a clean install look with out all the long screws sticking out the bottom of the hood
aDP's Ultimate Rivet would give it a clean look http://www.adprivet.com/ultimate_rivets.html And there made in the USA
Unread 05-18-2012, 09:53 PM   #290
Mayfair_Jeeper
When did it become against jeepforum ruled to, in a product thread, respectfully let the vendor know that a change in other product was preventing not only my, but multiple others from purchasing thier product? You would think this would be encouraged so they knew what the people thought?
That being said, again, if the spider is the only logo, I'll purchase in a heartbeat....anything else, they will loose my business.
2006 Jeep TJ X Modded with toys
2008 Jeep Liberty Sport Stock
1987 Cherokee 4.0 Renix...Build in Process
Mayfair_Jeeper is offline   Reply With Quote Quick reply to this message
Unread 05-20-2012, 01:09 PM   #291
cyberpyrot
Hows this for the money shot Everyone loved the louver there where at least 400 + jeeps here
cyberpyrot is offline   Reply With Quote Quick reply to this message
Unread 05-21-2012, 09:44 AM   #292
epeck87
Originally Posted by DTS View Post
Just a clarification that the initial hood louver product is specific to the '03-'06 TJ/LJ. A version for the earlier TJ's is in the works.
well its been a year and a half since that statement. wheres the kit for earlier tjs at? I want one. whats different that makes the 03-06 not fit on a 2000?
Associates Degree in automotive technology
A1-A8 ASE MASTER CERTIFIED TOYOTA MECHANIC
epeck87 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2012, 09:58 AM   #293
RDaniel2405
I could be wrong but, if you go to page 18 ( B2CARPEN ) Put the 03-06 one on a 2000 wrangler. Other posts say the only thing different is the hood on older jeep have 2 windshield washer sprayers, newer ones only have 1 in the center.
on page 10 ( 2003X ) shows a pic of converting 2 sparyers to 1 sprayer.
Unread 05-21-2012, 11:07 AM   #294
B2CARPEN
B2CARPEN's Avatar
You are correct, main difference is converting from two washer nozzles to one. The only other thing I noticed was the template had you slightly cut into the edge of the hood brace up toward the top where the two forward facing louvers are. Instead of trimming the edge of the hood brace, I moved the template 1" out from the center.
My 4.7L Stroker Build
IndyORV
B2CARPEN is offline   Reply With Quote Quick reply to this message
Unread 05-21-2012, 11:44 AM   #295
RDaniel2405
I wouldnt expect Poison Spyder to make 2 different parst just so people can use 2 washer sprayers instead of 1. All they should do is add a note to the description or in the directions. Saying that it will fit all TJ's but you will have to convert your 2 washer sprayers to a 1 sprayer setup, with a quick picture or two showing how it would look. And maybe a different template for the older model jeep. Paper directions are cheaper than a metal part. Its a jeep, how many other things have you modified just a bit to fit on your jeep...
Unread 05-21-2012, 12:08 PM   #296
scot68
Did I miss something?? Did you get grief for stating your opinion regarding the logo?
Unread 05-21-2012, 11:45 PM   #297
Mayfair_Jeeper
Yeah. All of us that stated our displeasure had our comments removed and replaced with some bogus 'wrong place' comment from the mod....
Unread 05-22-2012, 09:31 AM   #298
Diverdown87
I read where the PSC crew has just gotten a 2 squirter TJ and will be making the louvers for it. I will get one if they offer it with the Spyder logo only at first.
98 TJ 4.0L, 5spd, 4.25 Zone lift, D-locked D30/D35 w/4.56 gears, MCE GEN I Flares, 33" Trxxus ATs, Engo 10K# winch, rear disc brake conversion.
My idea of help from the man above is a sniper on the roof.
Diverdown87 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2012, 11:02 AM   #299
Mayfair_Jeeper
Its sad, but that wont be the case. See Below:
Currently the TJ Hood Louver has the Spyder only, and an old version of it at that. The JK Hood Louver has the full Poison Spyder logo. The TJ one (late model) will get the update on the next revision. The early TJ and YJ models will have the full logo when they are launched here sometime in the next couple of weeks.
Seems they are determined to drive customers away that want their product, but don't want the full logo...
Unread 05-22-2012, 11:09 AM   #300
cyberpyrot
Why do people put decals on there ride? It is to make a statment to people who do not have mods to let them know what was done. Its not like they have poisonspyder.com on it. Im fine with the logo when i was at the go topless event in galveston out of 400 + jeeps there was only one other that had a hood louver. Every one who passed by it asked where did I get it and how hard was it to install. I hope the dont become popular make my jeep stand out.
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
