Poison Spyder Hood Louvers - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder Hood Louvers
Savvy FOX IFP 4" Lift Shocks in StockOnly 2 Days left to win $3,800 Jeep Parts!Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 11-19-2010, 06:30 PM   #1
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
Poison Spyder Hood Louver Panels are available now for JK, Late TJ/LJ, Early TJ, YJ and '76-'86 CJ.
The Poison Spyder Hood Louver panel helps keep your engine running cool by promoting airflow through the engine compartment. Many factors can contribute to high under-hood temperatures, which can translate to higher engine coolant temperatures and overheating. Headers, slow speeds, flex fans, and the cramped spaces of the engine compartment can all contribute to increased heat and reduced airflow. This Hood Louver kit frees up airflow through the engine compartment, allowing hot air to escape and cooler air to be drawn in through the radiator, improving cooling of both the engine coolant and under-hood air. Rock-crawlers and slow-moving vehicles are especially susceptible, as slower speeds naturally result in reduced airflow.
In addition to improved cooling performance, Poison Spyder Hood Louvers add great looks to your Jeep! Crafted from thick gauge aluminum sheet, CNC laser-cut and precision die-stamped. Hood Louvers are fairly easy to install but do require some drilling and cutting of your hood. Stainless steel fasteners are supplied. Hood Louvers are available in bare aluminum or powder coated black.
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote Quick reply to this message
Unread 11-19-2010, 07:46 PM   #2
PlatinumNiner
How about something for an XJ!?!?
PlatinumNiner is offline   Reply With Quote Quick reply to this message
Unread 11-20-2010, 02:20 AM   #3
biggoofy
or a ZJ?
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
RIP Troy aka BigBlueZJ94
FroBot Fab FTW
[URL="http://www.mallcrawlin.com/forum/showthread.php?22776-Biggoofy-s-96-ZJ-build!-**Building-axles**"]My Build[/URL]
Need quality parts call Andy at Ironman4x4fab!!!!!
[url]http://ironman4x4fab.com/index.html[/url]
[/CENTER]
biggoofy is offline   Reply With Quote Quick reply to this message
Unread 11-23-2010, 11:35 AM   #4
DTS
Vendor
DTS's Avatar
Originally Posted by biggoofy View Post
or a ZJ?
Sorry guys at this point our product line is Wrangler & CJ focused. We have ambitions to expand into the XJ market but no timeline for that at this point.
Unread 11-23-2010, 11:37 AM   #5
DTS
Vendor
DTS's Avatar
Just a clarification that the initial hood louver product is specific to the '03-'06 TJ/LJ. A version for the earlier TJ's is in the works.
Unread 11-23-2010, 12:13 PM   #6
purplepig
purplepig's Avatar
How hard is the install?
purplepig is offline   Reply With Quote Quick reply to this message
Unread 11-23-2010, 01:55 PM   #7
DTS
Vendor
DTS's Avatar
Its not too bad. We provide a cut template for cutting the holes in the hood that will be underneath the louver panel. We recommend unbolting the hood from the Jeep and putting it on a bench or sawhorses to make the work easier. You remove the windshiled squirter, footman loop, bumpers, and the insulation pad from underneath. Then you mark using the template, and use a hole saw and cut-off wheel or body saw to make the cuts. Then align the hood louver onto the hood and drill all of the bolt holes. De-burr the bolt holes, touch up all the cut edges with paint to keep it from rusting. Then bolt the hood louver panel on. If you want to keep the insulation pad you'll need to cut the same holes in it.
Its a fairly easy process if you're familiar with tools and how to use them. But it is a somewhat long process, and patience and attention to detail will pay off in the end.
Unread 11-23-2010, 10:22 PM   #8
dcorn
I'd say no reason this wouldn't fit on an XJ. Might have to cut off the top part where the spider is, but I'm sure it would fit. I almost did this, but someone in my club has an almost identical louver and I didn't want to copy
2004 Grand Cherokee Overland
OME HD/5100s - 31" Toyo AT2
dcorn is offline   Reply With Quote Quick reply to this message
Unread 12-09-2010, 01:04 PM   #9
DTS
Vendor
DTS's Avatar
TTT for your Christmas shopping!
Don't forget our December Specials where you can get FREE SWAG when you spend $100, $200, $300 or more!
Unread 12-09-2010, 01:12 PM   #10
gunshw301
Dont forget the yj's!
gunshw301 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2010, 10:12 PM   #11
gremlinsteve
whats the eta on shipping one of these?
steve
gremlinsteve is offline   Reply With Quote Quick reply to this message
Unread 12-19-2010, 10:22 PM   #12
PoisonSpyder
Vendor
PoisonSpyder's Avatar
steve
In stock and ready to ship!
Jeep TJ LJ Exterior Upgrades | TJ LJ Hood Louver | Poison Spyder Customs
Poison Spyder Customs, Inc.
Protection for you and your Jeep
951-849-5911
www.PoisonSpyder.com
Spyder Bytes Blog
Become a fan on Facebook
MySpace a Place for Friends
PoisonSpyder is offline   Reply With Quote Quick reply to this message
Unread 12-19-2010, 11:14 PM   #13
mightydog78
i will get one when they make it for a 99 TJ!
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2010, 09:13 AM   #14
gremlinsteve
order was placed..
Unread 12-21-2010, 12:11 AM   #15
GraKee99
Rapist Wit
GraKee99's Avatar
Any plan for CJs?
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
