Poison Spyder Full Cage Kits with Lazer-Fit features - Page 4 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder Full Cage Kits with Lazer-Fit features
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiFS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-04-2014, 04:11 PM   #46
tjcj
Originally Posted by 07wurubi View Post
There has been allot of debate in other threads on here over the use of A pillar plates versus through the dash. Has PSC done any type of rollover testing to verify the plates would hold up in a rollover just as well as through the dash will? If so, I'd very much like to see results, video or pics of it if so. I am wanting a full cage and still up in the air on which one or which way to go.
At one time there was a rumor in another thread of PSC coming out with a threw the dash A- pillar bar like the poly kit.
Sent from my XT881 freeze ray gun using JeepForum.
Yakima Valley Mountaineers.
tjcj is offline   Reply With Quote Quick reply to this message
Unread 05-05-2014, 05:03 PM   #47
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
Originally Posted by Copperhead89 View Post
Hey PSC, you can add this top to the list of tops that don't fit. The Bestop Super Top soft top will not fit over the PSC Lazer Fit cage on a YJ. The problem is, the rear hoop extends back too far, and won't allow the rear window to be zipped closed. So, the only way to make this particular top fit, is to lose the rear hoop and all its supporting bars. I don't have a back seat, so its not a safety concern for me, but still, I've got a lot of cutting and grinding to do.
Thanks for the info. We'll make a note of that.
We would have to intentionally roll a Jeep in order to test that out. Can we borrow yours? LOL...seriously though, we agree that a continuous A-pillar tube that goes straight down through the dash to the floor, would be marginally stronger than the plate style A-pillars we use in our cage kits. That's why you haven't seen us wade into those threads to argue against that point. That's also why we don't recommend our A-pillars for racing use, and why the racing and competition rigs we've built ourselves use full-tubular A-pillars.
However, a piece of railroad track would be even stronger than .120 wall tubing. So why not make the cage out of railroad track? Of course that's a silly question with obvious answers. But it does illustrate a point: that there are compromises and reasons you would choose any product, material or design versus others. DOM tubing is "strong enough" that you don't need to go to the extra hassle, added weight, strange looks, etc that it would take to build the cage out of railroad track. Similarly, the plate style A-pillars, in our opinion, for most uses are strong enough to provide adequate protection to the occupants in just about any rollover situation under normal 4-wheeling conditions, at the speeds we typically see on trail runs versus racing. And anecdotal evidence has borne that out, as we've received lots of feedback from happy customers who have survived rollovers in their Jeeps equipped with our cages.
There are those who have argued vehemently in those threads that a cage like ours is worse than no cage at all, as according to them it gives the driver a false sense of security. But I think that depends on the driver. Just like our body armor won't make a Jeep invincible against the rocks if the driver is determined to use the Jeep as a wrecking ball, our cage probably isn't the best choice if you drive your rig like you're Shannon Campbell at KOH. If you're doing 80 through the whoops and lose control and cartwheel for a few hundred yards, you'd probably want a cage that's all tubular, and probably even chromoly, and with even more structural members than ours or a typical aftermarket cage provides. But if you're a regular Jeeper who drives normal trails, at normal speeds, but takes the occasional risk and needs extra protection from the typical rolls, flops and lean-overs that we see on any average run, then our cage A-Pillars will serve you well.
Those who are most vocal about our style of A-Pillar in those threads like to speculate about the plates collapsing like scissors and cutting your legs off. We haven't seen that happen, and frankly its not that likely, at least with our A-pillars. Ours aren't just a flat plate bolted to the floor and welded to the cage tubes up by the windshield. They have vertical bends and gusseting to give them extra strength in multiple planes, and remember they're made of 3/16" thick plate (most cages, including the remainder of our cages, are made with .120" wall tubing, less than 1/8" thick). Of course the shape of round tubing inherently provides more strength than flat plate, but its not like these are made of tinfoil. Also, consider that our A-pillars are not only bolted to the floor (and to a frame tie-in if you go that route, or through our Rocker Knockers if you install them that way), but they're also bolted to the strongest part of the Jeep's tub where they go up along where the dash meets the cowl and door posts. Plus there's a tubular cross bar just above the dash. For the A-Pillars to collapse and scissor your legs off they'd have to bring the entire tub/firewall and dash of the Jeep with them.
Again, we do concede that an all-tube A-pillar, that goes straight through the dash to the floor with as few bends as possible, is stronger than our plate A-pillars. That's why we do have plans to offer a version of our cage like that at some point (we've had those plans for years, just haven't gotten around to them yet). So we're not going to argue that our plate A-Pillars are stronger. But for many Jeepers they are the right combination of strength, ease of installation, ease of use, etc.
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote Quick reply to this message
Unread 05-11-2014, 01:23 PM   #48
Copperhead89
Soft top update! Amazingly, I was able to get the Bestop Super Top to fit into place. Leaving the pieces out in the sun for a few hours made an incredible difference. As you can see in the pictures, the rear hoop does push against the top of the back window, which made adjustment of the rear bow a bit of a challenge. Hopefully, that interference won't damage the back window over time. Anyway, I just wanted to report this development.
My YJ/CJ V8 Magnum Build: http://jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
Copperhead89 is online now   Reply With Quote Quick reply to this message
Unread 05-12-2014, 08:26 AM   #49
DTS
Vendor
DTS's Avatar
Soft top update!
Thanks Copperhead89 for adding to the knowledge base here! Yes please update us if there are any further developments. This is good info for those who are considering that top and this cage.
Unread 05-12-2014, 10:30 AM   #50
Cavasar
No Longer DD
Cavasar's Avatar
John has the full cage
Cavasar's TJ
Cavasar is online now   Reply With Quote Quick reply to this message
Unread 05-12-2014, 09:55 PM   #51
Copperhead89
Here is a pic of the inside, showing the relationship between the top of the cage and the Bestop Super Top.
Unread 03-24-2015, 09:09 AM   #52
DTS
Vendor
DTS's Avatar
We recently re-designed the entire cage for TJ and LJ. Check out this clip for a summary of the Lazer-Fit™ cage features including these new upgrades:
Unread 03-24-2015, 08:55 PM   #53
SpeedJeep
SpeedJeep's Avatar
Nice product. I would love the option of having a new cage shipped directly to my powder coater so I could pick it up from there but you still dont' offer an A pillar option. Why is this so difficult to do? By now you should at least have the option on the table for those who want it. I bet a local fabricator could bend up a couple of A pillars in an few hours. I can Google one for you if you need help.
When he's done you could shoot them with your fancy laser. PEW! PEW!
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline   Reply With Quote Quick reply to this message
Unread 03-25-2015, 08:22 AM   #54
DTS
Vendor
DTS's Avatar
I'm assuming you're talking about the through-the-dash A-Pillar tube for TJ. Its been on our list for a while and is still on there. We have a project coming up that will get one like that (Larry's new LJ trail Jeep), so it will be designed for production when we do get around to it.
Unread 03-25-2015, 06:11 PM   #55
Cavasar
No Longer DD
Cavasar's Avatar
Got my cage back from powder coating and into the TJ.
Mounts for the CB and dome light
Cavasar's TJ
Unread 05-13-2015, 10:26 AM   #56
watsoc08
Any idea of the time frame for the OE seat belt option you discuss on your website and show in the new video? Very interested in this option and will likely wait until you release it before purchasing anything.
watsoc08 is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 09:01 AM   #57
DTS
Vendor
DTS's Avatar
I can't give you an ETA for it. They've been done, its just a matter of getting them into the system and doing a run of them.
Unread 05-19-2015, 05:35 PM   #58
Cavasar
No Longer DD
Cavasar's Avatar
Cage is done. We added a plate for the cb, and another for the dome. Just need to figure out rear speakers, thinking wake board speakers.
Cavasar's TJ
Unread 05-20-2015, 08:58 AM   #59
watsoc08
Most wakeboard tower speakers are stadium speakers meaning that the sound projects to 80-100 ft. so that the rider can hear the tunes while behind the boat. I have a boat with the WetSounds pods and they are awesome for that application but would not be what I would want in the Jeep. Your best bet would be to get empty cans and then add car audio speakers to them so you get the sound in the jeep.
Unread 05-26-2015, 08:40 AM   #60
DTS
Vendor
DTS's Avatar
Cavasar check out the speaker cans from Crawl Tunes. I have them on my rig and I like them.
