Poison Spyder Full Cage Kits with Lazer-Fit features - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder Full Cage Kits with Lazer-Fit features
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 01-11-2010, 12:11 PM   #1
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
Poison Spyder Lazer-Fit Full Cage Kits!
Hey guys here's the text from our recent press release:
Poison Spyder Customs has re-engineered the way customer-weld-in cage kits are designed, manufactured and installed. The cutting edge Lazer-Fit™ system incorporates several manufacturing and design features that make installation by the customer much easier and faster, while also ensuring higher quality in the manufactured parts as well as the completed assembly. “We’ve simply brought the cage design and manufacturing process out from under the shadetree, into modern engineering and manufacturing processes,” claims Larry McRae, president of Poison Spyder Customs, Inc.
The Lazer-Fit™ system begins in the design phase, where components are CAD designed right inside a 3D model of the specific vehicle for which the kit is being designed. “By using an accurate 3D model of the vehicle,” says Kevin Dill, Poison Spyder’s product engineer, “we’re able to ensure the components precisely fit the vehicle before burning through a couple hundred feet of tubing on the shop floor.” Production of Lazer-Fit™ components takes place in state-of-the-art facilities. High strength structural DOM tubing is cut and notched by a CNC laser. The laser also etches part numbers and assembly guides directly onto the surface of the tube. Laser notching provides an exact, clean cut that fits its intended joint with no further grinding or fitting. After notching and etching, tube pieces are bent on a CNC bender that indexes off of the laser-etched markings to yield perfectly notched and bent parts.
A Poison Spyder Lazer-Fit™ cage can be installed in less than half the time it takes to install competitors’ cage kits. The Lazer-Fit™ system removes all the guesswork, grinding, notching, fitting, and opportunities for mistakes. Each piece not only comes already bent and notched to fit perfectly, but the part identification and installation marks etched directly onto each part make assembly a quick, simple process. Where a notched tube joins another, the shape of the notched tube end is etched right onto the other part, and where needed, index marks on both pieces can be lined up for proper clocking, removing all guesswork. You literally just piece it together and weld it up! The Lazer-Fit™ system makes it possible for even novice gearheads to install. And the time saving translates into significant money savings for those who have the cage installed at a shop.
“We’re excited about the Lazer-Fit™ system,” says McRae, “Nobody else does this in our market, although I’m sure the imitators will follow. But the best part is that now people with minimal fab skills can assemble their own Poison Spyder Customs cage, and if they have to take it to a shop for assembly, the cost in shop hours will be only a fraction of what it once was.” The first product to feature the Lazer-Fit™ system is Poison Spyder’s Full Cage Kit for Jeep TJ, which is currently in production and available for purchase. Poison Spyder cages for other Jeep Models will soon follow, all with the revolutionary features of the Lazer-Fit system.
Click Here for our current line of Full Cage Kits featuring the Lazer-Fit system.
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote
Unread 04-20-2010, 02:24 PM   #2
DTS
Vendor
DTS's Avatar
The Lazer-Fit Full Cage is now available for YJ! Check our website for details or call for a shipping quote. CJ's coming next...
Unread 06-04-2010, 03:49 PM   #3
DTS
Vendor
DTS's Avatar
We're happy to announce that the CJ-7 version of our Lazer-Fit(TM) Full Cage Kits is now available to pre-order! The R&D phase is over and they are now going into production. The first production run should be completed and shipping out within the next two weeks. We know many of you have been waiting patiently for t...hese, so now is your chance to place your order and be among the first CJ-7 owners to experience how fast and easy it is to install a Poison Spyder Lazer-Fit Cage! You can order online on our website or give Brent a call here at the shop at (951) 849-5911.
THE FIRST TEN PRE-ORDERS WILL RECEIVE A SET OF GRAB HANDLES FREE! (as shown in the pic below)
(NOTE: your card is not charged when you place your order, only when it ships!)
Unread 09-06-2010, 01:50 AM   #4
arejay06
What's the $$ the CJ-7 cage?
arejay06 is offline   Reply With Quote
Unread 09-06-2010, 08:52 AM   #5
Biglar
Junior Member
Biglar's Avatar
The CJ 7 cage is $999 and will install faster than any cage on the market.
Thanks
Larry
President
Biglar is offline   Reply With Quote
Unread 09-06-2010, 09:48 AM   #6
Recoil
Recoil's Avatar
1988 MJ Comanche
This is friggun brilliant. One thing I was not looking forward to was trying to figure out all the bars and fitment. Thanks for helping me make up my mind on a cage.
www.indyorv.com
EPIC
Recoil is offline   Reply With Quote
Unread 09-06-2010, 10:08 AM   #7
Biglar
Junior Member
Biglar's Avatar
We have a shipping special if you order this weekend
Larry
President
Unread 09-09-2010, 10:25 AM   #8
DTS
Vendor
DTS's Avatar
Nice shot of the TJ Lazer-Fit Full Cage Kit (thanks Yves!):
Unread 12-14-2010, 04:20 PM   #9
DTS
Vendor
DTS's Avatar
TTT for your Christmas shopping! :smokin:
Don't forget our December Specials where you can get FREE SWAG when you spend $100, $200, $300 or more!
Unread 02-28-2011, 04:41 PM   #10
DTS
Vendor
DTS's Avatar
The fastest, easiest-to-install Full Cage Kit on the market! The Lazer-Fit system means no notching, no grinding, no cussing, no hassle! And if you're having a shop do the install, the labor hours should be a fraction of other kits!
Unread 03-22-2011, 04:16 PM   #11
DTS
Vendor
DTS's Avatar
Don't forget the seatbelt bungs!
Unread 05-12-2011, 11:17 AM   #12
DTS
Vendor
DTS's Avatar
Rick Pewe from Petersen's 4WOR Magazine used our Lazer-Fit Cage kit on his 2010 Ultimate Adventure CJ-7 (with a couple of mods ).
Unread 05-25-2011, 10:28 AM   #13
DTS
Vendor
DTS's Avatar
Check out the article in 4Wheel Drive & Sport Utility magazine about the Lazer-Fit cage system!
Unread 05-25-2011, 10:40 AM   #14
Savvy
Savvy Off Road
Savvy's Avatar
Dusty,
Can we get the TJ or LJ cage with thru dash A-pillar. I want to do a write up on your cage but we really want thru dash A-pillars.
Let me know.
Thanks,
Gerald
949-870-8106
Email me for the fastest response: gman@savvyoffroad.com
Like us on Facebook FACEBOOK.COM/SAVVYOFFROAD
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
http://www.savvyoffroad.com
Savvy Spartan 2004 LJ
2012 JKU Test Mule
2006 LJ Unlimited Black Hole
2005 LJ Test Mule
2003 TJ Project Unrolled
2003 TJ Project Click Here
Savvy is offline   Reply With Quote
Unread 05-25-2011, 12:58 PM   #15
DTS
Vendor
DTS's Avatar
Gerald, it just so happens that Larry and I were talking about that very subject just a while ago. The through-the-dash all tube A-Pillar is something that Larry has wanted to add to the product line for quite a while. And while we are not yet actually working on it, we did recently acquire another TJ for R&D and this will be one of the projects we'll be putting to it. Its actually not that big of a variation from the existing kit so once we turn our attention toward it, it should be pretty quick after that. LJ versions are also on the drawing board but I don't have an ETA for them.
