Poison Spyder DeFenders™ - "Tubeless" Jeep Fender Armor! - Page 5 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder DeFenders™ - "Tubeless" Jeep Fender Armor!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Wrangler WeatherstrippingJeep Wrangler Exhaust Manifold
Unread 11-12-2011, 05:46 AM   #61
trevor98tj
Couldn't a guy weld a piece of flat stock behind the inner fender with nuts welded to it after drilling the holes for the lower fender mount, thus eliminating the need for the access panels? There should be a way around this. Trevor
trevor98tj is offline   Reply With Quote Quick reply to this message
Unread 11-14-2011, 10:58 AM   #62
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
Originally Posted by trevor98tj View Post
Can you make a set without the access panels on the side? Just a nice stock style flat bare steel? I would be interested for sure in a set of 4.5"s.
Sorry, the existence of the access hole is a done deal, and we have no plans to offer DeFenders without the hole. It is a feature we included to make them easier to install, since our old school tube fenders didn't have it and it was harder to install those. While the hole itself is there to stay, we are considering a couple of different variations for the insert/cover for those who would like something other than what is already offered.
We are considering other flare widths, but they will come later after we've completed the roll-out of the remaining initial models (YJ, CJ, then hi-lines).
Originally Posted by ajf1994 View Post
Access panels are necessary for installation. You need to reach in there for the bolts/nuts. I think it was mentioned earlier in this thread. I think the access hole covers would be sweet in a louvered/mesh design, but that's just me. If they were vented in some way, would it be possible to flush out the insides/exposed areas so that it drained somehow? Just thinking from a salt collection (anti-corrosion) angle...
A louvered version is one of the variants we are considering.
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote Quick reply to this message
Unread 11-18-2011, 11:11 AM   #63
DTS
Vendor
DTS's Avatar
All flavors now available and well stocked for TJ/LJ! Steel or Aluminum, in Negative Flare, Zero Flare, or 3" Flare. Matching rear 3" DeFender Flare also available in steel or aluminum, by itself as a weld-on or already welded to Crusher Corners. We're still running our $100 off Intro Pricing on front DeFenders. See the website for pricing on all variants!
Unread 11-20-2011, 03:32 PM   #64
bmosing
bmosing's Avatar
I still would love to see the negatives or zeros installed!!
bmosing is offline   Reply With Quote Quick reply to this message
Unread 11-20-2011, 04:51 PM   #65
epeck87
i noticed on your site your rear tube fenders for the tj are not available. are you planning on stop making your old fenders and just sell defenders. i wanted a set of rear tj fenders to match my poison spyder rockers and front fenders and cage
Associates Degree in automotive technology
A1-A8 ASE MASTER CERTIFIED TOYOTA MECHANIC
epeck87 is offline   Reply With Quote Quick reply to this message
Unread 11-20-2011, 06:17 PM   #66
edmonddantes
X1000 very interested.
edmonddantes is offline   Reply With Quote Quick reply to this message
Unread 11-21-2011, 10:40 AM   #67
DTS
Vendor
DTS's Avatar
Yes the tubes are being phased out of our product line as the DeFenders roll out. But I believe you may still be able to order the rear tube "Crusher Flares", at least for a little while longer, just give our sales dept. a call at 951-849-5911.
Unread 11-21-2011, 10:54 AM   #68
DTS
Vendor
DTS's Avatar
Here's the Zero's on Savvy's KOH rig:
Here's the Negatives on DJ Harmon's KOH rig (mod class):
I'll add more photos as I get them.
Unread 11-21-2011, 12:20 PM   #69
Bakpack
Would you happen to have an original set of flared tube fenders still in stock? I've noticed that some PSC vendors are still listing them. I'd like to order but I wouldn't want to get a set of these by mistake.
Thanks
Bakpack is offline   Reply With Quote Quick reply to this message
Unread 11-21-2011, 12:48 PM   #70
DTS
Vendor
DTS's Avatar
Thanks
Call our sales department, they can check stock on the old tubes for you. 951-849-5911. Or email sales@poisonspyder.com if you are not able to call. Thanks,
Unread 11-21-2011, 04:01 PM   #71
gremlinsteve
any plans for a matching rear type fender?
gremlinsteve is offline   Reply With Quote Quick reply to this message
Unread 11-21-2011, 04:09 PM   #72
edmonddantes
See page 4.
Unless you're talking about a matching negative fender....which would be corner armor and no flare.
Unread 11-21-2011, 11:17 PM   #73
TheWicked
i will buy 4.5 if you come out with them
TheWicked is offline   Reply With Quote Quick reply to this message
Unread 11-22-2011, 09:25 AM   #74
DTS
Vendor
DTS's Avatar
See page 4.
no-flare rears match the Zero's as well as the Negatives
Noted, we'll hold you to it
Unread 11-28-2011, 01:27 PM   #75
DTS
Vendor
DTS's Avatar
Thanks to Anthony Fox for these shots. DeFenders with 3" Flares, painted to match body color:
