Poison Spyder DeFenders™ - "Tubeless" Jeep Fender Armor! - Page 17 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder DeFenders™ - "Tubeless" Jeep Fender Armor!
Rough Country Jeep Suspension Deals at Rockridge 4WD!JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 12-10-2012, 12:21 PM   #241
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
Originally Posted by NJHCx4xLIFE View Post
How much work would it take to get the xc inner fender to work with the non-xc version. My fab skills are pretty slim but if it is as simple as trimming 3" or so off the bottom inner fender pieces and everything will otherwise line up I can handle that. Since there is no eta for the non-xc inner fender I'm weighing my options for the defenders I'm waiting to install.
I think it would be a little more complicated than just trimming the bottom. The back edge of the fender well is angled forward, meaning the inner fender assembly is tapered (narrower at the top). So the taller XC version would be narrower at the top than what you would need for the standard DeFenders. If you went ahead and bolted them in there, you'd not only have to trim some from the bottom, but the cut-out for the shock/spring tower would be placed too far toward the rear (you could open it up some but there would be a gap). Also, the front edge wouldn't reach all the way to the side of the grille, so you'd have to cut/fab a small tab or bracket to span that gap. All in all it wouldn't be impossible, but it would be more involved than simply trimming off the bottom 3".
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote Quick reply to this message
Unread 12-19-2012, 05:37 PM   #242
WhiteRuby06
Originally Posted by DTS View Post
Sorry guys, no ETA's on anything. WhiteRuby06 I can guarantee they won't be a Christmas gift for this year. tjcj, those are even further back on the burners.
no problem i can hold off buying new fenders for a little while. Happy holidays to you guys and ill check back in a few months thanks
WhiteRuby06 is offline   Reply With Quote Quick reply to this message
Unread 01-25-2013, 01:54 PM   #243
DTS
Vendor
DTS's Avatar
YJ DeFenders with Negative Flare
Unread 02-15-2013, 06:42 AM   #244
NJHCx4xLIFE
Dusty... Any updates. I'm sure things have been busy but was curious if there might be any news on the inner fenders for regular defenders. Thanks.
NJHCx4xLIFE is offline   Reply With Quote Quick reply to this message
Unread 02-15-2013, 12:31 PM   #245
DTS
Vendor
DTS's Avatar
There's no news on those yet. They are still on our list of "To Do's", but unfortunately I still can't give you an idea of when.
Unread 02-15-2013, 03:12 PM   #246
midnight_f150
Have you started on Larry TTC Jeep yet? I voted for him and I hope he gets picked.
midnight_f150 is offline   Reply With Quote Quick reply to this message
Unread 02-18-2013, 10:03 AM   #247
DTS
Vendor
DTS's Avatar
Yes we have, its been here for a few months already. Thanks for the vote. We'll be starting a "campaign" for it soon
Unread 03-05-2013, 09:07 PM   #248
jjt4806
I crunched the driver fender wheelin' this weekend - oops! - so now I'm FORCED to upgrde another part of the Rubi. In looking at pics of the defender installs, I've noticed a number of them that have a tapered gap between the hood and the fender (larger towards the rear) - including some of the rigs in your website gallery. Are these just because the people putting them in didn't bother to check the gap prior to drilling? Just wanted to get your thoughts on this prior to putting the cash down..
Thanks
Jeff
jjt4806 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2013, 10:33 AM   #249
DTS
Vendor
DTS's Avatar
jjt4806, I think what you're seeing is mostly optical illusion. The curve of the Jeep's hood can make it look like what you're describing depending on the angle its viewed from. The bolt holes where the DeFenders mount to the body tub are a little oversized to allow for adjustment, so its possible that some may have installed them slightly too low, but that's an easy remedy to just loosen those bolts, slide the DeFender upward so that the topline of it matches that horizontal body line.
Unread 04-01-2013, 09:17 PM   #250
WhiteRuby06
Just checking in on any progress on the 3" tapered flares?? Summer time is coming soon, I need a new project!
Also no April fools jokes
Unread 04-01-2013, 09:26 PM   #251
tjcj
Ya this in aluminum?
Sent from my XT881 freezeray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline   Reply With Quote Quick reply to this message
Unread 04-01-2013, 09:28 PM   #252
WhiteRuby06
Yes definitely aluminum
Unread 04-02-2013, 09:23 AM   #253
DTS
Vendor
DTS's Avatar
There's no news on them. They are still in our "to do" list but they are not on the front burner yet. When I have some news on them I'll post it up here. And yes they will be available in both steel and aluminum, like all of our DeFender products
Unread 04-03-2013, 03:46 PM   #254
midnight_f150
When will larry find out if he will be in the TTC?
Unread 04-03-2013, 04:51 PM   #255
Biglar
Junior Member
Biglar's Avatar
Soon I hope!! I asked everyone I know at 4 Wheeler in Moab. They were all very tight lipped.
Larry
President
Poison Spyder Customs, Inc.
Biglar is offline   Reply With Quote Quick reply to this message
