Poison Spyder DeFender Inner Fender Kits - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder DeFender Inner Fender Kits
Savvy FOX IFP 4" Lift Shocks in StockOnly 2 Days left to win $3,800 Jeep Parts!Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 08-20-2013, 11:45 AM   #1
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
This new Inner Fender Kit for Poison Spyder TJ DeFenders allows you to install a set of DeFenders without cutting up your stock fenders and retaining your stock inner fenders. We've had a similar Inner Fender kit available for our DeFender XC (highline) for some time, but now have them for the standard height DeFenders as well.
The DeFender Inner Fender Kit provides for a complete, bolt-in DeFender installation for those who either do not have their stock inner fenders or would rather sell them than cut and re-use them. Each inner fender is a 3-piece bolt-together assembly, made of CNC laser cut aluminum sheet.
Please note that no accessory mounting holes or brackets are provided, as each installation is left to the discretion of the installer to decide where to mount components. Most stock inner fender-mounted components can be re-mounted to the DeFenderô Inner Fenders by simply drilling a hole and/or fabricating a simple bracket. Unfortunately, we have not yet found an elegant solution for retaining the stock air box, so an aftermarket air intake or open air filter element (such as a K&N conical filter) may be needed. We'll update this thread when we have a better idea of the options for retaining the stock air box.
The TJ DeFender Inner Fender Kit is available Spyder Direct for $149.00, or through any of our Authorized Poison Spyder Dealers.
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote Quick reply to this message
Unread 06-24-2014, 12:28 PM   #2
DTS
Vendor
DTS's Avatar
Poison Spyder DeFender Inner Fender Kits are now available in a VENTED version. The Vented inner fenders help promote airflow through the engine bay, which can be important for slow-moving crawlers in hot climates. The Vented Inner Fender Kit is identical to our regular "Solid" Inner Fender Kit, except that the main center panel has a honeycomb vent pattern that has been CNC laser cut into it.
The vented panels are available in a complete kit for those doing a new DeFender Inner Fender Kit installation. The vented panels by themselves are also available separately for those who already have an existing DeFender Solid Inner Fender Kit installed, but would like to convert to vented.
TJ DeFender™ Vented Inner Fender Kit
TJ DeFender™ Vented Inner Fender Panels
TJ DeFender™ XC Vented Inner Fender Kit
TJ DeFender™ XC Vented Inner Fender Panels
These are available directly from Poison Spyder or through any of our Authorized Poison Spyder Dealers.
Unread 07-09-2014, 06:29 PM   #3
DTS
Vendor
DTS's Avatar
Here's a shot of the new DeFender XC Vented Inner Fenders on Justin from Rock Krawler's stretched LJ:
