Poison Spyder Crusher Corners™ are built for the off-road enthusiast who likes to play in the big rocks. Crusher Corners™ are a key component in avoiding body damage to your Jeep. Choose from our Standard, Stock or Comp Cut or Modified Crusher Corners™ to fit your crawler's unique needs. Poison Spyder Crusher Corners are laser cut from high strength 3/16" plate steel then carefully roll-formed for a perfect fit to your Jeep's body lines. All of the bolt holes are countersunk, and the supplied stainless steel flat head cap screws yield a smooth, flat surface to slide over rocks.
For the ultimate in corner protection and hard core looks, add the optional weld-on Crusher Flares™ to your Crusher Corners™. Crusher Flares™ are fabricated from 1.5" x .120 wall tubing with a precision-formed 1/8" plate steel fender. Crusher Flares™ extend 3" outboard to provide extra body protection and a surface to slide along rocks and trees on tight trails. The 3" Crusher Flares™ match the factory flare tire coverage to help you stay legal in those areas where flares are required by law. 6" flares are coming soon (call for availability), which provide extra coverage for Jeeps with wider tires, full width axles or wheel spacers. Weld-On Crusher Flares™ are also available separately, to retrofit your existing Crusher Corners™, home-built or other manufacturers' corner guards.
Bolt-On Crusher Flares™ Can be bolted on to Jeeps with existing Crusher Corners™ or other manufacturers' corner protectors. They have a CNC-laser cut full mounting plate (not just a few tabs) with countersunk bolt holes for the included stainless steel flat head cap screws. The bolt pattern matches the stock TJ flare bolt pattern—drilling will be required if your existing corners do not already have this bolt pattern. Bolt-on Crusher Flares™ are a great addition to Poison Spyder aluminum Crusher Corners™, where a weld-on flare is not available.
Crusher Corners™, when used in conjunction with Poison Spyder
Rocker Knockers™ or
Ricochet Rockers™and front
Tube Fenders give your Jeep an impenetrable defense against rock damage. All of these components are designed to fit and work together perfectly, guarding your Jeep from the front wheel well to the tailgate!
