-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   Poison Spyder Crusher Corners (http://www.jeepforum.com/forum/f43/poison-spyder-crusher-corners-1076790/)
DTS 07-26-2010 11:02 AM
http://www.poisonspyder.com/images/p...-A-prodpic.jpg
Poison Spyder Crusher Corners™ are built for the off-road enthusiast who likes to play in the big rocks. Crusher Corners™ are a key component in avoiding body damage to your Jeep. Choose from our Standard, Stock or Comp Cut or Modified Crusher Corners™ to fit your crawler's unique needs. Poison Spyder Crusher Corners are laser cut from high strength 3/16" plate steel then carefully roll-formed for a perfect fit to your Jeep's body lines. All of the bolt holes are countersunk, and the supplied stainless steel flat head cap screws yield a smooth, flat surface to slide over rocks.
http://www.poisonspyder.com/images/p...-installed.jpg
For the ultimate in corner protection and hard core looks, add the optional weld-on Crusher Flares™ to your Crusher Corners™. Crusher Flares™ are fabricated from 1.5" x .120 wall tubing with a precision-formed 1/8" plate steel fender. Crusher Flares™ extend 3" outboard to provide extra body protection and a surface to slide along rocks and trees on tight trails. The 3" Crusher Flares™ match the factory flare tire coverage to help you stay legal in those areas where flares are required by law. 6" flares are coming soon (call for availability), which provide extra coverage for Jeeps with wider tires, full width axles or wheel spacers. Weld-On Crusher Flares™ are also available separately, to retrofit your existing Crusher Corners™, home-built or other manufacturers' corner guards.
Bolt-On Crusher Flares™ Can be bolted on to Jeeps with existing Crusher Corners™ or other manufacturers' corner protectors. They have a CNC-laser cut full mounting plate (not just a few tabs) with countersunk bolt holes for the included stainless steel flat head cap screws. The bolt pattern matches the stock TJ flare bolt pattern—drilling will be required if your existing corners do not already have this bolt pattern. Bolt-on Crusher Flares™ are a great addition to Poison Spyder aluminum Crusher Corners™, where a weld-on flare is not available.
Crusher Corners™, when used in conjunction with Poison Spyder Rocker Knockers™ or Ricochet Rockers™and front Tube Fenders give your Jeep an impenetrable defense against rock damage. All of these components are designed to fit and work together perfectly, guarding your Jeep from the front wheel well to the tailgate!
DTS 09-09-2010 10:33 AM
Just a little heads-up for those watching this thread, the current Special of the Month is a FREE Tramp Stamp and Windshield Sticker with Crusher Corners purchase!
http://www.poisonspyder.com/images/m...cial-10sep.jpg
Click Here for YJ-TJ-LJ
Click Here for JK
DTS 12-14-2010 04:19 PM
TTT for your Christmas shopping! :smokin:
Don't forget our December Specials where you can get FREE SWAG when you spend $100, $200, $300 or more!
DTS 01-18-2011 09:59 AM
Bump!
http://pix.poisonspyder.com/Products...86_SX3Ru-M.jpg
DTS 02-28-2011 04:50 PM
Poison Spyder Crusher Corners are available with no flare, or with standard width or full width weld-on Crusher Flares!
http://pix.poisonspyder.com/Products...54_QQZiP-L.jpg
DTS 03-22-2011 04:12 PM
http://pix.poisonspyder.com/Products...18_hDdnb-L.jpg
jeepndel 03-29-2011 06:43 AM
Albright Jeep Runs Crusher Corners
I gotta say, my Poison Spyder Crusher Corners are flippin' awesome! They gave "Red", the Land Use War Machine a new look, and like totally *****en corner/side protection.
I added the Ricochet Rockers (Access Army version) to give me some added leverage when I "twirl" Red around the big rocks on the Rubicon. :tea:
Find me in Moab at Easter Jeep -- "Red" will be all over town and trails for the whole week.
Thanks Poison Spyder for your awesome products.
Del
DTS 05-20-2011 12:11 PM
http://pix.poisonspyder.com/Events-1..._g6SqP-L-1.jpg
DTS 05-25-2011 03:51 PM
A set of Comp Cut Crusher Corners getting some Flares...
http://pix.poisonspyder.com/Aroundth...05-25592-L.jpg
DTS 08-09-2011 12:07 PM
:D
http://pix.poisonspyder.com/Products...08-02644-L.jpg
DTS 08-24-2011 04:32 PM
:D
http://pix.poisonspyder.com/Products...-CUST-02-L.jpg
DTS 09-02-2011 12:19 PM
LJ Crusher Corners™ with Standard Width Weld-On Crusher Flares™ :D
http://pix.poisonspyder.com/Products...tzler-04-L.jpg
DTS 02-15-2012 12:17 PM
CLICK HERE for our full line of 3/16" CNC laser cut, precision brake-formed Crusher Corners, in Steel or Aluminum, with or without DeFender Flares or Crusher Flares!
http://pix.poisonspyder.com/Vehicles...2-144047-L.jpg
http://pix.poisonspyder.com/Vehicles...2-144058-L.jpg
DTS 07-18-2012 10:41 AM
Thanks to our friends at Classic City Off-Road for these shots of their TJ with Poison Spyder Crusher Corners with 3" DeFender Flares (and matching front DeFenders).
http://pix.poisonspyder.com/Products...-CUST-01-L.jpg
http://pix.poisonspyder.com/Products...-CUST-07-L.jpg
DTS 01-22-2013 03:48 PM
Poison Spyder Crusher Corners! Available for LJ, TJ, YJ, CJ-8 and CJ-7!
http://pix.poisonspyder.com/Products...Hopper01-L.jpg
Available without flares, as shown above, or with our DeFender Flares to match our front DeFenders
http://pix.poisonspyder.com/Events-1...IMG_3665-L.jpg
Also available in aluminum! Thanks to Debbie Barker for this shot of her Aluminum Crusher Corners, polished to shine. Or you can paint, powdercoat or leave them natural.
http://pix.poisonspyder.com/Products...Barker01-L.jpg
The time now is 11:58 AM.
Powered by vBulletin Version 3.8.4
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
