Poison Spyder from CCOR! - Page 11 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder from CCOR!
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 04-05-2013, 10:00 AM   #151
CCOR
Vendor
Check it out!
The RockBrawler™ II is the latest evolution in JK rear bumpers, incorporating many features requested by customers, and product improvements born of real world use and testing of the original RockBrawler™. This bumper combines the best features to maximize performance on the toughest trails with some of the more refined traits not normally needed on a dedicated rock crawler. Its most prominent feature is the all new RockBrawler™ II Tire Carrier, which connects to the tailgate for easy, single-action opening. It's also slightly wider and deeper than the orignal RockBrawler™ for increased corner protection, and features an integrated hitch.
Integrated Single-Action-Open Spare Tire Carrier
The RockBrawler™ II Spare Tire Carrier's Single-Action-Opening feature is a huge convenience for when you're trying to open the tailgate and tire carrier with one hand, when you've got an armload of gear or groceries in the other. Rather than latching to itself, the RockBrawler™ II tire carrier is tethered to the tailgate so that they open and close in tandem. A custom designed tie-rod assembly, bumper mechanism and Tramp Stamp™ keep the two pieces perfectly aligned when open, but tight and rattle-free when closed.
Tire Carrier Fabricated Plate Steel Construction
The RockBrawler™ II Spare Tire Carrier is fabricated entirely from CNC laser cut, precision brake-formed plate steel. The pieces are expertly welded together in a specially designed assembly fixture to ensure consistent fit and quality. A web gusset design is cut into the corner of the tire carrier to provide a little Poison Spyder flare.
Extreme Duty Hinge Assembly
The extreme duty hinge assembly includes a precision CNC machined spindle and housing, with a pair of high quality Timken tapered roller bearings to provide smooth operation under the heaviest loads A spindle seal at the bottom of the hinge assembly keeps your lubrication in, and dirt and water out. The hinge assembly is capped with a CNC machined billet aluminum cap with the Spyder emblem machined in.
2-Way Adjustable Tire Mount
The tire mount is adjustable up and down, as well as in and out, to accomodate a wide variety of tire sizes up to 39". The adjustability allows the tire to be mounted as low as possible for any tire size, to keep a low center of gravity.
License Plate Relocation Mount
The included license plate mount places the license plate at the center of the spare tire, for those who choose to move it there. Unlike the original RockBrawler™ rear bumper, the RockBrawler™ II Rear Bumper with Tire Carrier does NOT obstruct the placement of the stock license plate frame, so the installer may choose to leave it in the stock location or move it to the center of the rear tire using the included bracket. We recommend relocating it, as the stock mount sticks out significantly from the side of the Jeep and is just begging to be torn off by a rock along the trail. If relocating the license plate, our License Plate Delete Cover and LED License Plate & 3rd Brake Light (each sold separately) will be useful in completing the relocation.
Multi-Faceted Bumper Design
The RockBrawler™ II Rear Bumper's high clearance, multi-faceted design provides the best possible departure angles and corner obstacle clearance. Its appearance is streamlined and sexy, not like the squarish, boxy shape of many other bumpers on the market. The RockBrawler™ II Rear Bumper is slightly wider and wraps around the Jeep's corner and farther forward, when compared to the original RockBrawler™ Rear Bumper. This provides an increased degree of protection from corner impacts on the trail.
Call 706-207-4140 to order!
www.classiccityoffroad.com
To order call 706-559-9609
Randy's Gear Supply
CCOR is offline   Reply With Quote Quick reply to this message
Unread 04-09-2013, 01:41 PM   #152
CCOR
Vendor
Been out sick please bear with me on returning Pm's.
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 04-09-2013, 02:03 PM   #153
max70
Hi,do you ship to Italy?
max70 is offline   Reply With Quote Quick reply to this message
Unread 04-09-2013, 07:00 PM   #154
CCOR
Vendor
Typically we only ship to North America
Randy's Gear Supply
Unread 04-11-2013, 07:10 AM   #155
CCOR
Vendor
Thanks for all the business!
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 04-12-2013, 12:23 PM   #156
CCOR
Vendor
Get all your armor for your Jeep at CCOR!
Randy's Gear Supply
Unread 04-15-2013, 08:35 AM   #157
CCOR
Vendor
TJ/LJ BFH™ Front Bumper with Brawler Bar
Poison Spyder Customs BFH™ front bumper is designed for those hardcore four-wheelers who value strength, simplicity and function. This bumper was literally "Built For the Hammers" with the best ground clearance, tire clearance and approach angle possible. It is no wider than the Jeep's frame rails, with angled facets to improve its ability to slide over the rocks. The BFH™ bumper is CNC laser-cut from a single piece of high strength 3/16" plate steel, then precision brake-formed for an exact fit. The BFH™ bumper features an integrated winch mount and one-piece design.
Customize your BFH™ bumper with several different Stinger/Bar options, Winch Fairlead Mount, and Heavy Duty Shackle Tabs:
The optional Brawler Bar is a lower-profile Stinger, fashioned after the 2-bend Stinger featured on our Original RockBrawler bumper for JK. The Brawler Bar features the most versatile combination of trail protection and a lower profile for easier access to the engine compartment, fitment into garages and trailers, etc. Plus it looks bad-***! The Brawler Bar extends 7.4" forward from the front edge of the bumper, and 9.8" high from the top surface of the bumper.
The optional Trail Stinger™ is similar in proportion to the famous Poison Spyder Trail Stinger™. This time-honored design has proven itself on hundreds of Jeeps over the past decade, providing simple, clean lines along with a measure of forward-flop protection. The Trail Stinger™ extends 13.4" forward from the front edge of the bumper, and 17" high from the top surface of the bumper.
The optional Comp Stinger™ for the BFH™ front bumper matches the lines of our stand-alone Comp Stinger™s. For those getting into the more hard-core aspects of the sport, the Comp Stinger™ provides even better forward-roll prevention, as well as increased protection of the radiator area and engine compartment in the event of a rollover. The Comp Stinger™ extends 17.6" forward from the front edge of the bumper, and 21.9" high from the top surface of the bumper.
The optional Recovery Shackle Tabs are machined from 1" thick plate steel to provide a secure attachment point for 3/4" recovery shackles. These tabs are specifically engineered to match the angles of the BFH™ bumper to result in zero loss in approach angle.
The optional Winch Fairlead Mount is a separate piece (bolt-on, not weld-on) that mounts between your winch and the BFH™ bumper to provide a secure mounting surface for the winch fairlead (find it in the "Related Items" section below).
The JK BFH Disco Skid is an optional bolt-on skid plate to protect the factory electric swaybar disconnect motor on JK's. In stock form this motor hangs low, making it vulnerable to rocks and trail hazards. The BFH Disco Skid protects it, but also comes with hardware and instructions to rotate the motor upward, further out of harm's way. Like the BFH bumper, the Disco Skid is made of CNC laser-cut 3/16" plate steel and is designed to be a great looking, functional addition to the JK BFH bumper.
Whether you keep it simple or customize it with all the options, the BFH™ front bumper is a serious bumper for hardcore wheeling!
Call 706-207-4140
Randy's Gear Supply
Unread 04-16-2013, 12:19 PM   #158
CCOR
Vendor
LJ Rocker Knockers™ with Sliders
Poison Spyder Rocker Knockers™ are the ultimate protection for your Jeep's vulnerable rocker panel area. As the trails get tougher and recreational off-roading gets more and more hardcore, vehicle body damage becomes more prevalent. And rocker panels are most vulnerable, taking hits from both underneath and the sides as you work your way through tight obstacles.
Poison Spyder Rocker Knockers™ protect your rocker panels by cladding them in rugged, high strength 3/16" plate steel armor. Rocker Knockers™ are manufactured to hug the lines of your Jeep's rocker panels perfectly, forming a glove-fit with virtually no loss of valuable ground clearance. Specifically engineered for most Jeep CJ, YJ, TJ and LJ models, Rocker Knockers™ are CNC laser cut from high strength 3/16" plate steel, and precisiion brake-formed for a perfect fit. Bolt holes are countersunk for the included stainless steel flat head hardware, which yields a flat, unobstructed surface to slide over obstacles. All mounting hardware is included as well as detailed installation instructions. Poison Spyder Rocker Knockers™ bolt to your Jeep's body in key areas, and interface with strenghtened areas of the underside of the tub such as body mounts, strenthening ribs, etc. Because they mount to the body itself, there is no resulting gap or misalignment when a body lift is installed.
For added side protection on the trail, Rocker Knockers™ can be ordered with the optional tubular Slider. The Slider is crafted of high strength DOM structural tubing, welded to the Rocker Knocker™ with additional DOM tube spacers. The result is a combination of rocker panel protection and a tubular slider to keep your rig's bodysides a few precious inches away from taller rocks and trees. The Slider may also become an integral part of your driving strategy, as it may be useful to pivot the vehicle around obstacles while searching for traction. It also serves as a short entry step, assisting entry and egress. For those who want a more purpose-built entry step, check out Poison Spyder's Ricochet Rockers™.
For installations in which you would like to protect the paint underneath the Rocker Knocker, as well as provide a measure of vibration absorption, we offer an optional Rubber Liner, precisely cut to fit between the Rocker Knocker and the Jeep's body. Be sure to order these separately, as they're not included in the standard Rocker Knocker™ package.
For Do-It-Yourselfers, we offer the slider tubes by themselves in kit form. With the DIY Slider Tube Kit you can add a rugged, DOM tube slider to your home-built or other manufacturer's rocker protectors. The kit includes the slider tubes as well as the short tube supports to brace the center of the tube against the rocker, to do both sides of the Jeep. We do not recommend welding them to the stock sheetmetal or to steel thinner than 1/8", with 3/16" being the ideal plate thickness to weld them to. Installation should be performed by a certified welder.
For installations in which you would like to protect the paint underneath the Rocker Knocker™, as well as provide a measure of vibration absorption, we offer an optional Rubber Liner, precisely cut to fit between the Rocker Knocker™ and the Jeep's body. Be sure to order these separately, as they're not included in the standard Rocker Knocker™ package.
IMPORTANT: Some of the installed images below depict an earlier version of these Rocker Knockers™, which had a deeper cut-out in order to reveal the "Unlimited" decal on the side of the Jeep. The current Rocker Knocker™ design is like the uninstalled photo, where there is only a slight dip in the topline of the Rocker Knocker™ to clear the Jeep logo. The current design COVERS the "Unlimited" decal.
Randy's Gear Supply
Unread 04-17-2013, 09:04 AM   #159
CCOR
Vendor
TJ Rubicon 6" RC Long Arm suspension with Fox IPF aluminum body shocks, 35x12.50x17 Nitto Trail Grapplers, 17x9 Moto 951's, Custom 1350 CV driveshaft, Poison Spyder Full roll cage Powder Coated semi Gloss Black!
Call 706-207-4140 to get your Jeep build scheduled in at CCOR!
poisonspydertjrollcage.jpg   tjpoisonspydercage1.jpg   tjpoisonspydercagefront.jpg   tjpoisonspydercagefrontside.jpg   tjpoisonspydercagerearcorner.jpg
Randy's Gear Supply
Unread 04-19-2013, 03:30 PM   #160
CCOR
Vendor
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 04-24-2013, 02:04 PM   #161
CCOR
Vendor
I appreciate all of the orders and PM's don't hesitate to call us at 706-207-4140!
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 04-25-2013, 12:17 PM   #162
CCOR
Vendor
Great times!
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 04-26-2013, 07:24 AM   #163
CCOR
Vendor
Great Customer and Friend of ours in front of her 4 Door JK outfitted with Poison Spyder goodies and Larry McRae at Jeep Beach 2013
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 04-26-2013, 02:07 PM   #164
CCOR
Vendor
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
Unread 04-28-2013, 07:45 AM   #165
CCOR
Vendor
Great deals are waiting on you!
Thanks,
Bobby
Sales Manager
706-207-4140
Randy's Gear Supply
