Poison Spyder Brawler Rockers! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder Brawler Rockers!
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSOPTIC ARMOR WINDOWS all sale now !!!!!!!!FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 11-03-2010, 10:18 AM   #1
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
Jeep JK's, especially the long wheelbase 4-door Unlimited, are extremely vulnerable to rocker armor damage on the trail. Poison Spyder Brawler Rockers™ provide the ultimate rocker armor protection while actually enhancing your Jeep's off-road capability—not to mention they look bad-***!
Poison Spyder Brawler Rockers™ are two-piece "mini-boatside" style rocker armor. Each component is fabricated entirely of CNC-laser cut, precision brake-formed 3/16" plate steel. The upper piece fits the lower section of your Jeep's exterior sheetmetal like a glove, conforming to the sublte curvature of the JK and providing protection similar to Poison Spyder's JK Body Armor™. The lower piece incorporates an extremely strong rub rail that protrudes about 3" outboard of the Jeep's body tub. The top surface of the rub rail may also serve as an entry step. Below, the brake-formed 3/16" plate steel angles down and inward to form a high clearance boatside for sliding off of rocks and obstacles. Inside, an array of beefy 3/16" thick internal gussets provide ultimate strength to the Brawler Rocker™. Oval lightning holes along the length of the boatside section provide great Poison Spyder looks while allowing access to hose out mud and debris after a day on the trail. The ends of the Brawler Rockers are capped in the same 3/16" plate steel, in angled facets that allow up to a 40" tire and visually integrate with the lines of Poison Spyder front and rear JK Crusher Flares™.
The upper piece attaches to the body tube using supplied stainless steel flat-head cap screws and nut-serts. The lower piece attaches to the upper piece also with stainless steel flat-head cap screws and easy-to-install clip-nuts. All fastener holes are countersunk for a flat surface using the flat-head hardware. Underneath, the lower piece attaches at the Jeep's body mounts. Attaching the Brawler Rockers™ in this way, along several different planes, provides triangulated strength to the entire assembly. The body-mount tie-ins ensure that they are securely integrated to the strongest structural component of the Jeep—the frame—while also allowing the Brawler Rocker™ to hug the body tub as closely as possible, and to move upward with it in the event that a body lift is installed.
Brawler Rockers™ are designed to handle a serious beating! They not only provide unmatched rocker protection, but they also provide a super strong pivot point which can help you to maneuver through tight obstacles. The boatside design will allow the Jeep to slide off of rocks and back onto the center of the trail. The protruding rub rail keeps vertical obstructions such as trees and rock walls a safe distance from the Jeep's doors and other vulnerable body parts. And when you need to change a tire or perform an extraction, the Brawler Rocker™ provides a strong, convenient lifting point for your Hi-Lift jack.
Brawler Rockers™ ship as bare steel, allowing you to paint or powdercoat in the color of your choice. Note that if you have previously installed Poison Spyder's JK Body Armor, you will be able to re-use the existing nut-serts, saving a significant amount of installation time (Body Armor will have to be removed).
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote
Unread 11-05-2010, 07:10 PM   #2
DTS
Vendor
DTS's Avatar
Here's a video with Larry discussing the features and benefits of the new Brawler Rockers:
YouTube - Poison Spyder Brawler Rockers
Unread 12-14-2010, 04:18 PM   #3
DTS
Vendor
DTS's Avatar
TTT for your Christmas shopping! :smokin:
Don't forget our December Specials where you can get FREE SWAG when you spend $100, $200, $300 or more!
Unread 01-10-2011, 11:22 AM   #4
DTS
Vendor
DTS's Avatar
Off-Road.com posted a nice write-up of our Brawler Rockers.
Unread 02-16-2011, 11:21 AM   #5
DTS
Vendor
DTS's Avatar
King Of the Hammers Proven!
Unread 02-22-2011, 05:03 PM   #6
DTS
Vendor
DTS's Avatar
Nice 2-tone color job on this customer's Brawler Rockers...
Unread 03-08-2011, 04:51 PM   #7
DTS
Vendor
DTS's Avatar
2-DOOR JK Brawler Rockers are READY!!
I hope to have some photos of these mounted within the next few days.
You can now order the 2-Door Brawler Rockers online from our website, or place your order by phone at (951) 849-5911, or purchase them through your favorite Authorized Poison Spyder Dealer!
Unread 03-14-2011, 03:11 PM   #8
DTS
Vendor
DTS's Avatar
Got some installed shots of the 2-Door Brawler Rockers. They actually look pretty good with the stock flares on Doug-E-Fresh's Jeep. But they'll look even better when he gets around to adding some more PSC armor
Unread 03-14-2011, 04:22 PM   #9
SKINUM
U make any of these for the Jeep LJ?
SKINUM is offline   Reply With Quote
Unread 03-14-2011, 05:02 PM   #10
DTS
Vendor
DTS's Avatar
Sorry we don't, although we have 3 other types of rocker armor for LJ's. Check those out here. Thanks!
Unread 03-14-2011, 05:07 PM   #11
SKINUM
Already looked at those but thanks anyways.
Unread 03-22-2011, 04:09 PM   #12
DTS
Vendor
DTS's Avatar
These make a good lifting point for a hi-lift jack...
Unread 04-20-2011, 01:50 PM   #13
aztec_doc
What's the gross weight on the 2 door style.
aztec_doc is offline   Reply With Quote
Unread 04-20-2011, 02:20 PM   #14
DTS
Vendor
DTS's Avatar
102 lbs.
Unread 04-20-2011, 06:47 PM   #15
aztec_doc
Nice, Do you powder coat are they bare?
