Poison Spyder
Rear Crusher Flares™ are finally available in a bolt-on version for Jeep CJ, YJ and TJ/LJ. Now you can easily add tough, great looking Crusher Flares to your aluminum or steel Crusher Corners™, or other manufacturer's (or your home built) steel or aluminum corner protectors.
Fabricated from 1.5" X .120 wall DOM tubing and CNC laser cut 1/8" plate steel, Crusher Flares™ can handle the punishment inflicted by rocks, trees, or even other Jeeps! And they not only withstand their own damage, but they also help to protect the rest of the Jeep's body side by keeping it a safe distance from the obstacle. The mounting surface is a 3/16" thick full plate, not just a few tabs, with countersunk bolt holes for flush bolt heads.
These "Standard" Bolt-On 3" Crusher Flares™ are designed to fit the large TJ/LJ-style wheel opening. They can also be used on CJ and YJ, where the larger wheel opening is desired. They mount using coutnersunk, flat head stainless steel hardware (included), in a bolt pattern that matches the stock TJ flare bolt pattern. If you have Crusher Corners™ that already have this bolt pattern, install is a simple bolt-on. To retrofit to corners that do not already have the bolt holes, simply drill them using the flares as your template. Note that these can also be bolted directly to the Jeep's tub, without corner protection, but we do not recommend that.
The photo above is of our weld-on Crusher Flare but the Bolt-On version is identical in shape and size. We'll post up installed photos of the bolt-ons when we have a set powdercoated and mounted up.
These are available now! Call (951) 849-5911 to order or get a shipping quote by phone, or
check out the web page for more infor or online ordering.
