Poison Spyder BFH II Rear Bumper for Jeep TJ-YJ - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Poison Spyder BFH II Rear Bumper for Jeep TJ-YJ
Introducing MONSTALINER UV Permanent DIY Roll On Bed LineFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 09-25-2013, 09:19 AM   #1
DTS
Vendor
JeepForum 2012 Vendor Giveaway Participate
DTS's Avatar
The new BFH II rear bumper for TJ and YJ is now available! This bumper was literally "Built For the Hammers" designed with light weight, toughness and performance in mind.
This is basically a "frame cap" style bumper, hugging the rear end of the Jeep's frame and crossmember to provide the best obstacle clearance and departure angle possible. But unlike other frame cap bumpers that are on the market, the BFH II incorporates signature Poison Spyder style, with multiple angles and facets to give the bumper great looks on top of its hard core functionality. This replaces the original BFH Rear Bumper for TJ-YJ, which has been discontinued.
The BFH II is CNC laser-cut from high strength 3/16" plate steel, then precision brake-formed for an exact fit over the Jeep's rear frame and crossmember. The heavy duty recovery shackles are CNC machined from 1" thick plate steel, and welded both inside and outside the bumper shell. The tabs are standard equipment on the BFH II, and are designed to accept 3/4" recovery shackles (AKA "D-Rings"). This bumper is available in bare steel onlyit will need to be painted or powder coated prior to final installation.
For more info about the BFH II rear bumper for TJ and YJ, see our website or any of our Authorized Poison Spyder Dealers.
Dusty Sharp - Marketing Director
Click Here for the Latest Poison Spyder News!
Poison Spyder Customs - 951-849-5911 - Connect with us on: Facebook / YouTube / Twitter
DTS is offline   Reply With Quote Quick reply to this message
Unread 09-25-2013, 09:21 AM   #2
DTS
Vendor
DTS's Avatar
Coinciding with the release of the BFH™ II rear bumper for TJ and YJ, we are also releasing our new TJ Rear Bumper Brace Kit.
The Poison Spyder Jeep TJ Rear Bumper Brace Kit adds more strength to your TJ's rear bumper mounting. This is especially important if you intend to tow, use bumper-mounted recovery points, or a bumper-mounted spare tire carrier. This is a recommended upgrade for all Poison Spyder TJ rear bumpers, including the RockBrawler™ and BFH™ line of rear bumpers.
The braces are CNC laser cut and precision brake-formed from 3/16" plate steel. They include a strengthening gusset to provide additional strength over competitors' non-gussetted braces. There is an access hole conveniently placed in the center of the gusset for a socket to reach the rear body mount nut, if needed. Nut plates—with both nuts welded to a single plate to simplify installation—are supplied, which are inserted inside the frame rail so that the supplied Grade 8 hardware securely clamps the wall of the Jeep's frame rail. The TJ Rear Bumper Braces and Nut Plates are bare steel, and will need to be painted or powder coated prior to final installation.
Check these out on our website or inquire with any of our Authorized Poison Spyder Dealers.
