Panhard Parts & Kits from Ruffstuff! - JeepForum.com
post #1 of 35 Old 07-10-2011, 01:11 PM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
We make 4 different Panhard / Trackbar brackets and I get alot of questions as to why not just one?
Here is the simple answer. You are either replacing a weak factory bracket that has broken and need something stronger and more versatile or you are swapping a new axle into your rig and need something that works better or is more adaptable!
We make 2 for the axle end and 2 for the frame end. In this pic, from the top left (going clockwise) we have the Axle Offset Bracket because 70-80% of the time you need the additional room on the axle. Next we have the Axle Centered Bracket for those of you that can work with one, both have 3 height adjustment positions. The lower right shows the Frame Outside Bracket for those of you going full width and to the left the Frame Inside bracket for the relatively stock width axle. The Frame brackets both have 2 mounting positions so matching up is easy.
Remember, Selection is always the key! We have been making these for 4 years but I don't think I ever posted these here...No time like the present!
We also make the complete kit with the DOM to keep the cost down for you! http://www.ruffstuffspecialties.com/catalog/PANKIT.html
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #2 of 35 Old 02-19-2012, 12:09 PM Thread Starter
Dan Fredrickson
Vendor
Time for a bump to keep it in your eyes!
Dan Fredrickson
post #3 of 35 Old 03-02-2012, 11:08 AM Thread Starter
Dan Fredrickson
Vendor
A simple solution with options!
Dan Fredrickson
post #4 of 35 Old 03-14-2012, 11:28 AM Thread Starter
Dan Fredrickson
Vendor
If you have a linked front end and some lift with larger than stock tires and you are still using the stock panhard bar you also have issues. This will help you resolve those issues!
Dan Fredrickson
post #5 of 35 Old 04-02-2012, 11:04 AM Thread Starter
Dan Fredrickson
Vendor
Time to get it done the right way!
Dan Fredrickson
post #6 of 35 Old 04-18-2012, 12:20 PM Thread Starter
Dan Fredrickson
Vendor
When you need it you definately need it!
Dan Fredrickson
post #7 of 35 Old 04-23-2012, 10:53 AM Thread Starter
Dan Fredrickson
Vendor
Simple and strong, things that count when you are abusing your rig beyond what factory specs allow
Dan Fredrickson
post #8 of 35 Old 04-26-2012, 10:35 AM Thread Starter
Dan Fredrickson
Vendor
Easy and versatile!
Dan Fredrickson
post #9 of 35 Old 05-02-2012, 10:06 AM Thread Starter
Dan Fredrickson
Vendor
No time like today to get it all working right!
Dan Fredrickson
post #10 of 35 Old 05-07-2012, 11:48 AM Thread Starter
Dan Fredrickson
Vendor
Still Crabwalking down the road? Time to do it the right way!
Dan Fredrickson
post #11 of 35 Old 05-22-2012, 11:21 AM Thread Starter
Dan Fredrickson
Vendor
When you want to do it right the first time!
Dan Fredrickson
post #12 of 35 Old 05-29-2012, 05:05 PM Thread Starter
Dan Fredrickson
Vendor
A simple way to tell if you have binding issues with your Panhard is:
When your rig is sitting there, not moving, and you turn the wheel and the drivers side lifts 1/2" to 2" you are binding on the panhard.
Dan Fredrickson
post #13 of 35 Old 06-01-2012, 03:12 PM Thread Starter
Dan Fredrickson
Vendor
It is an easy fix but it is a bit of work...
Dan Fredrickson
post #14 of 35 Old 06-27-2012, 01:52 PM Thread Starter
Dan Fredrickson
Vendor
Driving straight or crabwalking, its your choice!
Dan Fredrickson
post #15 of 35 Old 07-11-2012, 11:57 AM Thread Starter
Dan Fredrickson
Vendor
WE MAKE IT EASY FOR YOU TO DO IT RIGHT THE FIRST TIME
Dan Fredrickson
Steering and more from Ruffstuff! Dan Fredrickson Vendor Display 375 09-07-2017 09:00 AM
DOM Tube now available at Ruffstuff! Dan Fredrickson Vendor Display 51 07-07-2014 09:18 AM
Panhard Kits from Ruffstuff! Dan Fredrickson Vendor Display 45 05-13-2013 02:37 PM
You may not post new threads
