PANDEMIC-USA D30 or D44 INNER AXLE TUBE SLEEVES (NO WELDING & NO DRILLING) - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > PANDEMIC-USA D30 or D44 INNER AXLE TUBE SLEEVES (NO WELDING & NO DRILLING)
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-29-2015, 01:12 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Pandemic has finally created a nicely machined NO-DRILL, NO-WELD inner axle tube sleeve to help add a tremendous amount of strength the the factory front JK axle tubes. This upgrade adds nearly 60% more strength by doubling the axle tube wall thickness.
These sleeves are designed to be hammered in. We have added a few nice features to the sleeves that the competitors sleeves do not have. You will find these sleeves to install easier with the lightly chamfered ends on the O.D. of the inner portion of the sleeve and a cleaner look with the I.D. Chamfered out near the axle joint, plus it allows for easier installation of the axle shaft due to know rough edges near the end of the tube. The Sleeve has a knurled end with a .010" interference fit. Rest assured. These babies will add a ton of strength and they WILL NEVER COME OUT!
Email me direct for your quote Eric@Rockridge4wd.com
sales@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
