Our Panhard / Trackbar brackets, Variations...... - JeepForum.com
post #1 of 61 Old 07-12-2012, 12:13 PM Thread Starter
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
We make 4 different Panhard / Trackbar brackets and I get alot of questions as to why not just one?
Here is the simple answer. You are either replacing a weak factory bracket that has broken and need something stronger and more versatile or you are swapping a new axle into your rig and need something that works better or is more adaptable!
We make 2 for the axle end and 2 for the frame end. In this pic, from the top left (going clockwise) we have the Axle Offset Bracket because 70-80% of the time you need the additional room on the axle. Next we have the Axle Centered Bracket for those of you that can work with one, both have 3 height adjustment positions. The lower right shows the Frame Outside Bracket for those of you going full width and to the left the Frame Inside bracket for the relatively stock width axle. The Frame brackets both have 2 mounting positions so matching up is easy.
Remember, Selection is always the key! We have been making these for 4 years but I don't think I ever posted these here...No time like the present!
We also make the complete kit with the DOM to keep the cost down for you! http://www.ruffstuffspecialties.com/catalog/PANKIT.html
Dan Fredrickson
The New Industry Standard
Sales & Tech 916.600.1945
Dan Fredrickson is offline
post #2 of 61 Old 07-23-2012, 10:54 AM Thread Starter
Dan Fredrickson
Vendor
Panhard Kits and Components From Ruffstuff!
We make it strong and affordable..
Dan Fredrickson
post #3 of 61 Old 08-05-2012, 09:43 PM Thread Starter
Dan Fredrickson
Vendor
Its Pretty Easy...
If when you turn to the left does your frontend rise? If it does you need to work on your Panhard angle...
Dan Fredrickson
post #4 of 61 Old 08-07-2012, 09:14 PM Thread Starter
Dan Fredrickson
Vendor
Time to do it the right way
Dan Fredrickson
post #5 of 61 Old 11-06-2012, 09:49 AM Thread Starter
Dan Fredrickson
Vendor
It's build season! Time to upgrade!
Dan Fredrickson
post #6 of 61 Old 05-13-2013, 02:33 PM Thread Starter
Dan Fredrickson
Vendor
Time to move up!
Dan Fredrickson
post #7 of 61 Old 05-23-2013, 09:33 AM Thread Starter
Dan Fredrickson
Vendor
The common issue is the trackbar adapter bolt coming loose, time to fix it!
Dan Fredrickson
post #8 of 61 Old 05-28-2013, 08:48 PM Thread Starter
Dan Fredrickson
Vendor
If you swap to full width or even add larger tires you need to swap your Panhard for a longer one...
Dan Fredrickson
post #9 of 61 Old 06-06-2013, 12:02 PM Thread Starter
Dan Fredrickson
Vendor
Always a great time to upgrade!
Dan Fredrickson
post #10 of 61 Old 06-28-2013, 12:15 PM Thread Starter
Dan Fredrickson
Vendor
When it comes to fabrication parts, we got you covered!
Dan Fredrickson
post #11 of 61 Old 07-13-2013, 12:58 PM Thread Starter
Dan Fredrickson
Vendor
Thanks for the orders guys!
Dan Fredrickson
post #12 of 61 Old 08-13-2013, 11:22 AM Thread Starter
Dan Fredrickson
Vendor
Tuesday bump, keep those orders coming!
Dan Fredrickson
post #13 of 61 Old 09-10-2013, 09:14 AM Thread Starter
Dan Fredrickson
Vendor
All very good options to choose from!
Dan Fredrickson
post #14 of 61 Old 09-24-2013, 11:06 AM Thread Starter
Dan Fredrickson
Vendor
Some of these other options out there just don't get it....but ours do!
Dan Fredrickson
post #15 of 61 Old 10-15-2013, 10:03 AM Thread Starter
Dan Fredrickson
Vendor
Can't beat the deals on these!
Dan Fredrickson
Panhard Parts & Kits from Ruffstuff! Dan Fredrickson Vendor Display 34 05-31-2014 09:31 PM
BETTER BRACKETS! - ARTEC's FORM+FUNCTION Suspension brackets ARTEC Vendor Display 26 11-01-2013 11:07 AM
Panhard Kits from Ruffstuff! Dan Fredrickson Vendor Display 45 05-13-2013 02:37 PM
You may not post new threads
